Old 11-17-2012, 10:53 AM   #1
drzep OP
drzep's Avatar
Oddometer: 30
Question Will a Givi AF330 fit a GSA?
As the title states...I may have missed this topic in searching cause I'm sure it has been discussed.
The support arms that come with the Givi AF330 look as if they would fit and the OEM GSA screen will fit a GS, so has anyone fit the AF to a GSA? FWIW I have a 2008 GSA.
Thanks, joe
drzep is offline   Reply With Quote
Old 11-17-2012, 11:05 AM   #2
JustKip
JustKip's Avatar
Oddometer: 4,471
Of course it will. They're esentially the same bike except for bolt on bits. Your GSA screen and brackets come off and the AF330 goes on, in half an hour. Can (should) be used with the GSA winglets
JustKip is online now   Reply With Quote
Old 11-17-2012, 06:38 PM   #3
drzep OP
drzep's Avatar
Oddometer: 30
Can't hurt to ask. Thanks for confirming.
Old 11-17-2012, 09:17 PM   #4
Wdwrkr
Wdwrkr's Avatar
Oddometer: 1,854
You will have to remove the GSA windshield support bracket, which was a deal breaker for me. I like the location for my gps so for me the search continues. By the way I called givi about this and they told me it would not fit. I tend to agree it will as the two bikes share the same headlight assembly.
Wdwrkr is offline   Reply With Quote
Old 11-18-2012, 02:26 AM   #5
Kiwirich
Kiwirich's Avatar
Oddometer: 179
It does fit both & Touratech make a High GPS mount bracket that takes care of that problem too.
Kiwirich is offline   Reply With Quote
Old 11-18-2012, 02:01 PM   #6
Wdwrkr
Wdwrkr's Avatar
Oddometer: 1,854
Would love to see a pic of this final set up. I had an af330 on my 06 and loved it.
Old 11-27-2012, 02:25 PM   #7
drzep OP
drzep's Avatar
Oddometer: 30
So does anyone here actually have a GSA with a AF330 installed?
Not bitting the bullet until I see that it has been done (aside from the armchair thought experiment)...
Old 11-27-2012, 04:28 PM   #8
bobbybob
Oddometer: 592
Well, I can confirm it definitely fits the 2012 GS, as I watched a Givi rep. install one on my buddy's R12GS at the Givi USA warehouse in Charlotte last week! (I also have one on my 2010 GS)
bobbybob is offline   Reply With Quote
Old 11-30-2012, 08:19 PM   #9
drzep OP
drzep's Avatar
Oddometer: 30
So despite the popularity of the Givi AF and the notion that it should fit a GSA, its still remains an untested theory? That seems hard to believe...
Bueller?
Old 11-30-2012, 09:15 PM   #10
JustKip
JustKip's Avatar
Oddometer: 4,471
Bueller?
Rather than "untested theory", I prefer to think of it as the obvious conclusion. There is ONE R1200GS model, with a few different bolt on accessories. You can take ANY PART from one and bolt it directly to the other, but you might need to switch other parts to complete a process....like the GSA side stand and centerstand along with the longer GSA springs....or the GSA windshield bracket along with the GSA windshiled onto a std GS (or remove the bracket to go the other way).
To put a GIVI AF330 on a GSA you simply remove the windshield AND the GSA specific support bracket, then install per instructions for a standard GS. Anybody who can operate a screwdriver can do it.
Old 12-01-2012, 10:46 AM   #11
drzep OP
drzep's Avatar
Oddometer: 30
Well, I'm not very bright so it takes me time to process things but THANK YOU for the clarification. Now if I could only figure out how to use this damn screwdriver...
Old 12-01-2012, 11:06 AM   #12
JustKip
JustKip's Avatar
Oddometer: 4,471
Keep the pointy end pointed away from your body and you'll do fine. At least that's what's worked for me, so far.
Old 12-01-2012, 11:09 AM   #13
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,386
Bueller?
I have an 07 gsa with this screen. Put it on earlier this year. Should have done it years ago. One of the better mods I've done on a bike.
It calls for the removal of the gsa screen crossbar, which I did. Though I think that I could have kept it with a couple of holes drilled into the screen, if I had wanted to keep it.
PM me if you want to know more.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 12-08-2012, 05:07 PM   #14
drzep OP
drzep's Avatar
Oddometer: 30
Thumb
Thanks guys. With my last 3 bikes its been the same wind screen story - at least 3 before I find the one that suits me and my girlfriend. On the RT a Cee Baily's +1 H / +2 W was money.
I put an AF330 on this weekend. For me its a good screen - the adjustability was great for off road and the height is adequate to get good protection on the highway. The one thing that I found strange, and it may be due to the velocity of air flowing under the moving portion of the screen (and the fact that when fully up its nearly vertical and plowing through the air) is that above 75 mph I start to get buffeting no matter how I adjust it. I can drop it all the way down and get clean air to fix the problem, but when its 35F and raining, the clean air can be a bummer.
The second observation came from the pillion. We could not find a setting that gave her clean air without some buffeting. Tilting back towards me made it much worse and again, dropping it was the best in terms of noise/buffeting. I'd say that its as good as the Aeroflow (sport fairing, tall size) for me, not as good for the pillion.
So far she has preferred the Wunderlich Ergo with a Wunderlich clip-on wind deflector...
I'm going to keep playing with the adjustments and see if we can find a good all-around compromise. Thanks again for the input folks.
Old 12-08-2012, 05:15 PM   #15
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,386
Weird. I have none of those problems. I'm 6'4", btw.
Times are GMT -7.   It's 12:05 PM.
