View Results: Disc OR Drum???
Drums front and rear? 8 33.33%
Single disc front and rear? 11 45.83%
Dual disc front and disc rear? 5 20.83%
Voters: 24. You may not vote on this poll
Old 11-21-2012, 07:55 AM   #1
Calkins OP
On Any Sunday...
Calkins's Avatar
Oddometer: 505
Question Drum Brakes OR Disc Brakes???
I am going to start building a gravel road only bike soon. One big hold up for me right now is trying to figure out how I want to do brakes. I will be using a Yamaha XT500. I have a disc brake XS650 swing arm (which will add about one inch to the wheelbase), and I have XS650 forks to do single or dual front disc. So, do I go for discs or drums front and rear? I will not mix and match. I want the same front and rear. If I go drum, I could find a twin leading shoe front hub. Basically, what I want to end up with is my flattracker with nasty knobby tires. Yea, the current rage right now, I know...
Justin Calkins - Iowa Falls, Iowa USA
1973 Yamaha DT3 - 250 - FOR SALE
Boss Framed Yamaha RT3 Flat Tracker - FOR SALE
2007 Triumph Bonneville America - 865
Calkins is offline   Reply With Quote
Old 11-21-2012, 08:47 AM   #2
caponerd
Kickstart Enthusiast
caponerd's Avatar
Oddometer: 1,980
I'd go with drums front and rear for riding in the dirt, even though I do have a modern dual sport with disks at both ends.
You just don't need that much braking power off the pavement.
caponerd is offline   Reply With Quote
Old 11-21-2012, 09:01 AM   #3
gravityisnotmyfriend
gravityisnotmyfriend's Avatar
Oddometer: 1,425
If you want to keep them the same, I'd go with drums front and back too. It'd be far simpler and for that light of a bike, the drums will work just fine. The only time you'd find drums insufficient is in a racing situation when you are on the brakes hard and frequent. They'll heat up and become useless.
For real world gravel riding, the drums will work just fine and be far simpler to install and maintain.
Of course, this is coming from a guy with a '71 CB 350 with a 360 front end so I could have a front disc brake.
gravityisnotmyfriend is online now   Reply With Quote
Old 11-21-2012, 09:27 AM   #4
Calkins OP
On Any Sunday...
Calkins's Avatar
Oddometer: 505
I had a '90 XT350 that I rode on pretty much only gravels for 1k miles last year. I rode it pretty hard. I rode it like a flattracker, trying to slide every corner I came to, then topping it out until the next corner. I guess, it was a mixture of flattrack and road racing.
I will have a nasty engine on this bike too. I think I will run the same Dunlop D606 tires that my 350 had. I love those!
Old 11-21-2012, 09:30 AM   #5
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 16,376
If it's gonna be mostly dry, go with drums but if you are in a lot of water maybe the disks will be better.
"The turd follows the fart as surely as the rain follows the plow."
Emily Bronte
Mista Vern is offline   Reply With Quote
Old 11-21-2012, 10:41 AM   #6
Calkins OP
On Any Sunday...
Calkins's Avatar
Oddometer: 505
Wicked
This is similar to what I want to build. But, with knobbies and probably mid-level exhaust...
http://www.bikeexif.com/yamaha-sr500-3
Old 11-21-2012, 01:59 PM   #7
anotherguy
anotherguy's Avatar
Oddometer: 6,207
Disc front and rear. So much more predictable off road. I have a 2003 CRF450R (disc F&R) and 1980 YZ465 (drum F&R) and the CRF is much less tiring to ride even though it's more high strung.
Old 11-21-2012, 05:32 PM   #8
Speed King
Speed King's Avatar
Oddometer: 1,634
I'd go discs.
Speed King is offline   Reply With Quote
Old 11-21-2012, 05:35 PM   #9
muschelschubser
muschelschubser's Avatar
Oddometer: 294
Discs for braking, drums for style?
Central East Tour
http://gespann.wordpress.com
The fastest way to yourself leads arround the world!
Richard Hoffmann (*1938 ),
muschelschubser is offline   Reply With Quote
Old 11-21-2012, 10:03 PM   #10
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,628
Why worry about having the same at both ends.
Most bike that had disc on them in the seventies only had them on the front. It works fine , they're seperate systems anyway.
If you are going to ride some asphalt , go with a front disc. On the rear as long as the brake has good feel , a drum will be fine.
The bike you show as your inspiration has a disc/drum combo.
bk brkr baker screwed with this post 11-22-2012 at 06:25 AM
Old 11-21-2012, 10:19 PM   #11
robtg
Oddometer: 665
If you are riding offroad, the XT drum brakes are light and have decent stopping power. Why change?
robtg is offline   Reply With Quote
Old 11-22-2012, 02:56 PM   #12
MZRider
Neo-Luddite
Oddometer: 704
I've never needed more braking power on or off road on my '77 XT500. Plenty of power, good feel, very little fade. Stops better than my riding buddies KLRs...
Charlie
http://www.AntietamClassicCycle.com
'69 Guzzi Ambassador,'77 Yamaha XT500,
'88 Ducati Paso, '91 ATK 604
'94 MZ Silver Star, '96 CCM 350
MZRider is offline   Reply With Quote
Old 11-22-2012, 04:46 PM   #13
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,532
Where is the disc front drum rear choice?
Vince @ SWFL or WNC
2001 Kawasaki W650
2012 Dong Fang DF250RTB
2013 Ice Bear PBZ110-1P sidecar
2015 Ural cT
Bar None is online now   Reply With Quote
Old 11-23-2012, 04:12 PM   #14
Calkins OP
On Any Sunday...
Calkins's Avatar
Oddometer: 505
Exactly my thoughts!
I really like drums. I had a '90 XT350 that I rode gravels with last year. I rarely used the front brake.
As I stated before, I have stock Yamaha parts to go with each of the ideas. My next project will be a XS650 which will get the same treatment. With that, I am leaning toward disc on both ends. That gets me excellent braking on pavement, if I get bored with dirt on any given day. Now, dual or single disc up front?
Old 11-23-2012, 04:42 PM   #15
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,503
Given the choice I'd go with single disc front and rear. I use a lot of rear brake on gravel, not for stopping but rear wheel control....and I notice on rear disc bikes my rear disc gets pretty hot. Single disc only on the front, enough stopping power and light enough.
motu is offline   Reply With Quote
Times are GMT -7.   It's 06:40 AM.
