Old 11-12-2012, 08:00 AM   #1
MrHix OP
MrHix's Avatar
Oddometer: 384
2012 KTM 690 Specific Mods
Hi,
I have tried to read thru the forum for information specific to the 2012 690 Enduro R but it is confusing.
Can I extend the wires on the MAP switch to move it to the front of the bike without messing things up? Not sure how sensitive the ECU is to resistance.
Does the 2d & 3d gear mod also work on the 2012? How does the ECU limit power: timing, fuel, both, other?
Thanks for the help!
Cheers,
MrHix
Team Lemon Curry???
2012 KTM 690 Enduro R
MrHix is offline   Reply With Quote
Old 11-12-2012, 08:47 AM   #2
SKINNY
SKINNY's Avatar
Oddometer: 645
As far as I know, the 2nd/3rd gear mod isn't required for the off-road models...there is no limiter.
Never heard of anyone moving the underseat switch, but you can buy an aftermarket switch that will do the same thing..
SKINNY is offline   Reply With Quote
Old 11-12-2012, 02:08 PM   #3
MrHix OP
MrHix's Avatar
Oddometer: 384
I have not found an aftermarket switch that looks plug-&-play or says that it will work on a 2012 690 ER. Looked at the LV one and another that had 5 or 6 wires and my switch only has 2.
Hmmmm . . .
Cheers,
MrHix
Team Lemon Curry???
Old 11-12-2012, 05:27 PM   #4
offworlder
Oddometer: 256
Trailtech ?
While I cant say whether it'll work on a 2012, I've got the Trailtech on my 2010:
http://www.trailtech.net/040-HMS-A3A.html
I dont use (nor have I wired the extra kill switch), but the mode switch sure is handy in the slippery stuff...
offworlder is offline   Reply With Quote
Old 11-12-2012, 05:30 PM   #5
Bumpaman
Location: Foot of the Sangre de Cristos and Music City, TX.
Oddometer: 159
Offworlder, was the Trailtech plug and play? Will it work on earlier 690's? Thanks
Bumpaman is offline   Reply With Quote
Old 11-12-2012, 05:33 PM   #6
offworlder
Oddometer: 256
Trailtech plugs in where the underseat (rotary) mode switch does. I keep the stock switch in place in case I have to switch back . Me thinks it'll work an all 690s, as that switch has been standard since 2009 (?)....
Old 11-12-2012, 07:49 PM   #7
MrHix OP
MrHix's Avatar
Oddometer: 384
Thanks offworlder,
I'll give TrailTech a call tomorrow to confirm or deny that it works on the 2012 690 ER.
Cheers,
MrHix
Old 11-13-2012, 06:23 PM   #8
MrHix OP
MrHix's Avatar
Oddometer: 384
I called Trail Tech today and they said their KTM MAP switch will not work on the current 690. Bummer.
Cheers,
MrHix
Old 11-14-2012, 04:21 AM   #9
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 961
Thanks for the feedback
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 11-14-2012, 06:05 AM   #10
MrHix OP
MrHix's Avatar
Oddometer: 384
Grainger has a rotary switch that may help: http://www.grainger.com/Grainger/POW...y-Switch-2VLR8
I'll try to find out more. A switch, some wire, and 3 resistors would make a nice, compact setup.
Cheers,
MrHix
Old 11-14-2012, 06:15 AM   #11
Oldbear
Don't want a pickle
Oddometer: 225
Cheers,
MrHix
If you want to make your own switch the resistance values for each setting are as follows:
0 Poor fuel quality: infinite
1 Soft: 15kOhm
2 Advanced: 6.8kOhm
3 Standard: 4.7kOhm
Oldbear is online now   Reply With Quote
Old 11-14-2012, 08:08 AM   #12
MrHix OP
MrHix's Avatar
Oddometer: 384
1 Soft: 15kOhm
2 Advanced: 6.8kOhm
3 Standard: 4.7kOhm
Got it, thanks.
MrHix
Times are GMT -7.   It's 11:02 PM.
