Old 11-21-2012, 02:16 PM   #1
mister mars OP
Oddometer: 1
Heating element on carb broke...
The heating element on my carb broke.
Must I replace this, or will the bike operate OK without it?
In SF Bay Area, California so not the same as Michigan...
Thanks for any help
mister mars is offline   Reply With Quote
Old 11-21-2012, 05:24 PM   #2
666
Agnostic and Orange
666's Avatar
Oddometer: 1,316
Thanks for any help
I had same issue - it broke when I was pulling wire out. I JBwelded it together and put it back.
Works fine.
You probably dont need it, but if you go up at elevation where it's colder you may freeze carb. Unlikely, but possible.
2006 KTM 950 ADV; 2006 KTM 525EXC; 2013 Tiger 800 street
Moab Ride Report http://www.advrider.com/forums/showthread.php?t=629423
Dusy Ershim Ride Report http://www.southbayriders.com/forums...ad.php?t=99109
666 is offline   Reply With Quote
Old 11-21-2012, 05:29 PM   #3
AdvGa
AdvGa's Avatar
Oddometer: 1,320
I had the same thing happen and did what the above post did with no problem until I got the New Part in:
#63 60031003000 -HEATING ELEMENT CARB. HEAT. 05 -about $10.00
AdvGa is offline   Reply With Quote
Old 11-21-2012, 09:23 PM   #4
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,024
YUP, they do that. I've broke a lot and found a lot broke. The 03-04's don't have these, do they freeze up?
"Son, you can't do both"
Old 11-21-2012, 09:58 PM   #5
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,980
Well I'm afraid they do.
I own a Dec 2003 and experienced carb freezing twice. The temp was 8C very damp weather and 12C raining. That is not very often, is it? in 9 years. The location was Greece in mountainous areas.
Cheers.
Old 11-22-2012, 07:43 AM   #6
triplenickel
triplenickel's Avatar
Oddometer: 2,428
If its already back together I wouldn't worry about it, order the part so you'll have it on hand next time you're in there. I probably went 50k without one.
07 SE
PG007
Times are GMT -7.   It's 05:40 PM.
