Old 07-29-2013, 07:18 PM   #406
woodly1069
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 2,003
There we go, just beautiful!
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is offline   Reply With Quote
Old 08-01-2013, 06:04 PM   #407
jwegman
Oddometer: 231
I'm late, but can I join the party?
1970 ambo
Just bought this today - I've been eyeing it since Dec 2010. He finally agreed to sell it to me! It fires right up, but I have yet to determine if it has the stock chrome bores (I presume it does). Before any more runnin, I'll be dropping the pan (lookin for chrome) and playing with magnets (hopin I get lucky with steel linings).
It's been resprayed, and the tank liner is flaking. Lots of signs that fluids are weeping etc. Hopefully it'll be a great project!
[click for larger images]
Regards,
Jake
jwegman is offline   Reply With Quote
Old 08-02-2013, 12:01 AM   #408
England-Kev OP
Oddometer: 3,725
Sweet, they just keep on turning up.
And I have a feeling the prices on these are set to rise real soon, as people realise just what a great classic motorcycle they are
England-Kev is offline   Reply With Quote
Old 08-02-2013, 04:35 AM   #409
nick949eldo
Oddometer: 1,093
Lovely looking bike. The front mudguard is the right colour! The rest of the bike would look wonderful matched to it........
Good luck with the refresh.
Nick
nick949eldo is offline   Reply With Quote
Old 08-02-2013, 06:27 PM   #410
woodly1069
woodly1069's Avatar
Oddometer: 2,003
Laugh
Sweet looking Ambo! Welcome to the bikes that will eat your wallet.
Old 08-04-2013, 09:30 AM   #411
England-Kev OP
Oddometer: 3,725
Sunday is Guzzi day, decided to do an oil change today, and torque down the heads, as well as pull the distributor for a service, so lots going on...
as I was changing the oil, I also took the opportunity to drop the sump, this time it was pretty clean, not perfect but pretty clean, I still had one piece of that rusty metal, and a fair amount of thick crud? more than I was expecting, but maybe this is being loosened up by me using the bike, hopefully it will get better and cleaner with more use.
The head bolts were tight this time and needed no adjustment. But I did find that the spark plugs were black, so it would appear to be running a little rich.
I am going to strip and clean the dizzy this week, and I have already found that the outer o-ring is worn, so oil has been passing by that point.
onwards and upwards.
Old 08-04-2013, 12:30 PM   #412
England-Kev OP
Oddometer: 3,725
I took a couple of shots along the way, and then forgot to post them
I know how you guys like pictures...
Old 08-04-2013, 01:07 PM   #413
nick949eldo
Oddometer: 1,093
Kev,
Shouldn't that be 0.10mm and 0.20mm for your bike?
http://thisoldtractor.com/gtbender/m...intenance_data
You don't want that exhaust valve too tight!
Nick
Old 08-04-2013, 01:29 PM   #414
England-Kev OP
Oddometer: 3,725
15 inlet, 25 exhaust according to the manuals?
Old 08-08-2013, 12:32 PM   #415
England-Kev OP
Oddometer: 3,725
Gave my old goose a present today, I dropped by the local DellOrto dealer, and grabbed some new jets, and gaskets, couldn't get new V5 needles though, no longer available they told me? anyway pulled the carbs, and gave them a real good clean, blew through all the passages with high power air, and put the whole lot back together. runs like a top now, and even the balance across both carbs is damn near spot on perfect...
Old 08-10-2013, 12:06 AM   #416
England-Kev OP
Oddometer: 3,725
Over in the Airhead section I run a register of BMW R80ST's, it has worked out pretty good over time, I wonder if I started a V7 Loop frame register over here if it would? what do you guys think?
Old 08-10-2013, 12:35 AM   #417
davebeef
Buffoon
davebeef's Avatar
Oddometer: 269
Worth a try, i you can be bothered doing it.
Rgds,
D.
'70 Moto Guzzi Ambassador, '78 FLH Shovelhead
'81 BMW R100, '79 MZ 250/1, '81 MZ 250/1
davebeef is offline   Reply With Quote
Old 08-17-2013, 12:36 AM   #418
England-Kev OP
Oddometer: 3,725
Is it possible to clean the sludge trap with the engine in the frame? or can this only be done on a full motor strip
Old 08-17-2013, 03:31 AM   #419
davebeef
Buffoon
davebeef's Avatar
Oddometer: 269
Don't know for sure but I would suggest almost certainly a full strip.
DB
Old 08-17-2013, 02:04 PM   #420
MZRider
Neo-Luddite
Oddometer: 726
Full strip. No way to to get to it with the crank still in the case.
Charlie
http://www.AntietamClassicCycle.com
'69 Guzzi Ambassador,'77 Yamaha XT500,
'88 Ducati Paso, '91 ATK 604
'94 MZ Silver Star, '96 CCM 350
MZRider is offline   Reply With Quote
Times are GMT -7.   It's 04:11 PM.
