Old 11-15-2012, 04:02 AM   #1
wyrtyr2 OP
Oddometer: 2
Eastern Beaver fuse block
I think my BMW canbus trickle charger is shot. Would running a SAE 2 prong plug though one of open circuits on my Eastern Beaver fuse block and using a non CanBus style battery maintainer work? Or does the fuse block prevent current from running towards the battery? The technical aspects of winter...
wyrtyr2 is offline   Reply With Quote
Old 11-15-2012, 05:51 AM   #2
TuefelHunden
TuefelHunden's Avatar
Oddometer: 600
That would work. Just wire it to the unswitched connectors which would go directly to the battery.
I run an FZ1, similar but not quite so heavy duty as the Eastern Beaver. When putting it in I cut the under seat BMW power plug lead and connected it to an unswitched tap. I've made several pig tails to which all plug into the BMW (Powerlet) plug. One is SAE, one is a cigarette connector, another is a barrel connector to my heated gear. Since I can't think of when I'll be running my tire compressor, charger and heated gear all at the same time, it cuts down on the number of wires I have running around.
Old, but not Dead
TuefelHunden is offline   Reply With Quote
Old 11-15-2012, 05:52 AM   #3
WoodButcher
WoodButcher's Avatar
Oddometer: 2,089
Works on my bike just fine.
Rusty
2009 BMW R1200GS Adventure
WoodButcher is offline   Reply With Quote
Old 11-15-2012, 06:20 AM   #4
SpeedySteve
SpeedySteve's Avatar
Oddometer: 123
SAE 2 prong works fine for me through my EB as well. I have powered my tankbag through powerlet components (which use an SAE cable as power-in). When on, the SAE cable is powering the tankbag. When not, i just have it velcro-ed to the middle of the handbars. I have it running through unswitched fuzed with a 7amp. I also run my slime pump on this SEA cable. 7 amp seems to be adequate!
2012 BMW GSA - yeehaw! 5 years of drooling, finally did it.
2003 SV650s
SpeedySteve is offline   Reply With Quote
Old 11-15-2012, 06:24 AM   #5
El Gato
El Gato's Avatar
Oddometer: 772
Same here. No problems running my Optimate charger through an unswitched port on the the EB.
El Gato is offline   Reply With Quote
Old 11-15-2012, 01:55 PM   #6
solohvs
somewhere around the bend
solohvs's Avatar
Oddometer: 182
Good Stuff
The Eastern Beaver stuff is fantastic.
The last few bikes I owned all had a couple products from EB and I never had a problem with any of it.
Good Stuff.
solohvs is offline   Reply With Quote
Times are GMT -7.   It's 02:32 AM.
