Old 01-20-2015, 05:17 PM   #1
xurxo OP
Oddometer: 3
Engine noise R 1150 GS Adventure
Hy mates
Few days ago I realised that my R 1150 GS engine doesn't work properly.
In this video you can see what I mean:
https://www.youtube.com/watch?v=wyYtodO5-G4
It seems to come from distribution group.
At first I have changed oil and oil filter. I filtered the oil with a piece of cloth looking for any piece of plastic that could show me any problem with the slide rail.
This is what I found (of course the coin was not inside ):
[IMGhttp://i.imgur.com/LMqHAIz.jpg[/IMG]
As you can see, is not any piece of plastic in it.
After that I checked both chain tensioners looking for any damage in them.
Left tensioner is the first model changed at 2007. I will change it this weekend.
The right tensioner has some scratches and I don't know if is normal or not. You can see them here:
if you have any suggestion about what can be, will help me.
Thanks and sorry for my English
xurxo is offline   Reply With Quote
Old 01-20-2015, 06:43 PM   #2
Mr.JAJA
Mr.JAJA's Avatar
Oddometer: 686
If you
still have the original Muffler on, than this sounds NASTY. Turn it off.
Is hard to hear but it sound like a loose sparkplug or some mechanical from the inside.
Mr.JAJA
Mr.JAJA is offline   Reply With Quote
Old 01-20-2015, 07:10 PM   #3
jsb223
ADV Rookie
jsb223's Avatar
Oddometer: 1,252
Does it make the same sound with the clutch pulled in?
If it were me I would pull the valve covers and make sure
everything is in it's place and moves properly when the engine
is rotated.
Then pull the plugs and do and inspection of the piston top and
cylinder walls with a bore camera.
R1150GSA
DRZ400S
DRZ400E
jsb223 is offline   Reply With Quote
Old 01-20-2015, 07:36 PM   #4
YesRush
YesRush's Avatar
Oddometer: 502
Is your valve gap big.Sounds way loose.15mm&30mm.
Do a Video in the day light.
It could be a push rod making that noise also.The ends separate and make the noise.
http://m.youtube.com/watch?v=pRXeaequvzk
YesRush screwed with this post 01-20-2015 at 07:52 PM
YesRush is offline   Reply With Quote
Old 01-20-2015, 09:51 PM   #5
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,806
Due to the inadequate lighting in your video, it is not possible to determine the sound source visually. Also no mileage reported.
I vote for TB shaft/bushing worn out. Repairable.
I'm now so old I forgot my last birthday. Does this make me younger?
def is offline   Reply With Quote
Old 01-21-2015, 07:13 AM   #6
xurxo OP
Oddometer: 3
A person in a Spanish forum said that scratches on right tensioner indicates it becomes stiff with temperature. I'm going to change it this weekend and see what happend.You will know it soon
Thanks for your help. Sorry for the quality of video.
Old 01-21-2015, 11:36 AM   #7
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,591
If you're going to include critical specifications and want to sound like you know what you are talking about, please re-read what you type to make sure you get it right. Most people probably know what you mean, but some might take your numbers literally and potentially ruin their engine (even though it would be physically impossible to open the valve lash that far). 15mm is over a half inch and 30mm is over an inch...
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance screwed with this post 01-21-2015 at 11:41 AM
FatChance is offline   Reply With Quote
Old 01-21-2015, 11:57 AM   #8
Mr.JAJA
Mr.JAJA's Avatar
Oddometer: 686
Question loud noise
You are right, but this is what the motor sounds like: 15mm and 30mm valve gap. and anything between.
Don't come back and tell me thats not possible. I know that
Mr.JAJA
Old 01-21-2015, 11:59 AM   #9
YesRush
YesRush's Avatar
Oddometer: 502
Thumb
Maybe I should use thousand'th .oooo like I normally do.
Old 01-21-2015, 12:05 PM   #10
Mr.JAJA
Mr.JAJA's Avatar
Oddometer: 686
no its a METRIC BIKE
0.15mm and 0.30mm is fine, but i think everyone understand what you try to say, I did.
Mr.JAJA
Old 01-21-2015, 04:08 PM   #11
Sniperx
Oddometer: 504
Why do the headers look blue? They really that hot? I've idled for a length of time before and I didn't get anything like that.
Motorcycles are like chlorine for the gene pool. 8/31/2013
Sniperx is offline   Reply With Quote
Old 01-22-2015, 03:41 PM   #12
xurxo OP
Oddometer: 3
I don't know why that happends. Was only in the video, when I was recording it I didn't see any glow blue in them
Old 01-22-2015, 06:37 PM   #13
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,197
Quick easy check
I had a poly vee belt start to shred once and it sounded just like your video.
About a 3" tail came off the side and was wapping on the inside of the plastic cover.
Sounded like it was inside the engine.
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Old 01-23-2015, 03:14 PM   #14
def
def's Avatar
Oddometer: 10,806
Maybe a yard stick was used to adjust valve lash?
Agreed, I try to review and correct what I am about to post 'cause I don't want Jetspeed to think I'm just a dopey, white-hat sailor while he is entrusted with a multi-million-dollar military (US Navy...they're the best) aircraft. Some say he is the best pilot on the West Coast however, I have yet to see him fly his helicopter upside down (I think he's done it though...just not around the base CO).
Old 01-23-2015, 03:16 PM   #15
def
def's Avatar
Oddometer: 10,806
Sorry, four zeros to the right of the decimal would be ten thousandths.
Times are GMT -7.   It's 12:18 AM.
