11-17-2012, 02:34 PM
#16 |
....58....
Oddometer: 2,238
What forced me to find a solution was arriving at a meeting point for a Sunday ride, with people looking on I struggled with the gear leaver. I guess it really hadn't bothered me up to then up to then as like the commenter before me I snick neutral before stopping. This time I was jammed with 100 bikes and riders............ It was very embarrassing for me and the KTM.
I have the aftermarket slave, steel 2005> rod, ability to bleed correctly. The solution was to drill the clutch basket.
The News, those who are trying to control what we think, do not want us to see. http://www.presstv.ir/live.html So good the British Gov. Banned it !!! http://rt.com/on-air/rt-america-air/ |
11-18-2012, 11:53 AM
#17 |
Oddometer: 54
Right ok...I do change into neutral before coming to a stop( it's a pain in the ass
when you're hiccuping through traffic). Point is I should be able to get neutral when stopped. I was able to, up until a few months ago. I've changed the slave and back plate. Now I gonna change the pushrod and clean the jet. If still no joy, then I'll look at the booster, clutch basket and like you suggested, drill the clutch basket (sounds a bit severe!). |
11-18-2012, 06:15 PM
#18 | |
Oddometer: 158
Removing the big clutch cover, just as you would to remove the snapring and inspect the spring, should get you in far enough to see which housing you have. It is possible you have the old housing but the upgraded piston and/or spring.. no way to check for that without removing the whole housing, IIRC. Other than the different spring retention setup, I'm not sure if there is any advantage to the newer housing as long as the spring and piston are updated. For the record, my apparently OEM 2004 spring came in only .5mm under spec.. but it clearly wasn't doing its job adequately. |
11-19-2012, 01:59 AM
#19 | |
....58....
Oddometer: 2,238
Bloc you are the second person to say this about the new valve....... good enough for me I'll order one in. The 04s were early in the production..... I love mine
11-19-2012, 07:19 AM
#20 |
They call me......Ronski
Oddometer: 553
K2m, I also did the Meoni mod to my clutch basket with the intent to install a larger oil jet.
When I drilled mine out to .50mm, the clutch drag when warm was TERRIBLE! I think the additional holes in the clutch basket exacerbate the oil drag for any given oil jet size. I tried .40mm and .36mm, and it was still impossible to find neutral. Went back to the .30, and can happily find neutral when stopped again!
Ronski Enduro Racer & Google Earth Adventurer |
11-20-2012, 08:57 AM
#21 |
Oddometer: 262
Thanks Bloc, I will have to check one day. The list of things to do is getting longer !
12-30-2012, 07:08 AM
#22 | |
Oddometer: 54
Anyway question: Is there anything else I should know about? + A friend said there's a tool I need to get, to hold in the basket when tightening it all up again. Anyone know about this/have a part number. Is this an expensive KTM tool or can I get a universal one? |
