11-15-2012, 07:56 AM
#1 |
Oddometer: 60
LED turn signal problem
I recently installed LED turn markers on an 06 klr. Put the rears on first to see if i liked em. Like em. So with oem fronts and led rears needed to install new electronic relay. All was fine. Install same led set up in front and anger the moto elves. I now have four way fashers....grrr. I have checked connections and ground with no luck. Any suggestions ? Yes i know its a KLR but i had worse issues with my KTM
busmonkey screwed with this post 11-15-2012 at 07:57 AM Reason: spellin |
11-15-2012, 09:48 AM
#2 |
Oddometer: 235
do some googling, you don't have enough resistance in the system for the turns to work properly. this issue is very well documented.
I buy all my stuff at motorcyclegear.com, formerly newenough. |
11-15-2012, 10:04 AM
#3 |
The Spoad Warrior
Oddometer: 2,266
do you have a single dash light for the signals? if so, that's it. you can google and fix, or just pull the indicator light
11-15-2012, 03:42 PM
#4 |
If you want to maintain a dash indicator for your signals... you just need one of these:
http://www.kuryakyn.com/Products/719/Diode-Kit Either that, or just go to Radio Shack and pick up a package of misc diodes and solder up your own. |
11-15-2012, 03:55 PM
#5 |
Airventurer
Oddometer: 394
11-16-2012, 05:31 PM
#6 |
Oddometer: 60
Thanks all Installed diodes, problem solved.
12-10-2012, 02:05 PM
#7 |
night owl
Oddometer: 132
do you have to install diodes inline of each led or just the indicator light. I went led's all around and ended up just unplugging the indicator light.
12-11-2012, 06:14 PM
#8 |
Just inline with each of the leads to the indicator light itself. That way current won't bleed through to the left when you signal right and vice versa.
12-12-2012, 03:58 PM
#9 |
night owl
Oddometer: 132
I did leds all around and took out the indicator light, if i did the diode thing just for the indicator light would they still wig out?
12-12-2012, 11:50 PM
#10 |
Nope, diodes in line with each of the positive leads going to the indicator will prevent them from wigging out.
The only additional thing you have to do is join the two positive leads into a Y (AFTER the diodes) and then tap into a ground in the cluster behind the headlight to connect to the opposite lead on the indicator. |
