Old 11-14-2012, 01:12 PM   #16
Karlxx
Dirt Curious
Karlxx's Avatar
Oddometer: 177
Wow, just trying to help here... I am also an engineer, albeit mechanical. I believe we are both correct, I just used watts in my description because I thought power output would be more easy to understand.
2004 R1150GSA
2003 CBR1100XX
IBA 41759
Karlxx is offline   Reply With Quote
Old 11-14-2012, 01:20 PM   #17
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,161
Originally Posted by RFK View Post
Generators are measured in wattage not amperage. The voltage can vary which will vary the amperage so wattage is a better term to use... it is constant.
My point precisely, thank you
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 11-14-2012, 01:35 PM   #18
MotorradMike
MIL-TFD-41
MotorradMike's Avatar
Oddometer: 1,018
Originally Posted by GS Addict View Post
Pissing contests achieve nothing.
Pissing contests are fun, no?
I say it's voltage that drops.
C'mon guys, voltage, current, and power are all down at low RPM.
Mike
So far, everything that has surprised me has been completely unexpected.
BMW R1100RS
MotorradMike is offline   Reply With Quote
Old 11-14-2012, 02:14 PM   #19
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,591
I am not arguing anymore, and stop with the insults about my knowledge.
Sorry. You're likely smarter than I.
def is offline   Reply With Quote
Old 11-14-2012, 02:19 PM   #20
LaurelPerryOnLand
Oddometer: 3,482
Bueller...Bueller...Rodney King...Rodney King!
LaurelPerryOnLand is offline   Reply With Quote
Old 11-14-2012, 03:07 PM   #21
def
def's Avatar
Oddometer: 10,591
Sorry, our motorcycles use alternators not generators.
And yes, generator nameplate capacity is usually stated in watts.
Visit your local power generating station and you'll see a big GE, Westinghouse or Allis-Chalmers machine generating the electric power you use at home.
Then, when you get home, look at your electric distribution panel in your house. What do those circuit breakers say on them?
Yes, that's rights.....
AMPS
Old 11-14-2012, 03:15 PM   #22
def
def's Avatar
Oddometer: 10,591
I believe you're right but it is fun to watch the thread turn esoteric and everybody wax intelligent. There are some smart folks on this site without a doubt.
Old 11-14-2012, 03:38 PM   #23
DirtDabber
cultural illiterate
DirtDabber's Avatar
Oddometer: 8,300
If you switch to synthetic oil the problem should correct itself....
I wonder where that road goes?
DirtDabber is online now   Reply With Quote
Old 11-14-2012, 03:41 PM   #24
LaurelPerryOnLand
Oddometer: 3,482
Originally Posted by picinisco View Post
No idea what the 1965 riots in LA has to do with anything.
You just need to stay up on CURRENT events!
Old 11-14-2012, 07:31 PM   #25
nbk3
Oddometer: 6
now, for a newbie on this site, i must ask..... WATTS going on?
nbk3 is offline   Reply With Quote
Old 11-14-2012, 07:45 PM   #26
LaurelPerryOnLand
Oddometer: 3,482
I have no idea...I'd better ask my GR...AMPs!
Old 11-14-2012, 07:53 PM   #27
def
def's Avatar
Oddometer: 10,591
See? We're havin' fun now!
Old 11-14-2012, 08:01 PM   #28
def
def's Avatar
Oddometer: 10,591
Originally Posted by Yousef View Post
I've been noticing my headlight would dim at a stop light but when I rev the engine a little it gets brighter. It also does it when I have my heated gear on. The Gerbings thermostat will blink since I have it turned down and my headlight will dim every time the thermostat blinks.
I'm about to install my DDM HID kit and not sure how it will deal with this.
I'm thinking my battery is the cause but I could be wrong.
Any ideas?
Yes....some things to check;
1- Total the current demands of everything that is drawing current or consuming electrical power (watts) on the motorcycle.
2- Check your grounds and battery connections making sure they are clean and secure.
3- If you're concerned about an HID installation, remember when starting the engine, eliminate all external power consumption before starting the engine and cold striking the HID lights.
4- I would remove the battery and have it load tested by a reputable shop. Replace if necessary with a quality AGM battery of the highest Ahr rating that will fit your bike.
Old 11-15-2012, 01:58 AM   #29
nbk3
Oddometer: 6
yeah, while u're at it, could you ask if he would like some OHM-lettes??
Old 11-15-2012, 05:16 AM   #30
MotorradMike
MIL-TFD-41
Oddometer: 1,018
All alternators are generators but not all generators are alternators.
AMPS.
Circuit breakers are marked in Amps because they trip on overcurrent, not excess power.
Just sayin'
Mike
BMW R1100RS
Times are GMT -7.   It's 06:27 AM.
