Old 11-21-2012, 09:39 PM   #1
pipeburn OP
Oddometer: 77
Dream Project.
I got this bike a little while back, but just really started working on it. I heard the bike run before I bought it, but I knew that the clutch wasn't disengaging and the transmission might be hurt. After playing with it for a little while I decided that the tranny was indeed completely knackered.
Just a couple hours of work after deciding to pull everything apart.
There are already some unpleasant surprises, and I have yet to split the case.
In addition to the visible rusty spots, 4 links of the centrifuge chain are completely rusted together. Guess it's time to start the parts list...
It also came with some interesting sludge in the bottom of the side cover.
Next step is carrying it down to the basement and pulling the bottom off.
Though I may to find a manual before I do that..
pipeburn is offline   Reply With Quote
Old 11-21-2012, 10:12 PM   #2
flemsmith
lurk
Oddometer: 298
Book,,,,
I once built one of these; there was a very helpful book by a guy named Bill Silver. I let mine go with the bike, but it's worth trying to find one if you can find a used cc. At the time there was a club called the Vintage Japanese Motorcycle Club which was helpful for parts sourcing. Good luck, you'll get lots of attention from old guys like me.
Roy
flemsmith is offline   Reply With Quote
Old 11-22-2012, 04:23 AM   #3
manxkipper
Fishpistel
manxkipper's Avatar
Oddometer: 230
If that is a 305cc late 60"s honda twin then the below links may help. Cost free too!
http://www.mediafire.com/?dano05xtt4q34qx shop manual
http://www.mediafire.com/?92p07da77skdtsj owners manual
http://www.vintagehonda.net/docs/cb77pc.pdf parts list with diagrams
Aprilia Tuono
Norton 650 Mercury
Moto Guzzi LM2
1936 BSA Y-13 Project
manxkipper is offline   Reply With Quote
Old 11-22-2012, 05:16 AM   #4
max57
max57's Avatar
Oddometer: 56
That is my favorite motorcycle. A fine machine. One of the bikes that can be truly economical transportation.
"Deep in the heart of every human being...the drive to demonstrate competence." R. Buckminster Fuller
max57 is offline   Reply With Quote
Old 11-22-2012, 05:36 AM   #5
Bloodweiser
honestly
Bloodweiser's Avatar
Oddometer: 2,264
the carrot seed - honest country.
Bulletproof VS. Bloodweiser - yamaha world super GP TT 5000
BW - 455 : BP - 100
Bloodweiser is offline   Reply With Quote
Old 11-22-2012, 09:29 PM   #6
anonny
What could go wrong?
anonny's Avatar
Oddometer: 4,985
Awesome, I'm in
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 11-22-2012, 11:01 PM   #7
nsu max
Oddometer: 378
I'm in to. You'll love it! It's a sweet running bike.
nsu max is offline   Reply With Quote
Old 11-23-2012, 08:53 AM   #8
lrutt
SILENCE.....i kill you
lrutt's Avatar
Oddometer: 812
Looks like you have a challenge there. Too bad those main bearings are rusted. But from the looks of all the goop on the base gasket, it probably wouldn't hurt to tear it down and get a good look at things.
Good thing tha front fender is in nice shape. that was usually one of the first things to get buggered.
They are a nice bike but geared way to low and with that single puny little carb the leave a little to be desired for acceleration. Regardless, I love mine and have had it since 1980.
Check out the 305 forum if you haven't see it yet.
http://www.honda305.com/forum/
Gratuitus pic of my baby:
2004 Harley Sporster 1200C, 2001 Ducati M900, 2001 Honda XR650L, 1994 Harley Heritage, 1978 Honda CB750K with sidecar, 1977 Moto Guzzi 850 LeMans, 1976 Honda CB750K, 1965 Honda 305 Dream, 1973 Norton 850 Commando, 1971 Triumph Trophy 650, 1970 Honda Trail 90, 1970 Triumph Tiger 650, 1973 Honda Z50, 1984 Yamaha Virago 1000, 1981 Honda Passport 70, 1970 Suzuki T250, 1971 Yamaha RT1 360
lrutt is offline   Reply With Quote
Old 11-24-2012, 04:28 PM   #9
pipeburn OP
Oddometer: 77
I got the rest disassembled, results below.
The head and cylinders were solidly stuck together, so they stayed together.
They seem to be missing a few pieces...
You can't get a crank with that kind of corrosion just anywhere.
5 gear teeth and a piece of rubber. I don't think all the metal is accounted for yet.
Old 11-24-2012, 06:18 PM   #10
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 3,470
Bummer. I hate it when Dreams become Nightmares.
http://jupiterhack.blogspot.com
Living proof you shouldn't play with matches
Old 11-25-2012, 12:29 PM   #11
jellycow
out there & loving it
jellycow's Avatar
Oddometer: 485
Really, with that kind of rust inside and pieces missing of the pistons?
[Sir Mix-a-lot mode]
I like big tanks and I cannot lie
[\Sir Mix-a-lot mode]
jellycow is offline   Reply With Quote
Old 11-25-2012, 07:17 PM   #12
anonny
anonny's Avatar
Oddometer: 4,985
What year is it? I have 2 Dreams waiting to be turned into 1 so there should be a spare motor or lots of spare internals. Alternatively if you give up on the project I see a few parts I'd like to purchase from yours.
Unfortunately I wont be getting to mine until late winter/ early spring because my CL needs to be finished off first.
Old 11-25-2012, 09:14 PM   #13
pipeburn OP
Oddometer: 77
Very little of the rust was in a place that was crucial to engine operation. even the rusty main bearing is still tight, it just won't last too long like that. The pistons are just damaged on the skirt. The sharp edge is the only real danger, one could probably file the edges a little and run them for thousands more miles. Most newer motors have much shorter skirts anyhow. Otherwise the pistons look to be in great shape, not really any signs of blow-by. However the transmission was not at all functional, which is why I disassembled it in the first place.
It's a 1964. My preferred option would be a spare motor as well, but I definitely need a main shaft and a first gear.
Old 11-26-2012, 03:57 PM   #14
ValuePack
Oddometer: 23
Subscribed, hell of a cool project you've got there. I eye Dreams longingly on Craigslist from time to time, really need to get one in the stable.
ValuePack is offline   Reply With Quote
Old 11-26-2012, 06:02 PM   #15
Bloodweiser
honestly
Oddometer: 2,264
I'll take it if pipeburn doesn't want it.
BW - 455 : BP - 100
Times are GMT -7.   It's 08:05 AM.
