Old 11-20-2012, 07:05 AM   #1
weatherm OP
Oddometer: 297
drz400s weird starting issue
2003 drz400s
hey folks... this just started happening the other day out of the blue.
mods:
raptor petcock fix... so no vacuum problems or leaky petcock
air box mod
rejetted
fresh 93 octane gas
carb rescently cleaned
valvles checked 1k ago
11,500 miles
used to crank just fine
now:
i hit the starter and it tries to turn and just hangs...display resets
hit it again it tries to turn and hangs
hit it consecutively (a few times) and it finally turns over
when its warm it starts fine
---good battery, tested with volt meter... hooked it up to the car just to make sure on a separate instance
driving me nuts
weatherm screwed with this post 11-20-2012 at 07:32 AM
weatherm is offline   Reply With Quote
Old 11-20-2012, 08:00 AM   #2
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
Sounds like a bad battery connection (I'm sure you have already cleaned and tightened that) or maybe your battery has a problem that cause's it to test ok but fail under load? (a shorted cell?) The fact that it works well when warm is interesting. Maybe your starter solonoid?
jessepitt is offline   Reply With Quote
Old 11-20-2012, 08:03 AM   #3
weatherm OP
Oddometer: 297
i checked the connections they are fine.
that might be it... i dunno.
thanks though!
Old 11-20-2012, 08:15 AM   #4
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
Most times when I encounter these symptoms it turns out to be a connection somewhere. Usually the ground. Maybe the ground wire end opposite the battery? Probably hooks to the frame and could be loose.
Old 11-20-2012, 08:22 AM   #5
garrett
garrett's Avatar
Oddometer: 458
Electrical. Try removing and cleaning up the wires from the battery to the relay, and starter. 11K miles with water, road etc leads to poor connections. It takes time and energy tracking these gremlins down. Take them apart, clean them to bare metal, dielectric grease then re assemble. Plugs too, clean them with contact cleaner, re grease.
Good luck
Garrett
I like bikes...
garrett is offline   Reply With Quote
Old 11-20-2012, 08:23 AM   #6
Pauls2ndblessing
Oddometer: 99
My first inclination was battery or short(ground) as well. What happens when you wiggle the key while trying to start it... I know that sounds funny but could test for a short in the key ignition switch.
Hope you get it worked out soon man!
Pauls2ndblessing is offline   Reply With Quote
Old 11-20-2012, 01:12 PM   #7
rjsurfer
Oddometer: 207
How old is that battery?
Ron W.
DRZ 400SM
DL-650 Gone but not forgotten
rjsurfer is offline   Reply With Quote
Old 11-20-2012, 02:01 PM   #8
weatherm OP
Oddometer: 297
around 8 months for the battery
when I get off work I'll be cleaning all contacts... Keep you guys posted
Old 11-20-2012, 05:51 PM   #9
weatherm OP
Oddometer: 297
I think you guys were right! I cleaned all contacts, starter, frame, battery, solenoid. gave it a good carb deusche. let it sit for a few hours so it was nice and cold. cranked strong and turned over almost immediately.
I think its fixed.... not putting the cart before the horse until it works perfect for the next few days. Let you guys know if its 100% or not.
thanks for the help
K.I.S.S.
Old 11-21-2012, 04:22 PM   #10
garrett
garrett's Avatar
Oddometer: 458
One more little tidbit from my DRZ days.In the spring my normally reliable DRZ began ocasionally missing then would run fine. On subsequent rides, it got worse and began to run rough, cough sputter backfire etc. I cleaned the carb checked jetting and valves to no avail. Then the bike just wouldn't start.
I came across a thread over at TT that outlined the excat problem I was having and said that it was a fried stator. To diagnose was as easy as disconnecting the plug that goes to the voltage regulator on the left side of the bike. You cant miss it. Anyway, after I did that it started right up and ran and the second I plugged it back it the engine died. So I replaced the stator with a Ricky Stator unit and it ran better than ever.
Electrical gremlins are little bastards to diagnose, which is why I'm posting this here.
Hope your DRZ runs good.
Garrett
I like bikes...
Old 11-21-2012, 10:45 PM   #11
murgatroid42
Great Adventurer
Oddometer: 4,185
The digital speedo/odo on a DRZS can drain the battery if the bike is not run for a while. Unless it is charged or run regularly, the battery can discharge and have a shortened life.
I charge my battery once a week if I don't ride it.
"We hang around people who think these activities are normal."
"Me and gravity, we are really, really good friends." - Streetbike Tommy, Nitro Circus
"I'm a dude in his mid-40s, who acts likes he's in his 20's. But I don't plan on stopping any time soon." - Ken Block
murgatroid42 is offline   Reply With Quote
Old 11-23-2012, 06:50 PM   #12
Mudddawg
Oddometer: 5
The DRZ charging system is marginal at best. The Battery is just to small, the voltage to battery has to go thru silly connectors to get to the battery and the Clock drains the battery too.
Do the Free power mod on TT which basically bypasses silly connectors with larger gauge wire and puts regulator voltage straight to the Battery.
Always plug in your DRZ onto a Tender. My stock battery lasted 5 years before I replaced it with a bigger one. I gave the old one to a buddy and he used it for another 6 months, but he didn't plug it in.
Mudddawg is offline   Reply With Quote
Times are GMT -7.   It's 10:29 AM.
