Old 11-18-2012, 10:41 AM   #1
backcountryrider15 OP
Oddometer: 24
Pin hole in exaust ct125
Guys I have some kind of pin hole leak in the exaust on my 77 ct125. There is a small amount of fluid leaking. It appears to be before the muffler. What does this mean?
backcountryrider15 is offline   Reply With Quote
Old 11-18-2012, 11:32 AM   #2
Beezer
Oddometer: 5,748
some exhaust cans have a small drain hole. if that aint it then it's starting to rust through
Beezer is online now   Reply With Quote
Old 11-18-2012, 11:39 AM   #3
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,634
The fluid is likely just water. There's quite a bit of water in the air, and your motor uses a lot more of it than it does fuel. If the hole is not a factory weep hole but a rust hole, you can extend the life of your system by having a competent welder zap the hole shut with a small bead of weld. It's commonly done around here. It's not a solution to a completely rotted pipe, but is a legal move on a system that is otherwise sound.
The Rock 2013 RR
http://advrider.com/forums/showthread.php?t=915172
Dual Sport Luggage Racks: http://www.moto-racks.com
hONORARY mEMBER fIRST aMERICAN cHAPTER tEAM nONGA (pROVISIONAL wING)
Canuman is offline   Reply With Quote
Times are GMT -7.   It's 01:35 AM.
