Old 11-15-2012, 11:46 AM   #1
Leadnuts OP
do-over...
Leadnuts's Avatar
Oddometer: 116
Modifying Cables.. No/Yes
I want to do a 1 to 2 split for my throttle cables, is it possible to do it safely on my own or is it something that needs to be done in a pro shop?
Doing it on a R75/5 with Bings..
I was looking at the splitter junction box and it seems pretty strait forward but I'm not so sure how the cable ends are applied to all these cables. Crimped, soldered, screw clamp..
thanks, any info would be appreciated.
Leadnuts is offline   Reply With Quote
Old 11-15-2012, 11:58 AM   #2
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,504
Off the shelf from places like Motobins. The 81 onwards machines had splitters as standard. They just take a few minutes to fit but you may want the right throttle cam and single outlet throttle assembly.
Rob Farmer is online now   Reply With Quote
Old 11-15-2012, 12:14 PM   #3
cathouse willy
just some guy
Oddometer: 69
check out this youtube vid for soldering new cable ends. I've tried it and it works.
http://www.youtube.com/watch?v=F-gY2...endscreen&NR=1
cathouse willy is offline   Reply With Quote
Old 11-15-2012, 01:01 PM   #4
Leadnuts OP
do-over...
Leadnuts's Avatar
Oddometer: 116
Whoa, thanks.
Rob I have a nice tommaselli single pull throttle all ready to go. I hope it will do the job.
cathouse, thats a helpful little vid... if he used a denser wood he would have better results on finish.. I have a chunck of Ipe I'm going to test it on.. It should give a smoother surface when pulled out.
Thanks guys.
this was the splitter i was looking at.
Old 11-15-2012, 04:14 PM   #5
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,462
Looks a little short. Make sure it won't limit your cable pull and not allow you to open up the throttle all the way. Figure out how much cable take-up it takes to get the bings all the way open and add a bit for free play.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 11-16-2012, 08:00 AM   #6
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,500
You can do it!
The spreading/peening of the cable end is the most important point of all. Without that the joint will fail, even on a throttle cable.
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is online now   Reply With Quote
Old 11-17-2012, 11:34 AM   #7
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,459
32 73 1 242 125 x1 upper cable 19.00
32 73 1 242 132 x2 lower cables 19.00
32 73 1 242 014 x1 splitter 16.00
total $73.00
You might have to modify the exposed length on the upper cable if you are using the /5 throttle assembly.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 11-17-2012, 03:20 PM   #8
Thisguy
Hold Fast
Thisguy's Avatar
Oddometer: 2,310
Would anybody mind explaining why this conversion is a good idea. I am planing on replacing my cables soon.
1986 R80RT
2000 Land Cruiser
"The Edge... there is no honest way to explain it because the only people who really know where it is are the ones who have gone over." Hunter S. Thompson
Thisguy screwed with this post 11-18-2012 at 02:22 AM Reason: damn auto correct!
Thisguy is offline   Reply With Quote
Old 11-17-2012, 05:09 PM   #9
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,769
Convention?
Old 11-17-2012, 10:29 PM   #10
victor441
victor441's Avatar
Oddometer: 896
If you are installing new ends on a cable the right way is to use a solder pot...but a 1/2" black iron pipe cap with a propane torch for heat works great as a makeshift one...have done it this way successfully using plumbers solder and flux. Before I knew better I tried soldering directly with a torch and the cable failed quickly.
victor441 is offline   Reply With Quote
Old 11-17-2012, 10:48 PM   #11
_cy_
Oddometer: 6,033
thanks .. above instructions from Flanders is one of best/simplest I've seen posted.
Old 11-18-2012, 02:22 AM   #12
Thisguy
Hold Fast
Thisguy's Avatar
Oddometer: 2,310
Conversion- damn auto correct!!
Originally Posted by Houseoffubar View Post
Convention?
1986 R80RT
2000 Land Cruiser
Old 11-18-2012, 04:46 PM   #13
Houseoffubar
fine beer sampler
Oddometer: 1,769
I converted mine, because (IMHO) dual cables running all the way to the throttle grip get tugged, and pulled when turning the bars, and such causing them to get out of sync with each other more quickly/easily.
By running one cable as far down as possible, only one cable bends with turns, keeping thing in sync with each other. I also think there is slightly less drag, due to the lesser amount of cable being pulled.
Old 11-18-2012, 08:51 PM   #14
Boxer Metal
Mad Scientist
Oddometer: 3,459
Dual cables are easier to deal with and less maintenance. If your having problems with cables pulling or adjustment staying either run longer cables or route them in a smoother path. Stick with the dual cable set up.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 11-19-2012, 08:42 AM   #15
Leadnuts OP
do-over...
Leadnuts's Avatar
Oddometer: 116
I'm going to try this with your pipe trick, or rather a pipe end cap... Looks like the way to go.
What splitter box are people using, out of curiosity?
Also I've seen a fitting that is a curved tube between throttle body and cable to divert the cable to a 90ish degree angle... it it ok to use one or is it considered a no-no?
Leadnuts screwed with this post 11-19-2012 at 08:48 AM
Times are GMT -7.   It's 06:17 AM.
