Old 11-16-2012, 02:15 PM   #16
strongbad
Oddometer: 483
Install a voltmeter so you can monitor your charging system's output. If charge voltage falls below ~12.9V you need to turn off or turn down external loads.
strongbad is offline   Reply With Quote
Old 11-16-2012, 02:21 PM   #17
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,849
switch to turn off your headlight during the day
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins is online now   Reply With Quote
Old 11-16-2012, 02:57 PM   #18
crypto666
Oddometer: 1,277
Go faster.
crypto666 is offline   Reply With Quote
Old 11-16-2012, 03:26 PM   #19
Kommando
Kommando's Avatar
Oddometer: 7,378
LED lights can help. Just make sure they're low-draw. I've seen LED tail/brake lights that used almost as much wattage as the stock incandescent light. If you have LED marker/signal lights, use a no-load flasher unit, rather than using resistors. Remember to replace any small incandescent bulbs too (dash, license plate, etc.).
The beefed stator that was mentioned can help too.
Some people are also swapping a MOSFET reg/rect from a Honda CBR onto their bikes. These are typically more efficient than many other OEM reg/rect units.
A heat-troller can make your heated gear more efficient too, and allow you to better control what garment gets more or less heat when you need it or don't.
A headlight switch may or may not be legal where you ride. An HID or 35W/55W setup might be though. A more-efficient bulb could save you 20W at just your headlight. A switch could save you 55W.
Incorporate a light wicking layer, an insulating layer, and a windproof/waterproof layer into your riding gear. You may not even need heated gear. I never have, and I commuted in Chicago winters when temps were WELL below freezing.
Kommando is offline   Reply With Quote
Old 11-16-2012, 04:15 PM   #20
Grinnin
Forever N00b
Oddometer: 2,779
A volt display so you can see when it's OK and when it's not.
I've used my heated jacket with a flasher relay to give an approximate 50% duty cycle. It's not the toasty goodness that a full-power jacket is, but it works on one of my smaller bikes.
"The belief that there is only one truth, and that oneself is in possession of it, is the root of all evil in the world."-- Max Born, Nobel Physicist
Grinnin is offline   Reply With Quote
Old 11-16-2012, 05:47 PM   #21
Speedo66
Transient
Oddometer: 6,783
I run a gerbings jacket liner and gloves on an XT225 which also has a pretty dismal electrical output.
Things I've done are:
Wiring in a switch for the headlight. I run high beam during the day, so I just found the wire going to the high beam, cut it, and ran wires from each end to a switch on the handlebars. Turn it off before you try starting. 60 watts
I removed the wires for the front turn signal running lights, figured I didn't need them. 16 watts
LED tail light bulb. 5 watts
As previously stated, turn off all heated gear several miles before you stop to let the battery recharge.
I also installed a kick start kit.
A little planning required, but worth being able to ride all winter.
Good luck!
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 11-16-2012, 09:45 PM   #22
Walterxr650l
Walterxr650l's Avatar
Oddometer: 1,262
If one is only going to use this switch when starting, there would be no point on the XRL. Honda took care of that in the staring circuit. Press the starter button and the headlight shuts off.
Walter
"How much a dunce
That has been set to roam
Excels a dunce
That has stayed at home."
Walterxr650l is offline   Reply With Quote
Old 11-17-2012, 03:48 AM   #23
rjsurfer
Oddometer: 207
My DRZ's stator outputs just a bit more than your's, 200 watts or so.
I run a heated jacket and gloves with a total draw of 90 watts with no problem but I have made many of the mods that people have recommended here.
Voltmeter, HID headlight, LED tail/brakelight plus I run 12 gauge wires direct from the regulator output to the battery bypassing a few connectors and factory 16 gauge wiring.
I also shut down the heated gear 5 minutes before destination.
If I ever do run into trouble I'll go for the $200 kick start option.
Good luck.
Ron W.
DRZ 400SM
DL-650 Gone but not forgotten
rjsurfer is offline   Reply With Quote
Old 11-17-2012, 06:26 PM   #24
bmwktmbill
Traveler
Oddometer: 5,153
EX,
Sell the jacket and gloves and buy a vest from Aerostich, the cheap one
http://www.aerostich.com/clothing/he...tric-vest.html
and use grip heaters.
Less amps and more control
Buy quality insulated gloves with thin palms, look at bicycle 3 finger gloves... and for your torso use a silkweight underware top then the vest, then a quality insulated down or syn short jacket, then your riding jacket.
You are doing things backwards. Get the heat next to your body.
Loose the heat troller, it will just break and run the plug direct to the vest.
Then all the other stuff but buy a Buff neck warmer
http://www.buffusa.com/sports/collec...FQqe4Aod2gcALA
Stop every 50 miles and get a warm drink or carry one.
And that short windshield you were considering...good idea(or head south).
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill screwed with this post 11-17-2012 at 06:34 PM
bmwktmbill is offline   Reply With Quote
Old 11-18-2012, 03:31 AM   #25
rjsurfer
Oddometer: 207
The original Buf is great but don't waste your money, do yourself a favor and get the get the Polar Buf.
The last third of the fabric is fleece and the entire roll is longer so you can really seal up the bottom of your helmet from the wind and have enough material to act as a balaclava and still pull a section over your mouth and nose.
Ron W.
DRZ 400SM
Times are GMT -7.   It's 11:36 PM.
