Old 12-02-2012, 05:03 PM   #31
villageidiot
Oddometer: 1,615
Originally Posted by Kai Ju View Post
Makes me wonder how long that one was run before the owner got tired of the noise and lack of power.
seeing shit like that pains me.
villageidiot is online now   Reply With Quote
Old 12-02-2012, 05:11 PM   #32
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,320
Story I got with the pictures is, a guy was riding on the autobahn at about 6000 rpm. After hearing the noise (valve seat came loose) slowed and got onto the shoulder and limped it to the next exit.
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 12-03-2012, 07:46 AM   #33
caponerd
Kickstart Enthusiast
caponerd's Avatar
Oddometer: 1,980
Originally Posted by Beemerguru View Post
If it does look like that...unless you want/need the experience, don't even bother with the tear down except to get good parts. You've probably got metal bits in all the oil passages and pump. If oil pump gouged, block is gone. Rods are probably frozen on the crank, bearings seized, etc, MAYBE good lifters.
Take your new engine, put a set of new rings,,,maybe a timing chain - and ride. Use the old block for a door stop.
That's not the OP's engine.
And guessing by how long that engine must have run (on one cylinder) with pieces of broken off valve in there, nothing's seized at all.
If it had been shut down the moment it lost power and started making noise, it might even have been salvagable.
caponerd is offline   Reply With Quote
Old 12-03-2012, 07:47 AM   #34
caponerd
caponerd's Avatar
Oddometer: 1,980
Mike
Which was what caused 90 percent of the damage.
Old 12-03-2012, 08:40 AM   #35
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,320
Exactly, it should have been shut off at the first hint of noise and opened up for evaluation.
Mike
Times are GMT -7.   It's 10:16 PM.
