Old 11-18-2012, 02:30 AM   #1
kenhaw OP
2006 Adventure S EU
kenhaw's Avatar
Oddometer: 31
KTM Adv 2006 S Eu model and Tune Ecu
Hi Guys
Just figured something out.
Have been fidling with Tune Ecu and maps from 2006 for a little while now. Did not understand why I couldnt use the reset adaptation, adjust throttle cable, test coils and injectors. They were all greyed out and couldnt be activated.
So I tried the EU map for the 2007-08 model, it has exactly the same parameters and voila everything can be tested. Absolutely beautiful
I am not sure this works the same for the US models, but I think so.
I tried to copy paste all the parameters from PowerTripps dynotuned 2010 map into my old 2006 map. It loaded fine and the bike started without any problems. Have anyone done this before with any luck? Is there a big difference between 2006 and 2010 models? I can see there are changes everywhere in the map between the two.
PS I absolutely love my bike.
Thanks for all the work you have put into this site, Love it.
kenhaw is offline   Reply With Quote
Old 11-18-2012, 04:56 AM   #2
Spark01
V-Twin
Spark01's Avatar
Oddometer: 306
The cams are not the same.
since the 2009 model the adv uses the same cams as a '07 superduke.
Before that those were different, but if there is something more different not sure you have to check the parts fiche.
But it is strange that the power trip map works on your bike because more people in the tuneecu topic have tried this without luck because the cams are to different.
More/less valve lift and thus require different ignition/fuel value's
'10 990SMT
Spark01 is offline   Reply With Quote
Old 11-18-2012, 09:04 AM   #3
kenhaw OP
2006 Adventure S EU
kenhaw's Avatar
Oddometer: 31
Well all I can say is that it started without problems. It was idling fine and I gave it a couple of twists on the throttle.
Whether it also works when riding the bike, I dont know.
I only copied all the fuel tables, to my knowledge no ignition tables could be changed.
Old 11-18-2012, 10:50 AM   #4
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 935
That's why it works on your bike. If you changed the ignition tables too it would be messed up.
690R
Old 11-18-2012, 10:55 AM   #5
Gustavo.Ramos
Oddometer: 935
My 990 is a EU version, and that happened too... noone seems to know the reason... maybe the early 06 maps are less funtional than 07 and beyond?
690R
Times are GMT -7.   It's 07:32 AM.
