Old 11-14-2012, 02:58 PM   #1
mjfields_228 OP
mjfields_228's Avatar
Oddometer: 420
TraX 45L Pannier Leaking after dirt nap
I installed TraX Panniers on my GSA as soon as I bought it. Rode in tons and tons of rain and never had any water intrusion issues.
Finally did some off-roading in Sept and had a lower speed layover with the bike fully loaded.
Of course the case got all scratched and deformed and now has a few leak paths, which is unavoidable given its design.
My question is has anyone successfully used silicone sealant to stop the leaks in their leaky TraX boxes?
Or is it a lost cause at this point and simply use the plastic liners provided to help keep my SheeIt dry?
Present Bikes:
2015 Triumph Street Triple R -- Matte Black
2013 Ducati Multistrada -- Red
2011 Triumph Speed Triple -- Black
mjfields_228 is offline   Reply With Quote
Old 11-15-2012, 05:19 PM   #2
mudmullet
mudmullet's Avatar
Oddometer: 196
Are you trying to patch a hole or seal a gap between the lid and the body because of the deformation?
If the latter, I'd try to rack the box back straight-ish and get some closed cell foam weatherstripping. Cheap, replaceable, and easy to do neatly if you get some black and attach it to the lid. A little rubber cement will glue the ends together nicely without interfering with the seal.
mudmullet screwed with this post 11-15-2012 at 05:24 PM
mudmullet is offline   Reply With Quote
Old 11-15-2012, 07:00 PM   #3
mjfields_228 OP
Oddometer: 420
[QUOTE=mudmullet;20053554]Are you trying to patch a hole or seal a gap between the lid and the body because of the deformation?
It's the riveted seams that have separated along the bottom to side interface. The lid is still square and seems to seal good. I hit it with a hose for over a minute full nozzle in all directions around the lid seal and detected no intrusion.
But when I hit the messed up seams and the corners (under the plastic corner molding) water gets in.
Was looking to the forum to see if anyone has used silicone sealant successfully around all of the joints.
Present Bikes:
Old 11-15-2012, 07:59 PM   #4
mudmullet
mudmullet's Avatar
Oddometer: 196
My experience with silicone is that it doesn't adhere very well. It'll plug a hole ok, but a little movement (another crash or some thermal expansion) and it separates from its base. Don Casey is a sailboat repair guru. Here's a writeup for different sealants that might give you something to ponder. EDIT: oh, yeah, if you go with something like this, run some masking tape on both sides of the joint you want to seal and after you've worked the stuff into the crack, remove the tape for a nice clean line.
Times are GMT -7.   It's 12:46 AM.
