Old 11-12-2012, 11:19 AM   #1
JRP OP
Old guy
JRP's Avatar
Oddometer: 1,362
Trailtech Endurance II
I posted this in Thumps but I think I might get a better response here.
I have mounted one on my 2012 Husky TE 250. I want to use it and the stock speedo together. I made up a double ended sensor cable.
My problem is that only the stock speedo will work when both are hooked up. I have switched sensor ends to both units and either will work if plugged in one at a time, so the sensor wiring is OK.
I have switched to a super magnet at the advice of a member on Cafe Husky to increase the signal. I still only had the stock one reading and it was incorrect, unless I really was going 253 MPH.
There is really no place to mount a second sensor that will work from the stock magnet.
Any help at all would be greatly appreciated!
"What could possibly go wrong? " The Jerk
2012 TE 250
2010 F 650 GS
1983 R 80 G/S
JRP is offline   Reply With Quote
Old 11-12-2012, 01:10 PM   #2
FatBob
The name says it all
FatBob's Avatar
Oddometer: 237
You could run the signal through a DPDT switch. They both wouldn't work together but you could easily switch between them.
The older I get, the faster I was!
Ride Safe, Ride Often
FatBob is offline   Reply With Quote
Old 11-13-2012, 03:52 AM   #3
JRP OP
Old guy
JRP's Avatar
Oddometer: 1,362
Yes I could, but I really want both to work at the same time.
2012 TE 250
2010 F 650 GS
1983 R 80 G/S
Old 11-13-2012, 10:38 AM   #4
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 496
Could you run both in parallel (meaning two complete cables)? Maybe glue or zip-tie one sensor to the other? I have two on my bike, both zip-tied inside the fork leg and running off the same magnet, only separated by a mm or two and they both work, one's a Trailtech, the other a Sigma bike computer.
If your gonna be dumb, you gotta be tough
When you get knocked down you gotta get back up,
I ain't the sharpest knife in the drawer but I know enough, to know,
chollo9 is offline   Reply With Quote
Old 11-13-2012, 11:20 AM   #5
JRP OP
Old guy
JRP's Avatar
Oddometer: 1,362
Yes, that is the plan. I just don't know which sensor to get as there is not much available room in the back of the fork leg on top of the caliper. The only other place the magnet is available is in front of the fork, not the best place for a dirt bike.
2012 TE 250
2010 F 650 GS
1983 R 80 G/S
Times are GMT -7.   It's 11:21 AM.
