Old 07-24-2013, 03:53 AM   #391
danedg
Horizontally Opposed
Oddometer: 6,683
Originally Posted by MZRider View Post
Something ain't right then...
Sorry, I exaggerated. I occasionally will get rough running and and a soft backfire until warm. But it is cold starting...
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic
danedg is online now   Reply With Quote
Old 07-24-2013, 06:30 AM   #392
F_Sahms
mostly paved
F_Sahms's Avatar
Oddometer: 361
Originally Posted by joe cool View Post
F Sahms,
How is that 1000s coming along?
Stimied a bit by pistons. I bought a new Gilardoni nikasil kit that was supposedly applicable to the 93 1000S, but it came with lower-compression pistons a la the 30mm-carb, small-valve square and round-fin 949 motors. The 93 1000S and Cal III and SP III had 36mm carbs and mid-sized valves.
No one seems to be able to source the mid-domed slugs, so I will be re-using the ones that came out of the bike after 92,000 miles, with new rings and new nicasil cylinders. I don't want to dull the thing down, and in fact have swapped the OEM cam with a B-10.
Otherwise it's coming along. Frame is welded back together, forks and wheels are done, trans is back from Charley, and Mike Rich has the heads.
Life's too short.
F_Sahms is online now   Reply With Quote
Old 07-24-2013, 06:38 AM   #393
woodly1069
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,956
F_Sahms I think I know what you are saying here about the crown being shorter and different than the previous factory part but what about the wrist pin location? If that is moved at all then they could have "done the math" to create the same or different compression ratios. Maybe the crown of the piston was changed to enhance combustion or something...just sayin'
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is offline   Reply With Quote
Old 07-24-2013, 06:52 AM   #394
F_Sahms
mostly paved
F_Sahms's Avatar
Oddometer: 361
I wish. The pin-to-ring and pin-to-flat-top dimensions are the same, so the lower-dome pistons would give lower compression ratio. The pistons in the kit are identical to G5, SP1000, Cal II, etc. slugs.
Life's too short.
Old 07-24-2013, 06:54 AM   #395
woodly1069
woodly1069's Avatar
Oddometer: 1,956
Right on, just thought I would point it out. Never know if someone is knows these things. If you speak good Italian you could call and ask why
Good luck with the build bro!
Old 07-27-2013, 07:06 PM   #396
danedg
Oddometer: 6,683
Dead Right There
I'm done until further notice. The tranny munched itself in the first 2000 miles.
It was the only unit I didn't rebuild...
Old 07-28-2013, 04:50 AM   #397
England-Kev OP
Oddometer: 3,642
Oh NO!
England-Kev is offline   Reply With Quote
Old 07-28-2013, 05:02 AM   #398
England-Kev OP
Oddometer: 3,642
So as I seem to be getting to grips with the problems on my Guzzi, and the list of things to do gets ever smaller My thoughts turn to improving things a little... I know, I know! I can hear you telling me to leave it alone from here
Now, one of the things that needs, or could use improving is the front suspension, it makes quite a clunk when you hit a pot hole or drain cover, also it is not the most stable bike I have ridden? and tracks with the road surface. So back when I pulled the forks apart to replace the bushes, I was surprised at how similar they were to BSA forks, in fact they are almost identical to those fitted to the A10 and M33/B33 range of bikes. Well this got me to thinking, back when I had my M33 I had the same issue with the front suspension, and I overcame the problem by fitting BSA Goldstar damper rods inside the fork stanchions. So I am going to do the same on the Guzzi, this is not a big job on any of these bikes, as they just screw into the fork top nut, and hang down inside the stanchion.
You can see the damper rods here...
Paul Goff... http://www.norbsa02.freeuk.com/goffyfork.htm
England-Kev screwed with this post 07-28-2013 at 07:34 AM
Old 07-28-2013, 08:16 AM   #399
MZRider
Neo-Luddite
Oddometer: 721
Very interesting! Please post details when you do this, lots of other Loopers would be interested in doing the same. Looks quite simple - something I could whip up on the lathe in no time.
Charlie
http://www.AntietamClassicCycle.com
'69 Guzzi Ambassador,'77 Yamaha XT500,
'88 Ducati Paso, '91 ATK 604
'94 MZ Silver Star, '96 CCM 350
MZRider is offline   Reply With Quote
Old 07-28-2013, 01:04 PM   #400
England-Kev OP
Oddometer: 3,642
I will keep you informed Charlie, I shall be getting them at the next Kempton
Old 07-28-2013, 07:37 PM   #401
flemsmith
lurk
Oddometer: 664
DaneDG....
Real sorry to hear about the tranny going south. Did it make horrible noises, or just go into some neutral stage?When you decide what you're gonna do, would appreciate you posting about it.
I'm debugging my T3 now, I'm actually surprised a bit by how rough it seems to ride, the mirrors vibrate pretty badly, and I don't have it tuned well enough to feel confident going very far. And the clutch isn't engaging very well, cable needs replacing. Plus it gets hotter than I expected. I may end up wanting an airhead next...
roy
flemsmith is offline   Reply With Quote
Old 07-28-2013, 07:46 PM   #402
woodly1069
woodly1069's Avatar
Oddometer: 1,956
not to stomp on the guzzi thread at all but I think that a lot of Guzzi riders have airheads as well! LOVE THEM BOTH!
Old 07-29-2013, 09:22 AM   #403
danedg
Oddometer: 6,683
It just sort of quietly let loose, didn't lock up and I can't shift it. It is in "the Neutral Zone"... with lots of shavings on the magnetic plug.
It's out of the bike already and I'm ready to start taking some pics...
Old 07-29-2013, 10:10 AM   #404
woodly1069
woodly1069's Avatar
Oddometer: 1,956
Hey danedg, I'm sure you already know this but there are special tools used to disassemble our Guzzi trannys. When you decide to have it fixed you can pull it from the bike and send it to Charles Cole in NY. He does most of them and is SUPER knowledgeable on this subject as well as the rear drives...If you need contact info. just let me know.
Old 07-29-2013, 05:30 PM   #405
danedg
Oddometer: 6,683
You mean like this one?
With the goose down, I'm forced yet again to ride this....
danedg screwed with this post 08-03-2013 at 07:25 PM
Times are GMT -7.   It's 04:16 AM.
