Old 11-19-2012, 06:47 AM   #1
rossguzzi OP
990 Adv.
rossguzzi's Avatar
Oddometer: 1,055
Fork oil change
I want to change my fork oil but need a 'how to' anyone know of where I can find ?
Cheers
rossguzzi is offline   Reply With Quote
Old 11-19-2012, 07:16 AM   #2
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,170
Right at the top of OC page ...
here
Building a KTM 690Exc - the ultimate dirt tourer
2007 KTM Adv990S - Sold, 2010 KTM530Exc-Rally, 2012 KTM Adv990
Vicks is offline   Reply With Quote
Old 11-19-2012, 08:22 AM   #3
tomdubz
getting there
tomdubz's Avatar
Oddometer: 537
http://www.ktm950.info/how/Suspensio...ens_video.html
This is my signature: TD
tomdubz is offline   Reply With Quote
Old 11-19-2012, 09:16 AM   #4
rossguzzi OP
990 Adv.
rossguzzi's Avatar
Oddometer: 1,055
Thanks for the pointers but there isnt a 'how to drain' part to the vid. Looking for a more comprehensive how too.
I looked everywhere in the link to the top of the page but couldnt find it either.
Probably me, tierd after work etc.
Cheers
Old 11-19-2012, 10:38 AM   #5
yuu
yuu's Avatar
Oddometer: 122
Draining is pretty simple. Open the cap an *slowly* invert the fork over a bucket. I'd suggest having a drop cloth/news paper etc around as it can get messy quickly.
That slowly remark is important! Not far past parallel to the floor, the spring, spacer and anything else will start to slide towards the low end. As you might figure there will bit a bit of a fluid rush and mess potential when the springs pop out. Be sure to keep the spring etc. from exiting the fork without taking note of orientation of the spring, order of parts when there's a spacer etc etc. Just go slowly.
Let the spring etc fall in the bucket/drain pan and turn the fork almost all the way upside down. Almost will keep the oil draining from one side, and not just dripping out at random all around the circumference. With it in that position, secure it. A wood jaw vise, bicycle frame 3rd hand etc is perfect - just something softer than aluminum.
With it clamped down you can gently manually extend the fork slider and cartridge/ rod to pump any oil out of the 'nooks' and really, just let it sit and let gravity do the work. If you've got the time, let it set overnight.
Another thing I should mention is to be sure you've got control of the fork tube and lower when you move it about. With the cap off the tube will just slide down creating a great mess if you've got the fork clamped by the axle/caliper mount
Throttle's on the right, so are the brakes. Good luck.
yuu screwed with this post 11-19-2012 at 11:38 AM
yuu is offline   Reply With Quote
Old 11-19-2012, 12:21 PM   #6
DirtyADV
DirtyADV's Avatar
Oddometer: 2,366
Replaced the fork seals a while back and did a write up on it, skip the seal change steps:
http://www.dirtyadv.com/ktm-950-adve...l-replacement/
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is online now   Reply With Quote
Old 11-19-2012, 06:10 PM   #7
Graniteone
3,2,1...Beer me!
Graniteone's Avatar
Oddometer: 467
/Johan
Good stuff! Thanks for that.
Graniteone is offline   Reply With Quote
Old 11-19-2012, 06:46 PM   #8
rossguzzi OP
990 Adv.
rossguzzi's Avatar
Oddometer: 1,055
Many thanks guys.
Cheers.
Old 11-21-2012, 12:53 PM   #9
DirtyADV
DirtyADV's Avatar
Oddometer: 2,366
Had some issues with the inner tube on one of them and the spacer tube running down the middle got jamed on the valve at the bottom ending up with the valve coming back up with pulling the rebound spacer tube out.
Will do a writeup soon about the inner part of the fork, have done one without any special tools but miss some pictures so need to do the other one and get some better pictures (will look over the other one even if there are no issues just to be safe).
Was the stock fork I changed seals on. But have another set from a low S model that I had the valve problems with.
/Johan
Old 11-21-2012, 01:39 PM   #10
akarob
Green Cantern
akarob's Avatar
Oddometer: 7,872
If the oil in there hasn't been changed for a year or so, you will also probably want to flush it with some ATF. When refilling, I have found that using a dipstick (such as the OEM oil one) is a good tool to measure the level. I don't know if the 990 dipstick will give you the right level, I haven't had my bike long enough to find out, but on another bike it did.
All in all, a fluid change is fairly simple.
akarob is offline   Reply With Quote
Times are GMT -7.   It's 01:14 PM.
