Old 01-06-2012, 09:49 AM   #1
HeadinSouth OP
vroom!
HeadinSouth's Avatar
Oddometer: 96
Change to LED Signals
I did a search and couldnt find anything. My answer is probably buried in another thread.
Anyone switch to aftermarket LED signals and what was the outcome? I know from my passed experience on my DRZ the LEDs flashed much faster.
Thanks in advance.
HeadinSouth is offline   Reply With Quote
Old 01-06-2012, 10:06 AM   #2
dendrophobe
Motorbike Junky
dendrophobe's Avatar
Oddometer: 859
LEDs flash faster because there's less resistance... You can fix that with a flasher relay, it's pretty simple.
LED signals work fine on this bike, you just have to use the right relay if you want it to work properly.
If you need to find the relay, Highway Dirt Bikes has it, and some nice LED signals too.
Doug
Semper Fi
2009 BMW F800GS, Olive Drab
2006 Ducati Sport 1000, Black
Custom built Ducati GT1000 Scrambler, Red
dendrophobe is offline   Reply With Quote
Old 01-06-2012, 11:48 AM   #3
GB
Mod Squad
GB's Avatar
Oddometer: 56,906
I put the BMW OEM LED turn signals, plug and play.
Remember, on newer GS's, they terminate with an OEM molex type connector, so if you're using aftermarket turn signals you might have to cut those off or get a OEM conversion kit.
Old 01-06-2012, 02:42 PM   #4
GH41
Oddometer: 822
I am also interested in the OEM LED signals. Are they that much brighter than the bulbs?? GH
GH41 is offline   Reply With Quote
Old 01-06-2012, 03:23 PM   #5
SportFaller
Dirt dont hurt, MUCH
SportFaller's Avatar
Oddometer: 668
I love my LED BMW signals, plugged straight in! cant find a pic right now....
"The chokers, and the chain saws, and the log trucks have been stilled, now spotted owls, and hippy gals, run freely through the woods!"
Bikeless in WY
http://www.dakotadualsportriders.com
SportFaller is offline   Reply With Quote
Old 01-06-2012, 03:34 PM   #6
xxxshiftxxx
Oddometer: 207
Thanks in advance.
Here are some plug and play ones...
http://www.weiserstore.com/bmw/dual-sport/f800gs.html
xxxshiftxxx is offline   Reply With Quote
Old 01-06-2012, 04:57 PM   #7
GB
Mod Squad
GB's Avatar
Oddometer: 56,906
There are 2 large LED's that are super bright.. you can't judge how bright with a picture.
Had those on a previous bike.. in daytime, I would say they are barely on par with stock incandescent bulbs.
Old 01-06-2012, 04:59 PM   #8
dualsportride
Oddometer: 262
My local bike shop had resistors for 5 buck that you wire in very easy, and it will slow down the flashing. That way you can put any type of led light you want on your bike.
www.usdualsports.com
dualsportride is offline   Reply With Quote
Old 01-06-2012, 05:02 PM   #9
GB
Mod Squad
GB's Avatar
Oddometer: 56,906
Not necessarily true, because if the power consumption is too low or too high for the ZFE parameters, you will get a LampF (fault) on the LCD display and that circuit will be shut down.
Old 01-06-2012, 05:04 PM   #10
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 594
I recently changed to the HDB signals. I purchased the Flash Killer relays to slow down the rate but found that they were not needed and the lights worked just fine without them. Details coming soon in another build thread.
Dan
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 01-06-2012, 05:08 PM   #11
puckinet
Safety third
puckinet's Avatar
Oddometer: 346
BMW and touratech has a resistor in the LED so you would be able to install no issues, if you use others without a resister and replace all four you need a soild state flasher, SAR (sick ass racing )has them pretty cheap. If you only replace 2 of your turn signals with LED you have no problem with the OEM flasher
Our famous last words "It doesn't look too bad".
08 KTM 450 EXCR
2010 BMW F800GS
Rick
puckinet is offline   Reply With Quote
Old 01-07-2012, 06:15 PM   #12
Spinalcracker
former redriderofma
Spinalcracker's Avatar
Oddometer: 1,089
Does anybody have a part number or link for the BMW LED turn signals ?
Unless we change direction, we are likely to end up where we are headed.
It's county Fair time in New England
TET MA to NC
Vermont Covered Bridges
Spinalcracker is offline   Reply With Quote
Old 01-07-2012, 06:22 PM   #13
GB
Mod Squad
GB's Avatar
Oddometer: 56,906
A&S Cycles has them on their online store, or check Max's microfiche...
http://www.ascycles.com/detail.aspx?ID=56161
#Part Number DescriptionlbQtyEach
01 63137708048 LED FLASHER0.11 2 $58.00
02 63237710574 LED TURN SIGNAL, BRACKET, LONG, REAR0.11 2 $58.00
03 11117653180 FILLISTER HEAD SCREW - M6X200.02 4 $1.40
04 07129904871 HEX NUT - M6-8-ZNS3
2 $1.42
05 51127070202 CLIP NUT - M6-ZNS3
2 $1.16
GB screwed with this post 01-07-2012 at 06:27 PM
Old 01-09-2012, 07:50 PM   #14
BcDano
One Lucky Dude
BcDano's Avatar
Oddometer: 325
Put sets on both of our bikes. Perfect fit and function. Very happy with how they bright they are. Great service from the boys at Adventure Designs..
http://www.advdesigns.com/ulbrledbl.html
BcDano is offline   Reply With Quote
Old 01-14-2012, 10:29 AM   #15
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 594
Just another twist on this discussion. I have switched my OEM blinkers to Highway Dirt Bike LED's and interestingly if you change all four then the blinking rate is normal, but if you leave two of the OEM incandescent lights, the rate is very high. The problem comes in that even though the rate is OK with the 4 LED's, the computer still displays an error code. Unlike on most bikes, on the F800GS the flasher relay is integral to the computer and therefore you cannot simply add an aftermarket flasher relay (as mentioned above) as there is no place to put it. In addition to this I tried to use Wunderlich "Flash Killers". This is a series resistor that is supposed to be wired into a pair of blinkers to increase the resistance and fool the system into thinking that its still running incandescent bulbs. Good idea, unfortunately I couldn't get them to work and by wiring in either one or two of these, the blink rate still increases and you still get the error code. I am currently planning on just running the LED's and living with the error code but it is a bit frustrating and I'm still looking for a solution.
Dan
Times are GMT -7.   It's 07:01 AM.
