Old 11-12-2012, 05:25 PM   #1
cornercarver OP
cornercarver's Avatar
Oddometer: 18,536
1150GS parked 3 years, won't start. Help
I put a new Odyssey battery in that is fully charged. I siphoned out as much gas as I could and put a gallon of fresh gas in the tank. I changed engine and trans oil (I'll worry about final drive once it starts).
I put in new autolite plugs.
I get a spark from the plug wire when I ground it to the frame with a screwdriver.
So I assume that my problem is fuel. I detached what I believe to be the fuel injectors from the intake tubes and pushed the starter button and I don't get any noticeable liquid jetting out of the 4 little holes. But I'm not sure if I should. I do get fuel from the tank at the quick disconnects, and I can here the fuel pump doing its thing when I turn the key on.
The starter just goes round and round and nothing ever fires. It doesn't almost fire and fail. It just doesn't fire. So I think I'm not getting fuel all the way to the injectors.
So how do I diagnose where the problem is and how do I clean things up so that fuel gets through. I'm just looking to get it functional enough to sell the bike. You take a big hit if you try to sell a bike that won't start, but I'm not hiding the fact that it has sat idle for 3 years and I'm recommending that any purchaser take it straight in for service, so I just need to do enough to get the engine to fire up.
cornercarver is offline   Reply With Quote
Old 11-12-2012, 05:28 PM   #2
damurph
Cold Adventurer
damurph's Avatar
Location: The far east of the far east of North America
Oddometer: 2,004
Fuel filter?
If I still had every dollar I spent on motorbikes I would be a richer man but a poorer person.
damurph is offline   Reply With Quote
Old 11-12-2012, 05:31 PM   #3
100mpg
Self Imposed Exile
100mpg's Avatar
Oddometer: 17,565
It has not run at ALL for 3 years? something that meters the fuel into the engine is gummed up. that is my final answer.
100mpg is offline   Reply With Quote
Old 11-12-2012, 05:31 PM   #4
cornercarver OP
Oddometer: 18,536
Originally Posted by damurph View Post
Fuel filter?
Was changed immediately before the bike was parked for 3 years. I doubt it has had 10 gallons of gas go through it. Also, if the fuel filter were clogged, I wouldn't see gas at the quick disconnects, I think.
Old 11-12-2012, 05:33 PM   #5
cornercarver OP
Oddometer: 18,536
Yes, I get that. But what? How do I go about diagnosing it and fixing it? I'll forgo the diagnosis if there's a way to just pull all the likely parts and clean them somehow.
And no, it really hasn't moved at all in 3 years. It's possible that I started it a few times in the first year that it was parked, but once the battery died, it sat completely untouched.
Old 11-12-2012, 05:40 PM   #6
100mpg
Self Imposed Exile
100mpg's Avatar
Oddometer: 17,565
i said that because I don't know if it was carbed or FI. I looked it up and it is FI. So I am going to defer to someone that knows FI and injectors. If it was a carb, take it apart and clean it....but FI? Thats like magic to me!
On second thought, if you can get to the air filter and drop a few squirts of gasoline in to the throttle bodies, hit the starter and if it kicks over? you have clogged injectors.
on third thought....how come you haven't stated it in 3 years?! (I say that knowing my XRL is also gummed up...) hey, i have a Gold wing now!
Old 11-12-2012, 05:47 PM   #7
pcwirepro
Aspiring Adventurer
Oddometer: 282
Injector cleaning
http://f650cs.wikidot.com/fuel-injector-cleaning
http://www.youtube.com/watch?v=7aT4S1lIBAY
That's good that you have spark. Do you hear the fuel pump running? When you say fuel from the quick disconnects are you referring to a drop or two?
pcwirepro is offline   Reply With Quote
Old 11-12-2012, 05:55 PM   #8
Mrmerlin
K1300S fast as shi..
Mrmerlin's Avatar
Oddometer: 341
have you removed the air cleaner to determine if there might be a nest in that box ,
possibly plugging the cylinders
Mrmerlin is offline   Reply With Quote
Old 11-12-2012, 06:15 PM   #9
cornercarver OP
Oddometer: 18,536
yes - when I separate the quick disconnects after powering it up (and hearing the fuel pump), I get a drop or two of fuel.
I'll try cleaning the fuel injectors. That seems a likely candidate.
Old 11-12-2012, 06:28 PM   #10
pcwirepro
Aspiring Adventurer
Oddometer: 282
Fuel pump check
If your QD are installed with worm type clamps you could remove the male from the return and install it in the female QD on the supply side and run the pump just to confirm. Or you could cut off the irreversible clamp and do the same. That would also get any remaining old gas out of the tank.
pcwirepro screwed with this post 11-12-2012 at 06:49 PM
Old 11-12-2012, 06:45 PM   #11
RFK
Oddometer: 138
Fuel pump impeller could be seized...
RFK is online now   Reply With Quote
Old 11-12-2012, 07:13 PM   #12
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,809
Want to sell your Triumph?
def is offline   Reply With Quote
Old 11-12-2012, 10:39 PM   #13
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 12,190
It will turn over and not start with the side stand down.
Do you have it on the center stand with the side stand up?
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Old 11-13-2012, 04:26 AM   #14
skybo1
Oddometer: 91
Would he have a spark with the side stand down?
Do you get a spark with the safety switch shutoff on the handlebars?
Just wondering.
skybo1 is offline   Reply With Quote
Old 11-13-2012, 06:39 AM   #15
pcwirepro
Aspiring Adventurer
Oddometer: 282
He has spark
Times are GMT -7.   It's 03:26 PM.
