Old 11-16-2012, 08:54 AM   #1
EXRM193 OP
EXRM193's Avatar
Oddometer: 131
Heated clothing..my battery can't cope....now what?.
2008 Honda XR650L. I went for a cold ride at the weekend to test out a Gerbing heated jacket and heated gloves. After about 150 miles, I stopped for fuel and the battery was totally drained. It bump started ok and I rode the rest of the weekend without heated clothing.
So my question is what do I need to do to get the heated clothing running ok and the battery charging ok at the same time?
I presume upgrade the alternator,but I don't want to toast the battery if I'm not using the heated stuff.
Any ideas?
EXRM193 is offline   Reply With Quote
Old 11-16-2012, 09:05 AM   #2
sieg
sieg's Avatar
Oddometer: 2,855
I used full set of Gerbings on my '95 XR650L. You need to keep the RPM up or turn the controller down. On the highway it's ok, but in town or back roads run a lower gear to keep it cranking. And turn them of several minutes before killing the engine, if you know ahead of time where you are stopping. Rewound stator would be the right way to do it but I got by for years. Lucky you can bump start it so you won't be stranded.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 11-16-2012, 09:12 AM   #3
Jnich77
Jnich77's Avatar
Oddometer: 696
Replace all your bulbs with LED's
HID kit for your headlight (they draw less power)
Turn it off before you stop and turn it off when you you are at a stop light.
Jnich77 is offline   Reply With Quote
Old 11-16-2012, 09:24 AM   #4
8gv
Oddometer: 2,488
Pellet stove?
8gv is offline   Reply With Quote
Old 11-16-2012, 09:32 AM   #5
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,254
Any ideas?
For daytime use rig a switch to turn off your headlight and you should have no issues... The headlight will draw 60 Watts so with that gone your stator should be able to keep up the battery enough when running the 90-100 W jacket..
gunnerbuck screwed with this post 11-16-2012 at 04:19 PM
gunnerbuck is offline   Reply With Quote
Old 11-16-2012, 09:36 AM   #6
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 9,093
Do XR headlight turn off? My XL600 doesn't have that option.
The Ricky Stator is probably the best long term solution, assuming they make them for that year.
High Country Herb is offline   Reply With Quote
Old 11-16-2012, 09:45 AM   #7
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,254
No, there is not a headlight switch that is why you need to rig one to make a cheap solution...
Agreed, the RS high output stator would be best... The stock XRL has a pretty low output stator which does not leave much extra juice above the basic operation requirement of the ignition, instruments and lighting...
Old 11-16-2012, 10:17 AM   #8
OldPete
Be aware
OldPete's Avatar
Oddometer: 5,322
180w @ 5k rpm and that's why the 650 Terra is a big deal @ 400w.
http://www.advrider.com/forums/showthread.php?t=421796
some install a parking bulb in the headlight shell for day time running.
OldPete is offline   Reply With Quote
Old 11-16-2012, 10:19 AM   #9
NHADV
NHADV's Avatar
Oddometer: 554
I use the on/off switch and turn it off when coming to a stop. When the bike is going to be shut off for a while after extended use I will shut the heat off about ten miles before arriving at my destination so that the battery can recover before shut off.
-Gary
NHADV is offline   Reply With Quote
Old 11-16-2012, 12:02 PM   #10
Beezer
Oddometer: 5,855
buy a KLR?
you can try cycling between on & the other so both don't run at the same time. there may even be a premade box that does that
Beezer is offline   Reply With Quote
Old 11-16-2012, 12:31 PM   #11
EXRM193 OP
EXRM193's Avatar
Oddometer: 131
Better sister in whorehouse than brother on Kawasaki
Old 11-16-2012, 12:40 PM   #12
DaveStockwell
Rock Fodder
Oddometer: 205
An upgraded alternator won't toast the battery of you have the right regulator.
"Yes. It looks insubordinate, but it isn't really." - T.E. Lawrence
DaveStockwell is offline   Reply With Quote
Old 11-16-2012, 12:46 PM   #13
kirkster70
moto junkie
kirkster70's Avatar
Oddometer: 1,905
As previously said, turn the controller back or off completely while stopped in traffic.
Don't crank it back up until you're rolling 50mph or better.
It helps to also wire a Battery Tender plug so you can plug in when not riding.
I ran a Gerbing's jacket liner, Gerbing's socks, and Gerbings gloves on an '08 XRL with zero issues.
I used to put ammeters on all bikes to keep track of the voltage. It's not really needed, but I was just curious. All you really need to do is turn it down or off at low/no speed and you will be just fine.
kirkster70 is offline   Reply With Quote
Old 11-16-2012, 01:27 PM   #14
Tammy
Team 2nd Wind
Tammy's Avatar
Oddometer: 1,460
I used a relay to turn it off at a stop light i also used a timer with the relay to power it back after 2min after the brake light went out.
easy to make a 555 chip will get ya there...
hid headligh and LEDs will help a lot to.
08 WR250F
07 G650 X Challenge
Bergen Co, NJ
AMA / CJCR / ECEA
In a world that what we want is only what we want until it's ours
Tammy is offline   Reply With Quote
Old 11-16-2012, 01:57 PM   #15
EXRM193 OP
EXRM193's Avatar
Oddometer: 131
Thanks.
The rear light is already LED. I don't fancy riding without a front light. Car drivers over here are just as blind as your side of the pond. I may invest in the Gerbing controller. At the moment, both the jacket and gloves are either on or off. Turning it down to a trickle may help.
Times are GMT -7.   It's 04:05 PM.
