Old 11-15-2012, 09:23 PM   #1
lqgsrider OP
LQDesert Rider
lqgsrider's Avatar
Oddometer: 370
Headlight Adj. '04 GSA
I recently finished HID install and need to adjust the low beam. Any suggestions on best method?
lqgsrider is offline   Reply With Quote
Old 11-15-2012, 09:26 PM   #2
BluByU
BluByU's Avatar
Oddometer: 497
Seriously I am not trying to sound like an ass hole,
try using a screw driver on the adjustment screws (look around the edges of the headlights) I believe the center lower one is for height of both high & low beams.
BluByU is offline   Reply With Quote
Old 11-15-2012, 09:40 PM   #3
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 3,867
Motorcycle on level surface.
Rider’s weight on motorcycle
(approx. 85 kg/176 lbs).
Move swivel lever to horizontal position (basic
setting).
Turn the adjusting screws to correct the head-
light beam throw.
Lateral adjustment:
........................ Adjusting screw on left of headlight
Vertical adjustment:
......................Adjusting screw on right of headlight
Turn screw anti-clockwise:............... longer throw
Turn screw clockwise: ..................... shorter throw
Setting for headlight beam angle adjuster
.................................................. .. -15 cm (- 5.9 in)
.......................... . over a distance of 10 m (32.8 ft)
Old enough to know better....
Young enough to try it again
GS Addict is online now   Reply With Quote
Old 11-18-2012, 09:12 PM   #4
lqgsrider OP
LQDesert Rider
lqgsrider's Avatar
Oddometer: 370
thanks
Times are GMT -7.   It's 06:13 PM.
