Old 06-09-2013, 07:44 PM   #286
woodly1069
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,966
I think you can add a n insert like a large helicoil if I remember correctly. Then get the locks!
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is offline   Reply With Quote
Old 06-10-2013, 12:16 PM   #287
danedg
Horizontally Opposed
Oddometer: 6,686
Harper's Moto Guzzi sells a thread repair kit. Check it out.
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic
danedg is online now   Reply With Quote
Old 06-10-2013, 01:19 PM   #288
England-Kev OP
Oddometer: 3,643
I did, they don't have any, item is on backorder?
England-Kev is offline   Reply With Quote
Old 06-10-2013, 01:45 PM   #289
chris a
Oddometer: 106
Pretty sure that other suppliers would have it Kev...try Gutsibits in UK , Stein Dinse (germany ) TLM holland etc...
Lovely bike by the way !!!!!!!
chris a is offline   Reply With Quote
Old 06-11-2013, 12:13 AM   #290
BubbaJim
BubbaJim's Avatar
Oddometer: 47
Head Repair
Hi Kev,
http://cylinderheadshop.com/ I've got triumph heads done by The Cylinder Head Shop and can safely say his work is second to none! Not cheap but you pay for what you get. Maybe worth a try.
Jim......
"Where did you get your good judgement?
From my experience.
And where did you get your experience?
From my bad judgement."
BubbaJim is offline   Reply With Quote
Old 06-11-2013, 09:08 AM   #291
England-Kev OP
Oddometer: 3,643
I now have all my tell tale lights working, the new lamp holders arrived, and are now all fitted and wired in. Perfect. that is another of th small jobs done.
Old 06-11-2013, 10:50 AM   #292
England-Kev OP
Oddometer: 3,643
Tappet Clearance
Tappet Clearance, who is right?
The Official Guzzi Workshop Manual... V700 & V750
Still on COLD ENGINE make the final adjustment
of tappet clearance. Correct clearance Is 0.10
mm. (.0039") to inlet and 0.20 rnm. (.0078") to
exhaust.
Chilton (1973)
The inlet valves should be
set at 0.15 mm (0.0059 in.), and the exhaust
valves should be set at 0.25 mm
(0.0098 in.). If adjusted proper~y, the feeler
gauge should be able to be withdrawn
freely with a slight tugging pressure.
Old 06-11-2013, 12:17 PM   #293
danedg
Oddometer: 6,686
From the Riders Handbook
That is such an odd picture...look at the cables streaking straight up into the sky!!!
danedg screwed with this post 06-11-2013 at 02:35 PM
Old 06-11-2013, 02:54 PM   #294
davebeef
Buffoon
davebeef's Avatar
Oddometer: 261
Maybe they are a little excited.
'70 Moto Guzzi Ambassador, '78 FLH Shovelhead
'81 BMW R100, '79 MZ 250/1, '81 MZ 250/1
davebeef is offline   Reply With Quote
Old 06-11-2013, 04:53 PM   #295
nick949eldo
Oddometer: 1,026
Valve clearances
Noisy valves are happy valves! (within reason, of course)
Nick
Beyond the Coffee Shop: Riding 1970's Moto Guzzis in Northern Canada (Kindle Book) Buy it - it's cheap and good! All my adventures and disasters in one place.
nick949eldo is offline   Reply With Quote
Old 06-11-2013, 05:15 PM   #296
danedg
Oddometer: 6,686
Loud Valves Save Lives!
Old 06-11-2013, 06:16 PM   #297
MZRider
Neo-Luddite
Oddometer: 721
exhaust.
Chilton (1973)
Only the very early V700s (which had a different cam than later bikes) used the .10 mm and .20 mm clearances. For all others the factory recommended clearance (and what I use) is .006" and .010".
Charlie
http://www.AntietamClassicCycle.com
'69 Guzzi Ambassador,'77 Yamaha XT500,
'88 Ducati Paso, '91 ATK 604
'94 MZ Silver Star, '96 CCM 350
MZRider is offline   Reply With Quote
Old 06-12-2013, 02:52 PM   #298
davebeef
Buffoon
davebeef's Avatar
Oddometer: 261
Loud valves?? You should hear my bloody Trident!!
Dave.
davebeef screwed with this post 06-13-2013 at 10:34 AM
Old 06-13-2013, 05:21 AM   #299
woodly1069
woodly1069's Avatar
Oddometer: 1,966
Yep. I've always heard clappy valves are happy valves!
Old 06-14-2013, 06:50 PM   #300
nick949eldo
Oddometer: 1,026
Head Work
New valve guides, exhaust valves, springs, skimmed heads, deglazed. The old girl should stop acting like the Exxon Valdez and be good for another 41 years.
I glued her all back together and to my astonishment, she started right up and purrs just like an Italian lady of a certain age should.
Nick
Times are GMT -7.   It's 12:52 PM.
