Old 04-02-2013, 10:08 PM   #61
Idle
Oddometer: 703
Originally Posted by sam_2555 View Post
Are the inner springs just there as some sort of damper to stop the valve bouncing after its closed? Maybe the large outer spring was sufficient to pull the inlet valve closed but due to it's larger weight it would need a stiffer inner spring to stop it from oscillating?
Did your bike have dual springs before?
The dual springs eliminate harmonic resonance, they don't bcause they just graze one another as they move.
They also are a little weaker giving a slight bit more power (debatable).
Idle is offline   Reply With Quote
Old 04-03-2013, 04:43 AM   #62
sam_2555 OP
Oddometer: 21
Relief!
Idle, yeh it did have them before. Thanks for clarifying what they're for.
Gunner, that's exactly what they are. Thanks for the help. I think I'd just gone too far down the spring spacer train of thought to think about any other possibility.
After rebuilding the water pump the shaft seems pretty stiff when I turn it. I've tried knocking it back out a bit so it's tight up against the circlips but it is still really tight. Is this normal? Will it loosen up a bit as it's used? I thought it might be the new seal gripping the shaft tighter than the old one did but I'm not sure.
Thanks for the help guys.
sam_2555 is offline   Reply With Quote
Old 04-03-2013, 08:18 AM   #63
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,113
A freshly rebuilt pump is normally quite stiff to turn...
640 A x 2
BC RIDING 2014
gunnerbuck is online now   Reply With Quote
Old 02-02-2014, 03:49 AM   #64
muttley92
Oddometer: 66
Any updates on this...?
muttley92 is offline   Reply With Quote
Times are GMT -7.   It's 04:05 PM.
