11-22-2012, 03:48 AM
#1 |
Oddometer: 262
Gaskets O rings for carbs
Do I need to buy any just to alter the needle ?
Cheers |
11-22-2012, 05:13 AM
#2 |
Where fun goes to die....
Oddometer: 3,231
Depends on age and condition of carbs sudco can provide you with most individul parts google them.
DSM8 - A different kind of mean SQL > SELECT finger FROM hand WHERE id=3 WWW.DSM8.whereamiriding.com |
11-22-2012, 05:40 AM
#3 |
AWD please!!
Oddometer: 3,867
No, the small o-rings that cause gas leakage are on the gas inlet barbs.
You won't be near those when you adjust needles. Inspect the diaphram and make sure its seated properly when reinstalling the black plastic cap. These can rip with age. We have all these items in stock if you need them.
My 2006 950S thread. 2006 950s updateNew product updates here! Wordpress BLOG click www.cjdesignsllc.com for the full line of products. www.outriderjournal.com FREE STUFF!! |
11-22-2012, 07:14 AM
#4 | |
let's keep going...
Oddometer: 988
However waiting several hours (overnight usually) when you try again the o-rings don't leak. Seems the gasoline causes them to swell & they fix themselves... DAMHIK CJ, good to know you've got the o-rings in stock, they're tricky to find!!! take your time & all should go well; make sure you use a quality screwdriver so you don't damage the Phillips scews.
Britt '06 KTM 950 Adv 'S' '03 KTM 250 EXC '88 KLR650 - +170K miles "looks like you've had a lot of fun on that bike..." |
11-22-2012, 07:33 AM
#5 |
Oddometer: 262
Thanks for the info, one more thing......
Should I try to get the 2 carb vent hoses into a more 'still air' place than just under the air box? I have read doing a 2 into 1 with a small filter can cause probs. I was thinking of doing this and tuking the filter up under the dash somewhere. The symptoms I am trying to fix is a slight surging at highway speed around 4000 rpm. Worse in gusty wind conditions. Also picking the revs up slowly in neutral they take off at around 3000 and shoot up to 5-6000 Starts fine(warm weather here) pops a bit on decel, standard filter with prefilter, valves done, fuel pump Faucet, 95 octane, 42 pilot jets, Gualdi slip ons. I was thinking of raising the needle, lowering the clip one notch. If this dosn`t work, I will try 43 pilots. Also the TPS I will be checking. One of these things must make it better......and smoother. At around 5000 she buzzes quite a lot. I feel it in the footpegs, tank and seat. :( How does that sound to ye of knowledge ? rossguzzi screwed with this post 11-22-2012 at 07:57 AM |
11-22-2012, 11:51 AM
#6 |
I <3 Energizer Bunny
Oddometer: 574
Stock jetting? They tend to come lean at cruise rpm, 4000.
ALSO, I have a bag of those weird sized o-rings in viton. Anyone who needs any, let me know. I've sent a bunch of them out to folks here already. Price = free / owe me a beer. Send me a SASE, pm for address.
Yet Another New Air Filter for the KTM 950 - $150 Sporting Wood screwed with this post 11-22-2012 at 03:29 PM |
11-22-2012, 05:38 PM
#7 |
Oddometer: 262
As far as I know it is stock jeting. The mech that did the valves checked the jets, not me.
Incoming PM re o rings . Cheers. |
11-22-2012, 05:48 PM
#8 |
Oddometer: 574
Surging is most often a lean condition, but can also be vents, sync, a missing hose on one of the intake taps, pinched carb grommits or a loose carb boot. If it didn't do it prior to the wrench, somethings loose. If its not a fault with assembly, and it did it prior to the wrench, you've likely got f'd jetting...and if you're running the prefilter with stock settings thats likely your problem imho.
Yet Another New Air Filter for the KTM 950 - $150 |
11-22-2012, 08:31 PM
#9 | |
MotorcycleMayhem
Oddometer: 2,155
7/32" vacuum hose (not fuel hose), front 11" and rear 10", will run down through the bottom airbox and terminate down next to the starter. Works well, 100s of 1000s of miles with this setup.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla 2008 KTM 690 ADV- 2006 KTM 970 frankinADVsmSD ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
