Old 11-17-2012, 11:47 AM   #1
txbear55 OP
Oddometer: 266
Gas tank vent hoses
Seems like it's always something...I'm servicing my 1150 GSA and pulled the tank, fuel pump, etc. In my haste I pulled the vent hoses from the fuel pump plate and did not index which goes where. Obviously I have a 50/50 chance of re-installing correctly, but I would prefer to do it right the first time. BTW, if switched, what would effect be on the bike? TIA!
txbear55 is offline   Reply With Quote
Old 11-17-2012, 01:44 PM   #2
vintagerider
vintagerider's Avatar
Oddometer: 1,962
Careful when you put the plate back on. Tank studs strip easy. The actual bulhead fitting used on the pump plate isn't important. The connections are. Gently blow with your breath in to the end of the line terminating as your tank vent. Yo should hear breath escaping from inside the tank.
The tank condensation drain should drain to the ground.
vintagerider is offline   Reply With Quote
Old 11-17-2012, 02:38 PM   #3
txbear55 OP
Oddometer: 266
Thanks for the quick reply. Makes perfect sense...don't want fuel overflow draining into the charcoal canister instead of out to ground!
Old 11-17-2012, 03:33 PM   #4
vintagerider
Oddometer: 1,962
If you still have Kanister installed then either you are performing routine EVAP inspection and maintenance or you are preparing for trouble. EVAP with kanister requires extra service, parts and attention.
When was the last time that you removed the charcoal dust from the tank?
Cleaned, checked, replaced hoses?
Checked for condensate in Kanister?
Checked proper routing of hose?
Checked operation of purge valve?
Personally I leave EVAP on but perform the KKK by-pass. If this is a dealer serviced mc then you'll need to have the kanister renewed periodically along with regular tank cleanings. Most dealers don't want to do the latter.
Since most dealers don't want to service EVAP you have to decide if you will do it yourself or perform KKK or even Canisterectomy (not recommended- illegal, can be impounded at roadside DOT inspections)
Pre-KKK prep is a major service of the fuel prep/delivery system that prepares the tank for KKK.
KKK is also an illegal mod but one which is easily reversed and less likely to result in impoundment or state inspection failure then C-ectomy.
After kkk maintenance is lower. You can restore to contaminating your fuel fuels system with ultra fine charcoal dust in seconds whenever you wish.
edit:
The drawing below is not a substitute for verifying proper tank venting with the breath test. There is an assumption that one knows what to do with the vent terminus, however experience demonstrates a high level of confusion. The tube positions get switched all the time.
Breath test to verify tank venting, use the breath test, never compressed air.
vintagerider screwed with this post 11-17-2012 at 05:54 PM
Old 11-17-2012, 05:10 PM   #5
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,422
This is something Poolside made up. I just keep it handy for those in need.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Times are GMT -7.   It's 06:42 AM.
