Old 11-13-2012, 05:38 PM   #1
'Flagger OP
..this space for rent..
'Flagger's Avatar
Oddometer: 2,349
F800GS Sidestand Spring
Mine went missing after a day off-road in the Wayne National Forest (OH). BMW wants $23 for a replacement.
Anyone have a spare laying around? Or willing to provide some suitable measurements so that I may find a substitute?
Thx in advance!
- B
Proud to be an inmate of AdvRider.
'Flagger is offline   Reply With Quote
Old 11-14-2012, 06:43 AM   #2
JRWooden
Oddometer: 4,249
Wow...
That spring is kinda a bitch to get off I'm not sure how you lost it...
I had to use my brake pliers ....
My bike is 2009 F658GS the spring is actually two-springs and the coils are are interleaved/interwound...
I've never seen another one like it ... bless you BMW
But a good auto parts store may have something that will work ...
beefy clutch arm return spring or maybe a drum brake spring
or maybe http://www.mcmaster.com
length from inside of the "hook" to inside of other hook is 5.25" when "relaxed" (off the bike)
Outside diameter is ~0.60"
wire diameter is ~0.082
then it has a piece of thin plastic/rubber tubing over it to keep it from banging around....
Since you'll be unlikely to find a "double" spring replacement ...
I'd probably go with something that has the same outside diameter as stock,
with same or heavier wire gauge and working length that was maybe a little shorter than 5.25"
JRWooden screwed with this post 11-14-2012 at 09:45 AM
Old 11-14-2012, 06:53 AM   #3
bmwroadsterca
RadioFlyer
Oddometer: 130
Two Springs
The two spring arrangement is a safety feature. If one spring breaks the other will keep the sidestand retracted. Having a sidestand flopping around while riding is not so good.
mike
bmwroadsterca is offline   Reply With Quote
Old 11-14-2012, 09:45 AM   #4
JRWooden
Oddometer: 4,249
mike
I had not thought of that ... thanks!
It's especially not goo when you have a kickstand engine-cutout switch
Old 11-14-2012, 10:40 AM   #5
FredRydr
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 2,458
Length is only one aspect if you want aftermarket. Don't forget tension, which is what makes it a bitch to remove.
Fred
FredRydr is offline   Reply With Quote
Old 11-14-2012, 02:32 PM   #6
JRWooden
Oddometer: 4,249
Fred
It would be a PITA to remove without my trusty pair of brake pliers ...
wire diameter and free length was as close as I could come to tension without a trusty spring tester.
One other key dimension ... the free length at the ends is about 7/8" long ....
$23 is starting to sound "less bad"
Old 11-14-2012, 02:44 PM   #7
'Flagger OP
'Flagger's Avatar
Oddometer: 2,349
I'm beginning to agree. But I'm still hopeful that there is an extra one laying about somewhere.
Anyone?
- B
Times are GMT -7.   It's 01:29 PM.
