Old 11-13-2012, 05:25 AM   #1
Rockwell OP
Rockwell's Avatar
Oddometer: 669
Two holes in rim for valve stem?
I purchased THIS rim several months ago and just got to putting in on the bike yesterday. I noticed, after I put it together, that it had two holes (each about 6" apart) for the tube valve stem. Was there a mistake during manufacturing? I've never seen this before.
not all those who wander are lost | two earthlings ride around the world
Home | Photo Blog | The Route | The Bike | About Us | Participate!
Rockwell is offline   Reply With Quote
Old 11-13-2012, 05:26 AM   #2
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,974
The other would be for a rim lock.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 11-13-2012, 05:37 AM   #3
Rockwell OP
Rockwell's Avatar
Oddometer: 669
Thanks. Just got my TuneECU cable from your shop last week. Looking forward to using it once I have the bike started up again. Just finishing off the rebuild.
The bike has been without fluids since January (about 10 months). Should I have any concerns?
Old 11-13-2012, 06:36 AM   #4
xcflyn
xcflyn's Avatar
Oddometer: 1,152
Not a motor expert, But- as long as the motor never came apart I would not think twice about firing it up. If you are worried about lubrication you can always pull plug wires and crank it a little to prime the oil pump: before you do ask a real expert if you need to hook plugs to the wires and ground them to do this, some modern motorcycles will fry the coil caps (or so I am told) if you dont do this. When I was a young we would buy old motors from junk yards to rebuild for our "hot rod" projects, when we would pull them apart the bearings,lifters,and heads would all have oils in them, this was after sitting for years most of the time.
xcflyn is offline   Reply With Quote
Old 11-13-2012, 11:24 AM   #5
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 4,001
IT would also be a good idea to pour some motor oil down each cylinder and turn the motor over by hand a few times to lube the rings and walls. Doesn't take much teaspoon or two. Just pour it in via the spark-plug hole or intake valve if the carbs are off. Make sure to keep the valve open long enough for it to drip into the cylinder.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 11-17-2012, 04:55 PM   #6
Rockwell OP
Rockwell's Avatar
Oddometer: 669
I also just notice that the rim doesn't have the rubber strip around the inner part to protect the tube. Aren't new rims supposed to include this part?
Old 11-17-2012, 05:45 PM   #7
crofrog
Oddometer: 1,455
Just use some duct tape.
crofrog is offline   Reply With Quote
Old 11-18-2012, 06:52 AM   #8
booger1
booger1's Avatar
Oddometer: 924
Or, you can order the rim strips for the 950 SE which are thick and work better than duct tape.
Rear rim part number 63010073000 for $6.56
Front Rim part number 58409073100 for $4.47
Prices are through Munn Racing
Eating_goat_with_the_Cartel , Never_ventured_never_gained
oncostaricantime , boundlessbooger , 1998xr400buildwithe-start
Good judgment comes from experience. Experience comes from bad judgment - Mark_Twain
booger1 is online now   Reply With Quote
Old 11-18-2012, 06:58 AM   #9
crofrog
Oddometer: 1,455
If you want it thicker just go around the rim another few times. Duck tape never spins and makes getting the tube stem a pain to pull through. And when it wears out you just tape it up again
Old 11-18-2012, 07:00 AM   #10
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,745
+1 on duct tape... or Gorilla Tape.
traveltoad is offline   Reply With Quote
Old 11-18-2012, 08:38 AM   #11
Rockwell OP
Rockwell's Avatar
Oddometer: 669
I can try some duct tape. I just assumed the new wheel/rim should come with the rubber piece given that the photo on the website shows one and I paid $700 for the wheel.
Old 11-18-2012, 08:44 AM   #12
CRW
I dont want a pickle
CRW's Avatar
Oddometer: 765
also wrap the duct tape in same direction as wheel rotation
06 KTM 950 ADV
2006 KTM 450 EXC
DMC FRAMED XR125
CRW is offline   Reply With Quote
Old 11-18-2012, 09:20 AM   #13
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,030
This.
Can't use duct tape with rim locks anyways.
larryboy is online now   Reply With Quote
Old 11-18-2012, 09:32 AM   #14
Rockwell OP
Rockwell's Avatar
Oddometer: 669
Munn racing does not process international orders.
I guess I can buy these locally at any motorcycle shop?
Old 11-18-2012, 09:35 AM   #15
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,030
Yes.
Times are GMT -7.   It's 09:33 AM.
