Old 11-13-2012, 10:52 AM   #1
sigpe57 OP
Oddometer: 340
R1100 throttle lock switch
I remember reading a article on the web regarding replacing the right hand switch with a European version which has a throttle lock.
Can anyone provide the link?
I found the picture. The throttle lock is on the top. What is the part number?
http://home.comcast.net/~racingiron/...uro_switch.jpg
Thanks,
TT
sigpe57 screwed with this post 11-13-2012 at 11:09 AM
sigpe57 is offline   Reply With Quote
Old 11-13-2012, 11:34 AM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,353
Google "Flip-a-lever"
It is similar to the above, and can be retrofitted to the stock switch gear.
Jim
Old 11-13-2012, 12:19 PM   #3
sigpe57 OP
Oddometer: 340
Stock switch does not have a hole for the locking screw.
Old 11-13-2012, 12:54 PM   #4
JimVonBaden
"Cool" Aid!
Oddometer: 53,353
Drill, tap! Very simple, and has been done for years. No sense replacing the stock one.
Jim
Old 11-13-2012, 01:01 PM   #5
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,026
The earliest 1100s did.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is online now   Reply With Quote
Old 11-13-2012, 01:59 PM   #6
vintagerider
vintagerider's Avatar
Oddometer: 1,962
Hi, what you have pictured there is the "authorities" control housing with the "authorities" locking bolt. The thing works great. It was/still is? in the micro fiche specific to authorities. The bolt has a nylon tip and a spring. There were two versions of the bolt, one taller than the other.
Has nothing to do with the switch assembly.
The control housing is held to the master cyl with two fasteners, one of which is a small cross head bolt that you can see by bending back the the hand grip rubber a bit. btw- at some point you may r-r the m-cyl. That bolt will be seized. The head strips easily Drill the head then remove the housing and the rest of the bolt comes right off.
To install the auth. control housing you need to remove the heater grip. It's hard to save the heater but there are techniques. You may wish to do this in conjunction with any handle bar upgrade.
It looks like you can drill the stock control housing but you need a two step hole. I would just try to find one in fm or the bay. If you keep at it you will locate one. Worth having. The bolt/thumb screw may be harder to find. They get damaged in tip-over.
vintagerider is offline   Reply With Quote
Old 11-13-2012, 02:43 PM   #7
biometrics
biometrics's Avatar
Oddometer: 141
Here is a good photo of the tip over style installed. I saw it on an RT parked near to where I work.
biometrics is offline   Reply With Quote
Old 11-14-2012, 11:28 AM   #8
sigpe57 OP
Oddometer: 340
What's right hand police switch's part number?
Times are GMT -7.   It's 08:40 AM.
