Old 11-21-2012, 07:21 AM   #1
ColCook OP
ColCook's Avatar
Oddometer: 3
Yet Another DR350 clutch issue
OK so I had the regular 1992 DR350 bike lurching forward in 1st with the clutch in. I have ripped out the entire clutch and found the Hub and Lockwasher gnarled up a bit, its got new plates in it and I bought a 2nd hand clutch on ebay with all the parts I needed to replace plus a new clutch cable for good measure,
but before I put it all back together and find nothing has changed... The Spacer (part 3 in below diagram) and washer at the back (part 2) that the clutch sits on is jammed still and I can't get it out, I can upload a pic when I get home if that will help.
A) is this a problem or can I just sit the new clutch on it (it spins fine around it)
B) is there some special trick to getting it off?
Diagram
Cheers.
ColCook is offline   Reply With Quote
Old 11-21-2012, 08:41 AM   #2
dbarale
Squiddly slow
dbarale's Avatar
Oddometer: 907
If the new clutch has enough clearance to not drag you may be fine but I would still want to see the washer.
Wear on the washer is what creates the 0 clearance issue so I would not want to put it back together without taking a good look at it.
dbarale is offline   Reply With Quote
Old 11-21-2012, 08:57 AM   #3
ColCook OP
ColCook's Avatar
Oddometer: 3
Thats what worries me, so how do I get the bugger off without causing any damage to anything...
Old 11-21-2012, 11:29 AM   #4
ColCook OP
ColCook's Avatar
Oddometer: 3
Got it off, I had to get a screwdriver behind it and hammer it free, once it came loose I had to use the nail remover on a hammer to get it the rest of the way off, the washer was screwed and bent out of shape and so was the end of the spacer so just going to replace the whole lot! glad I persisted!
Times are GMT -7.   It's 10:26 PM.
