Old 11-24-2012, 12:56 PM   #31
scarysharkface
30-125
scarysharkface's Avatar
Oddometer: 13,022
V-Strom 650 is happy doing a true Garmin 85 mph all day long with side cases. Mileage suffers, but on a recent 3k+ mile trip with my brother on his R1150R the Wee had better range.
john
The road to Hell is paved...
Save $5 on a Smugmug subscription when you use my coupon:
yBr7OofIPuOP6
Another '98 DR350 for sale http://advrider.com/forums/showthread.php?t=1036981
scarysharkface is offline   Reply With Quote
Old 11-24-2012, 03:52 PM   #32
10/10ths
Road Trip Fool
10/10ths's Avatar
Oddometer: 927
V-Strom 650....
.....Mine will cruise I-10 at 80 mph all day long with huge Givi side cases and top box.
If you are worried that the 650 is "not enough motor", don't worry.
If you are a speed freak, or want extra headroom for high speed motoring in the mountains, fully loaded, then buy a V-Strom 1000.
FWIW, I ride solo, but with hard luggage on the Interstate and she will run 85mph with zero drama.
Buy one, and if you hate it, sell it and buy a bigger machine, you won't lose money.
1997 Ducati Monster 750
2004 Honda RC51
2011 Suzuki GSX1250FA replaced my '04 Wee 2-14
10/10ths is offline   Reply With Quote
Old 11-26-2012, 07:32 AM   #33
rodmuzwa
rodmuzwa's Avatar
Oddometer: 174
I've got a 2009 wee with 26k kms on the clock. She runs like a dream with a bit of clutch rattle just to prove she is a real strom. My mate just got a Tiger 1050 and my other friend has a GS1150. Now, after a recent longish run I was a little concerned my little 650 motor would suffer after cruising around 130kph compared to the two bigger bikes. So much so I started actively looking for a bigger bike, possibly a GS1200. After reading this I think I am better keeping the wee which incidentally I love. Just a little worried I mess up the motor on the longer runs at higher cruising speeds. Maybe it's a damn sight tougher than I thought!
Living the dream, everyday!
rodmuzwa is offline   Reply With Quote
Old 11-26-2012, 08:33 AM   #34
Pecha72
Oddometer: 3,889
Make sure you've got good quality oil, and check oil level regularly (just as with any vehicle), and the Wee does sustained 130kph just fine, it will even have something in reserve, though not as much as a +1000cc bike. But plenty for a 650.
Pecha72 is offline   Reply With Quote
Old 11-26-2012, 08:41 AM   #35
tommyhof
tommyhof's Avatar
Oddometer: 832
Back in Oct 11, I went from a Concours 1000 to the Wee, was going to keep the Concours but after a month on the Wee I sold the Connie, it could do everything the Connie could, plus go off road, I've been on a few goat trails on it, only thing I gave up is passing in gear, now I have to think and down shift to pass the Semi-Truck.
Tom
06 Wee-Strom
Virginia Beach, VA
COG 6517
tommyhof is offline   Reply With Quote
Old 11-26-2012, 08:55 AM   #36
ph0rk
Doesn't Care
ph0rk's Avatar
Oddometer: 2,059
I feel like I cruise at anywhere from 65mph(actual) to 95mph(actual) and it feels identical.
Calsci medium screen, set to stock angle on a madstad, lowest setting (but highest bolt mounting point for madstad). Caribou 36l cases, and an occasional duffel bag strapped longitudinally.
When I'm doing around 70-75mph I get about 50mpg. I haven't done sustained rides of 90+ for obvious reasons.
I get my best MPG at 70-75mph with a barn door on the front, I must be heavy on the throttle around town.
Edit: I just did a mid-tank fillup, ~20 miles of cold weather commute and 62.3 miles of angry WOT backroads blasting (all sub 60 mph).
38.51 mpg. Yikes.
--Semantics are everything.
ph0rk screwed with this post 11-26-2012 at 10:12 AM
ph0rk is offline   Reply With Quote
Old 11-26-2012, 04:02 PM   #37
rodmuzwa
rodmuzwa's Avatar
Oddometer: 174
I'm generally getting in excess of 500km per tank of fuel. Not quite sure what it works out as in mpg but it seems pretty good to me!
Old 11-26-2012, 04:37 PM   #38
bobobob
badbadbad
bobobob's Avatar
Oddometer: 5,352
300 miles.
It is just a bunch of inner tubes Roy . . . - Cannonshot
Growing old is compulsory - growing up is optional. - Haroon
bobobob is offline   Reply With Quote
Old 11-26-2012, 06:35 PM   #39
oldmanb777
Just say NO to socialism!
oldmanb777's Avatar
Oddometer: 3,862
Mine is fine at all reasonable speeds even with all the camping gear. It will easily get tickets on interstates, again with all the gear. Clear the Colorado passes with ease, again with gear well into the high 90's. the speedo is about 7 to 10 % optomistic. So high 90's is probably a true 90. But going over Vail Pass @ a true 90 mph with gear on is good enough. Vail Pass is about 11,000 ft. Some Wee's report high oil consumption above 80 mph, but mine doesn't do that. Even pushing 90 all day, it doesn't seem to use any oil. But I do see a decrease in fuel mileage above about 75 mph. And push a headwind at speed and the mileage will get down into the high 40's. I have seen as low as 46 mpg on a Yellowstone trip. Loaded bike pushing strong Wyoming wind and keeping up with a GS1100. We actually matched gas usage on that leg of the trip.
oldmanb777 is offline   Reply With Quote
Old 11-26-2012, 09:28 PM   #40
DPJK
Oddometer: 17
My 2012 vstrom 650 cruises at an indicated 80 (72 GPS) all day. Cruising on I-5 is effortless, even with luggage loaded for work. I would not hesitate to trust my setup for any length of trip, under any conditions. I love the little 650 motor.
2012 Suzuki V-Strom DL650AL2
2006 Kawasaki Vulcan 900 Classic... Sold
2009 TW200.... Sold
DPJK is online now   Reply With Quote
Old 11-26-2012, 10:48 PM   #41
tedder
irregular
tedder's Avatar
Oddometer: 8,797
at what speed?
tedder is offline   Reply With Quote
Old 11-27-2012, 01:28 AM   #42
rodmuzwa
rodmuzwa's Avatar
Oddometer: 174
Usually sit between 110 and 120 kph cruising which would average around 75mph I think. At 120 I'm about 5500 rpm. Even commuting to work and nipping round town I'm still getting close!
Old 11-27-2012, 02:03 AM   #43
outsidein
outsidein's Avatar
Oddometer: 433
Originally Posted by MNrider View Post
Hello - I'm considering going to something lighter than a 95 R100RT BMW. I see that a lot of the Iron Butt Association riders ride a 650 V-Strom. My question is - is that bike happy cruising at 75-80 MPH all day?
Thanks -
I would also consider test riding a Kawasaki Versys 650 too. The Versys has better handling/agility than the WeeStrom 650 on pavement and is more fun to ride fast on pavement, especially if it is twisty. I did a lot of comparison test rides before settling on buying my Versys. The Versys is not perfect however, it needs a bigger aftermarket windshield to ride distances at speed and you need to install aftermarket peg lowering kit to get a similar amount of leg room as the VStrom provides stock. While the parallel twin of the Versys seems to be more responsive and powerful than the similar sized VTwin of the VStrom it does produce slightly more vibration although not enough to be annoying or shake the rear view mirrors.
Either the VStrom or Versys can cruise comfortably at 80mph all day. Most of the motorcycle magazines have preferred the Versys over the VStrom in head to head comparison tests because of the slight edge it has in handling and engine response.
http://www.youtube.com/watch?v=cy16XkzFXdY
outsidein screwed with this post 11-27-2012 at 02:11 AM
outsidein is offline   Reply With Quote
Old 11-27-2012, 04:30 AM   #44
rodmuzwa
rodmuzwa's Avatar
Oddometer: 174
[QUOTE=outsidein;20125068]I would also consider test riding a Kawasaki Versys 650 too. The Versys has better handling/agility than the WeeStrom 650 on pavement and is more fun to ride fast on pavement, especially if it is twisty. I did a lot of comparison test rides before settling on buying my Versys. The Versys is not perfect however, it needs a bigger aftermarket windshield to ride distances at speed and you need to install aftermarket peg lowering kit to get a similar amount of leg room as the VStrom provides stock. While the parallel twin of the Versys seems to be more responsive and powerful than the similar sized VTwin of the VStrom it does produce slightly more vibration although not enough to be annoying or shake the rear view mirrors.
I tried the Versys and although it was fun I preferred the wee. The Versys has a different seating position, slightly more forward on the bike and it didn't feel as comfortable to me. There was also a fair bit of vibration at speed. In saying that it was definitely a little more responsive than the wee and certainly a fun ride. Not for me but I would certainly have a go on one. I'd like to try the Versys 1000!
Old 11-27-2012, 04:53 AM   #45
Pecha72
Oddometer: 3,889
If you do like I did, and put full street tyres (Michelin Pilot Road 3's in my case) on the 2012/2013 Wee, then I'd say handling on pavement gets pretty damn close to a Versys.
The crappy OEM tyres (on all Wee models) are the biggest reason it won't cut it on tarmac, or at least there's room for improvement. I mostly ride on pavement nowadays, and the occasional gravel road is still just fine, so street tyres are a good choice for me.
Times are GMT -7.   It's 03:04 PM.
