Old 11-13-2012, 03:28 PM   #1
Yousef OP
Oddometer: 8
Dimming headlight
I've been noticing my headlight would dim at a stop light but when I rev the engine a little it gets brighter. It also does it when I have my heated gear on. The Gerbings thermostat will blink since I have it turned down and my headlight will dim every time the thermostat blinks.
I'm about to install my DDM HID kit and not sure how it will deal with this.
I'm thinking my battery is the cause but I could be wrong.
Any ideas?
BMW R1200GS Adventure
KTM 450 SMR/MXC
Triumph Rocket III
Ducati 999s
Yousef is offline   Reply With Quote
Old 11-13-2012, 03:39 PM   #2
Karlxx
Dirt Curious
Karlxx's Avatar
Oddometer: 177
This is normal behaviour as the alternator is not able to produce as many watts at Idle speed. A tired battery will make this worse.
A HID will not fire up at all at low voltage, but once its going they tend to work OK at Idle.
K
2004 R1150GSA
2003 CBR1100XX
IBA 41759
Karlxx is offline   Reply With Quote
Old 11-13-2012, 07:05 PM   #3
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,613
That should be amps.
def is offline   Reply With Quote
Old 11-14-2012, 07:17 AM   #4
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,043
Doesn't amps = watts/volts? So, in effect the statement is still accurate?
Jim
Old 11-14-2012, 08:00 AM   #5
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,193
The term Watts covers it better as the voltage droops as well at low rpm.
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 11-14-2012, 08:12 AM   #6
def
def's Avatar
Oddometer: 10,613
So, you're gonna argue with an engineer? (my wife does all the time).
The Watt is a unit of work.
The volt is the force or EMF and the ampere is the unit of electrical current.
When the load consumes more current than the system is delivering (alternator), the battery supplies the difference. When this happens in the typical automotive electrical system, the voltage is reduced unless the alternator delivers more current (amperes) to offset the loss.
So, when the lights dim, it is due to more current (amperes) being called for than is being delivered.
def screwed with this post 11-14-2012 at 09:01 AM
Old 11-14-2012, 09:08 AM   #7
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,193
Don't start with the Engineer stuff. I work with them all the time. I am a certified Industrial Electrician.
Pissing contests achieve nothing.
The only way current will flow out of the alternator is if its output voltage is higher than the battery voltage.
So the term watts is not incorrect
Old 11-14-2012, 11:06 AM   #8
def
def's Avatar
Oddometer: 10,613
Not incorrect. Now your English is in question as well as your electrical knowledge.
Watts don't flow anywhere....current does.
And this is no contest...however, it is useful to use correct terminology and references when attempting to cite fact. That's how we learn, communicate and pass knowledge.
I understand the relationship between watts, volts and current. Also, our alternators are rated in both watts and amperes. However, in an automotive electrical system, the voltage is usually considered to be constant (and regulated electronically in the alternator) with load and current being the variable.
Remember also, current is the measure of coulombs, which are ampere seconds, or the measure of how many electrons flow in the circuit.
Old 11-14-2012, 11:28 AM   #9
Thunder Pig
Thunder Pig's Avatar
Oddometer: 258
How about just say demand exceeds supply and then the lights dim.
Ted VanR
12 R1200GS Rallye
06 KTM 525EXC
98 KTM 200EXC
99 Speed Triple, etc...
Thunder Pig is offline   Reply With Quote
Old 11-14-2012, 11:29 AM   #10
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,193
In the end it's either the the battery or the alternator doing the work depending on RPM.
Work = HP = Watts
I am not arguing anymore, and stop with the insults about my knowledge.
Old 11-14-2012, 11:31 AM   #11
jings
Oddometer: 268
jings is offline   Reply With Quote
Old 11-14-2012, 11:36 AM   #12
def
def's Avatar
Oddometer: 10,613
As usual, the pig get's it.
Old 11-14-2012, 12:50 PM   #13
Yousef OP
Oddometer: 8
Dang! What happened?
Ok, I'll install a new battery and see if it helps.
KTM 450 SMR/MXC
Triumph Rocket III
Ducati 999s
Old 11-14-2012, 12:53 PM   #14
RFK
Oddometer: 132
Generators are measured in wattage not amperage. The voltage can vary which will vary the amperage so wattage is a better term to use... it is constant.
RFK is offline   Reply With Quote
Old 11-14-2012, 12:55 PM   #15
picinisco
Scottish Transplant
picinisco's Avatar
Oddometer: 491
No idea what the 1965 riots in LA has to do with anything.
Cheers...John - 2004 BMW R1150GS, 1978 R100 (G/S Frankenbike)
Bikes That have Moved On:
1978 Suzuki GS550E, 1978 Kawasaki KZ1000P, 1982 Honda XL500R, 1995 BMW R1100RSL
picinisco is offline   Reply With Quote
Times are GMT -7.   It's 03:09 AM.
