Old 11-12-2012, 06:19 PM   #1
waddyp OP
Quite Content
waddyp's Avatar
Oddometer: 476
Re-surface brake rotors?
At 50k miles on my '07 12GS, my front rotors are showing wear. Does anyone know: can they be 'turned' (re-surfaced)?
Ed in Michigan MOA 32687
'07 R1200GS
'03 Honda XR400
waddyp is offline   Reply With Quote
Old 11-12-2012, 06:23 PM   #2
07wee
07wee's Avatar
Oddometer: 67
Its possible, but I've never been able to find a shop willing to do it around me.
What holds your gear?
Helmet storage system
www.helmetbutler.com
07wee is offline   Reply With Quote
Old 11-12-2012, 07:14 PM   #3
Idle
Oddometer: 719
I'm prolly gonna die.
I resurfaced my front rotor while on the bike. I have a variable speed grinder and 4" diamond polishing pads.
I only did the outside but plan on flipping it around to do the same to the inside in the next couple of days.
I had a slight lip on the outside of my disc. I have since shimmed the caliper out so I felt I had to get the lip ground down to get 100% contact.
Fwiw, I used a little water on the 300 grit diamond pad and it was a 310mm disc well in spec.
Idle is offline   Reply With Quote
Old 11-12-2012, 07:16 PM   #4
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,207
Resurface? No.
But, what do you mean, "showing wear"?
Rotors do show signs of friction from the pads.
You'll need to determine rotor thickness and when out of spec, replace the rotors...kind of like tires.
def is offline   Reply With Quote
Old 11-12-2012, 07:42 PM   #5
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,020
Considering that the wear tolerance is .5 mm I don't see where the material is going to come from for a fresh surface on each side.
These are not automobile rotors.
Old enough to know better....
Young enough to try it again
GS Addict is online now   Reply With Quote
Old 11-12-2012, 07:52 PM   #6
Juvat
Juvat's Avatar
Oddometer: 695
^^^^ What he said. If you try to shave those (and it is a shave) you could end up in a world of hurt. I'd just mic them to ensure the dimensions are still serviceable, through some new pads on and go!
Juvat is offline   Reply With Quote
Old 11-12-2012, 07:55 PM   #7
Juvat
Juvat's Avatar
Oddometer: 695
Laugh
Note: I did see somebody throw their disks on an auto lapping table and they came out pretty good. Not worth doing if you don't have ready access to one though, and it is total overkill. My buddy just did it for fun.
Old 11-13-2012, 03:31 AM   #8
Chat Lunatique
ACK
Chat Lunatique's Avatar
Oddometer: 1,051
Absolutely it can be done. As a tool & die maker I had lots of people bring me old bike and car parts to try and salvage them because SPARES WERE NOT AVAILABLE!
One could set up the disc on an internal cylindrical grinder and remachine the faces with a cup wheel. Nice cross hatch pattern and good control over the amount of stock removal. Any other method can create disc wobble.
Should it be done? Naw...too easy to warp them or go under the min thickness trying too clean them up. Best to pony up the cash for new ones.
I do not intend to tiptoe through life, only to arrive safely at death
Chat Lunatique is offline   Reply With Quote
Old 11-13-2012, 05:57 AM   #9
Disco Dean
Disco Dean's Avatar
Oddometer: 1,276
Like he and he and he said... too thin to begin with and not worth the risk...
There is a nice little Brembo logo on the disk that is stamped into the disk - if it has been worn clean/smooth the disk are done - at least in my measurements it has worked out perfectly that way.
D.
youmoveyou
As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?
Disco Dean is offline   Reply With Quote
Old 11-13-2012, 07:08 AM   #10
def
def's Avatar
Oddometer: 10,207
If you insist on tinkering with motorcycle brake rotors, some sandpaper is allowed but, I would use caution....you're messing with the most important system on your motorcycle that may save your life one day.
Old 11-13-2012, 07:09 AM   #11
def
def's Avatar
Oddometer: 10,207
D.
Where? I've never seen it. Photo?
Old 11-13-2012, 12:32 PM   #12
Disco Dean
Disco Dean's Avatar
Oddometer: 1,276
I'll post a photo later as I dropped off the wheel to get a new tire on and haven't picked it up yet. Damn Heidenau's are so friggin stiff... spoon those babies on...
It is the Circular Brembo "b" logo and it sits half on the wear surface and half off on the inside of the disk. I have had other Brembo disks that have a similar placement.
My bike is a 2006 R1200gs if it matters.
I cannot confirm from Brembo that it is in fact a wear indicator - however it works to the specs perfectly - is situated to wear out with use and wears only half way to let you see that it is still there when the disks are worn out. As soon as I cannot make out the stamp - the disk mics out to the spec.
If it is not - it is a coincidence that it works. Either way I mic the disk to be sure but it is a good visual indicator as to when I should check.
youmoveyou
Old 11-13-2012, 12:46 PM   #13
def
def's Avatar
Oddometer: 10,207
I have not observed it on my 2001 Brembo equipped GS. However, that doesn't mean that it is not there.
Old 11-13-2012, 01:02 PM   #14
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,019
Taking the lip off is pretty funny. This is the place the pads never contact.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 11-13-2012, 02:29 PM   #15
ragtoplvr
Oddometer: 6,343
grooves are just more surface area.
if not warped and you do not race, use it.
Rod
ragtoplvr is offline   Reply With Quote
Times are GMT -7.   It's 09:42 PM.
