Old 11-20-2012, 05:58 PM   #16
JRWooden
Oddometer: 4,293
Ok ... let's see if I can combine the continuation of the hi-jack at the same time I try to be helpful:
On the headlight ... yeah I've only used 55W OEM/equal bulbs and my reflector is hosed.
At the 3-year mark on the warranty I got a shrug and a "it's not bad enough that I can get anything done" ...
I'll be looking for a wrecked unit with good reflector, but wonder it it's worth the effort ... but ...
Like Reaver I'm cheap enough to try and it's not an urgent matter for me yet.
K4L: If you get any satisfaction with the rep. please let us know!
Ok ... now getting back to grips..............
I would either temporarily or permanently mount a voltage indicator to the bike....
and see if voltage drops under use... sometimes stators will short intermittently due to heat or whatever.........
your could either rig up a $3 Harbor Freight voltmeter for a while and watch it, or put in a permanent monitor.
Here's the one I used:
http://f800riders.org/forum/showthre...mp-GPS-adapter
If it is really BOTH grips I find it hard to beleive that both of the heating elements actually have shorts but for reference here is the repair article: http://www.advrider.com/forums/showthread.php?t=770662
Sometimes when very cold it seems like the left grip on my bike is not working, but then I realize that's the hand I take off the grip to dink with my helmet or visor, use the clutch, or whatever and that lets the grip cool down ... as it gets a cold air blast........
Old 11-20-2012, 06:24 PM   #17
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,269
Yeahhhhh............No.
The left grip is snug to the handlebar (heatsink) and gets to warm up the whole thing. The right grip is somewhat isolated (insulated) on a plastic carrier for the throttle operation and retains more heat.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 11-20-2012, 08:59 PM   #18
JRWooden
Oddometer: 4,293
I have the foam grip-puppies which makes it worse in terms of heat transfer rate .........
Edit:
I have a dead left grip in the garage and just dug it out of the box ...
the plastic "mounting sleeve" under the heater element is almost 3/16" thick, so there is some insulation value ...
JRWooden screwed with this post 11-21-2012 at 05:39 AM
Old 11-21-2012, 08:19 AM   #19
h2only OP
Oddometer: 31
thanks, I will give that a shot.
h2only is offline   Reply With Quote
Old 11-21-2012, 07:12 PM   #20
guzzimike
guzzimike's Avatar
Oddometer: 1,403
ts the ABS working OK?
There seems to be some correlation between two.
Armageddon Was Yesterday, Today We Have a Problem
East is East & West is West 2008
http://www.advrider.com/forums/ad.php?t=400050
A Long Weekend 2009
http://www.advrider.com/forums/showthread.php?t=523893
All the Way to Nowhere & Back Again. 2010
http://www.advrider.com/forums/showthread.php?t=619683
Save 5 bucks on your Smugmug, use my discount code
hQo9Atub1N9jg
guzzimike is offline   Reply With Quote
Times are GMT -7.   It's 05:53 PM.
