Old 11-26-2012, 04:48 PM   #1
Crackofnoon OP
Oddometer: 60
Mounting Tires?
Does anyone know if i can mount a tubeless type tire on a tube type rim?
i would be mounting these tires with tubes.
2010 klr650, putting on heidenau k60 scout tires.
thanks,
b
Crackofnoon is offline   Reply With Quote
Old 11-26-2012, 04:52 PM   #2
Murf2
Oddometer: 822
Yes you can but of course you'll have to run a tube.
Murf
Murf2 is offline   Reply With Quote
Old 11-26-2012, 04:53 PM   #3
SloMo228
World Class Cheapass
Oddometer: 1,721
I have mounted several tubeless tires on tube type rims with no problems. As you said, you need to run a tube, of course.
--------------------------- Steve----------------------------------------
'93 GL1500 frankenbike basketcase in progress
'96 DR350SE
SloMo228 is offline   Reply With Quote
Old 11-26-2012, 05:35 PM   #4
kubiak
Oddometer: 4,810
yes you can. run a tube and you are set!
Old 11-26-2012, 08:44 PM   #5
tundra61
I wish I had a title
tundra61's Avatar
Oddometer: 1,015
yes - i run the tubliss setup on my bike.
http://tubliss.com/
Lots but currently:
2011 Harley Road Glide
2012 BMW GSA
2012 KTM 350 XCF-W
tundra61 is offline   Reply With Quote
Old 11-27-2012, 08:25 AM   #6
Crackofnoon OP
Oddometer: 60
Suh-weeeet! thanks everyone!
Old 11-27-2012, 10:38 AM   #7
Myfuture_yourdebt
Oddometer: 372
Tubeless tires are generally harder to spoon on the rim than tubed ones. That being said, they are usually more rigid which means they're more likely to prevent an accident from a leaky or a blown tube because a flat tire will still kind of hold its shape.
Myfuture_yourdebt is offline   Reply With Quote
Times are GMT -7.   It's 03:56 PM.
