Old 11-12-2012, 04:54 PM   #1
Kingsized OP
Kingsized Adventurer
Kingsized's Avatar
Oddometer: 792
Running through canbus without fuse
I just bought a used 550 and the canbus cable (BMW) didn't have a fuse inline. How power stable are GPS as a whole? I know there is no blanket answer but best guess if I should cut and place a fuse in this cable?
Everything's better in retrospect.
My ride through Bourbon county http://advrider.com/forums/showthrea...7#post22154447
Two Wheels Good, a journey out west http://twowheelsgood3.blogspot.com/
Kingsized is offline   Reply With Quote
Old 11-13-2012, 05:16 PM   #2
Mudcat
Unregistered
Mudcat's Avatar
Oddometer: 4,472
I think you can put away your worry beads. I have no issues with my Zumo 450 powered through CANbus. 5 years maybe
Oh Yeah, when I was making a power cord for my Zumo 220, the guys at GPScity confirmed I did not need a fuse when going through CANbus, well, from the GPS plug or an accessory outlet
I've got to be cool
Relax
Take a long long ride on my motor bike
Untill I'm ready
Mudcat screwed with this post 11-13-2012 at 05:33 PM
Mudcat is offline   Reply With Quote
Old 11-13-2012, 06:29 PM   #3
Bill Murray
Bill Murray's Avatar
Oddometer: 101
I powered a Zumo 550 via the BMW CanBus accessory connector for four year, without the inline fuse, with no problems. The fuse is there to protect your GPS from a voltage surge from the bike. The accessory CANBus source is only rated to provide 5 amps. (I now power my Montana 650 via the from CANBus connector.)
Try to keep the Zumo 550 mount dry. There is a seam that allows water to enter the mount, which eventually can cause corrosion and failure of the mount. I never experienced that problem, but you will see online accounts of this.
Bill Murray
2009 BMW R1200GS Adventure
Me on Google+
Bill Murray is offline   Reply With Quote
Old 11-13-2012, 06:31 PM   #4
Kingsized OP
Kingsized's Avatar
Oddometer: 792
Thanks. I wasn't worried about the Zumo as much as my Electrical system.
Thanks again
Old 11-14-2012, 06:24 AM   #5
Mudcat
Unregistered
Mudcat's Avatar
Oddometer: 4,472
Thanks again
Nope, the computer controls the electrical system on your BMW. There are no fuses. If a system draws more then the proscribed amount it is shut down by the computer.
The GPS plug and accessory ports shut down if the draw exceeds 5 amps.
I have my GPS powered from an accessory port on the left hand beak. I have a short power cable from the GPS unit which I can unplug easily, so, when I am parked in wonky areas, I just remove the GPS from the bike. It takes about 30 seconds.
I've got to be cool
Relax
Untill I'm ready
HTML code is Off
Times are GMT -7.   It's 07:35 AM.
