11-21-2012, 12:42 PM
#1 |
I used to be SCRay
Oddometer: 3,967
As I get older, the options of the bikes I've got get wider. Good, or what? Now, there is this developing situation where I want to take multiple bikes to specific events. I may even find it desirable to load the sidecar and do a drive/ride tour. pharqmoi!
I've never had a ute or 1 tonner. Any time I've wanted to cart bikes it's been in the box trailer, which has been fitted with rather rudimentary channels for the front wheels. I can just fit two bikes, with difficulty. Sooner or later, I'll have to lash out on another trailer. That's not the current question. From the experience of the many, what are the positives & negatives of a 'style side' ute against a drop sides, table top 1 tonner? Most obvious for me is that the ute is lower but, how hard is it to fit 2 full size motorcycles into a ute? Do I need a ladder to load bikes onto a 1 tonner? Beyond that, I'm listening.
rayb I taught Wall St how to crash Australian RD/RZ Owners Register http://tripodtiger.smugmug.com/ |
11-21-2012, 01:23 PM
#2 | |
Oddometer: 4,873
And he sees the vision splendid of the sunlit plains extended, And at night the wondrous glory of the everlasting stars. |
#3 |
Black Magic
Ex Ambulance LWB Commodore
Hi I had the very same predicament quite a few years ago and came up with this solution for carrying two road bikes to classic rallies.
![]() ![]() Tailgate can be closed even with a GL1000 Goldwing on board.
"Love is the condition in which the happiness of another person is essential to your own." Jubal Harshaw |
11-21-2012, 01:24 PM
#4 |
Oddometer: 1,810
As you say the ute is lower and has the wheel arches in the carry area. The table top is taller and has no wheel arches impinging on the goods area. Utes are only as wide as the cab. Where as the table top is wider than the cabin on 99.9% of table tops I see.
I know you are dealing with utes/table tops, but I caution that a good hot gal dipped trailer will last forever and each vehicle you have simply has to have a towbar and wiring. You can even have a trailer custom built to meet your needs and it just sits at home until you need it. There are many trailer builds on ADV to cover that side of things. Slightly off topic but has anyone ever seen fork tube failure in bikes that are tied down like vudu's above? Mate, nothing against what you do but I always wonder (I'm no engineer) whether fork tubes are designed or capable of being tied off like that and not eventually fail... I've only ever seen tie downs attached to handlebars or attached to custom brackets on the triple clamps. I know the strength in a long tube is in the vertical axis or along the tube. The weakest part is across the tube.
If you always do what you always did, you always get what you always got!
jtb screwed with this post 11-21-2012 at 01:31 PM |
11-21-2012, 01:40 PM
#5 |
Tester of Tooheys Old
Oddometer: 18,737
Ute - One tonners are just that much higher and harder to load / unload
Every day you should try and be as happy as a Dog with two dicks
11-21-2012, 01:44 PM
#6 |
Perpetual ponderer
Oddometer: 1,679
I used to load my Ducketty up on the tray of a 2006 Rodeo 4WD to go to the drags sometimes (when I was looking forward to REALLY getting into it, rather than riding home again!). The flat bed was 950mm off the deck, and every time I used to get up there and roll it backwards down the ramp my mates used to cringe and look away.........
Utes are generally MUCH lower, makes it 10 times easier to ride the things up and roll them off, normally they're about 650mm off the ground. Just to really confuse the issue, and your thought processes, might I suggest a van of some sort? Most of the guys at the drags take ther bikes in SWB Transits/Hiace/iLoad etc. Plenty of space for two bikes easily with change, lots of room left for tools and eskys, the load height is lower again (550-600mm), and the diesel vans use SFA fuel, so you can go to vintage meets twice as far away.
Every ride's an adventure if you can't ride for crap http://www.dragtimes.com/Ducati-Mons...lip-10329.html |
11-21-2012, 01:50 PM
#7 | |
Rankest of amateurs
Trailer is also lower for loading. We can debate this tomorrow
fayeslane 2002 Yamaha TDM900 BMW R80G/S BMW R80G/SPD |
11-21-2012, 02:19 PM
#8 | |
I used to be SCRay
Oddometer: 3,967
![]() And I suppose you made all the effort to restore them too? ![]() Good to see that the two bikes do fit into a ute. I should clarify that the 1 tonner is the first preference, but there are so many more utes around.
11-21-2012, 03:05 PM
#9 |
CRASHING BORE
Oddometer: 2,673
Did you see my trailer on Tuesdy...7' x 4'.6 " and I get my Kato in frontwards in the middle and the boys Hondas in backwards...it does need some better extra anchor points though....you can borrow it and try it if you like...no charge...you can fit the new anchor points and I wont charge for that either..
.. I fixt it...my way....gjr |
11-21-2012, 03:13 PM
#10 |
Oddometer: 843
Tripod I've had both styles over the years, both in 2 and 4 wheel drive,s and some of these started life as tubs but ended as trays. All my utes end up as tray-back,s
The advantages of a tray for me are its width for things like sheet metal & wide delivery's like the horse drawn carriages I build. Nothing getting in the way. No narrow openings at the rear door. Funny these are things inly now being addressed by the likes of VW. On a tray you get access from three sides when loading and tying down. With drop sides your gear isn't going to roll off. The down side is for some designs the floor is built too high particularly on the 4x4,s.When it doesn't need to be. Even a tub will have a higher floor than a trailer when it comes to loading up a ramp. This could be a problem with a bigger bike and a shorter person. I know of no musterers or cocky,s round here with tubs. They all have quads or 250dys on board loaded by ramp and all on 4x4,s so I guess its not too big a problem getting on or off. YouTubes full of fails though. Thats my thoughts. gateman screwed with this post 11-21-2012 at 03:19 PM |
11-21-2012, 03:19 PM
#11 |
Rankest of amateurs
Have to trailer it a lot Unc?
11-21-2012, 03:22 PM
#12 |
tEAM iDIOT
Oddometer: 5,606
I have a 91 2wd Hilux, and the wife has a 02 Falcon ute.
Ute is easier to load because it is lower, but the bike has to be loaded diagonally or the tail gate has to be down (I have a feeling hers is a space cab or something like that). My drop side really isn't that much worse to load (I load and unload by myself), I can fit two bikes easily with room behind them, and have had three bikes on at times.
tEAM iDIOT. The original, and still the best.
11-21-2012, 03:23 PM
#13 | |
Rankest of amateurs
11-21-2012, 03:28 PM
#14 |
Perpetual ponderer
Oddometer: 1,679
........and if you get an old Kombi like I had for a while, easy-peasy to roll the Ducati drag bike out the side door, roll out the side canvas and set up the little Weber and the kettle, then lounge in comfort in the back in a beanbag, much to your drag mates envy!
11-21-2012, 03:34 PM
#15 | |
(KTM quack)
Oddometer: 1,608
I blew a set of fork seals on my transalp...all I did was jump the ute off a cattle grid at about 140, got a little crossed up and shredded the utes tyres.... you'd think a 15 yo set of fork seals would cope ... Back on topic, I use a twin cab triton ute (98 model), it's JUST possible to get the tailgate up if you put the front wheel up on the wheel arch and park the bike diagonally (transalp or ktm 640). Most of the time I just leave the tailgate a little down (held in place with tie downs). Getting the bike on the back is a PITA. I use 2 of the alloy folding ramps and walk it up under motor. I expect one day it or I will fall over in the process. A trailer is much easier to load, but then it's also harder to park when you're going shopping but dropping the bike off at the shop at the same time ![]() A 4 wd ute gives you the flexibility of retrieving a bike out of the bush ...only done it a few times , but nice when you need it. |
