Old 12-30-2008, 06:18 PM   #1
been saved OP
been saved's Avatar
Oddometer: 88
Eek Need the Carb gurus to SAVE me!!
I have been stymied by my Daughters 2001 Dr200. This little bike has always run great, Slow but like a tractor. Here is the story
A) been running it without an airbox lid since a high altitude ride where the lid got "lost"
B) all of a sudden bike started barely running and battery was not holding a charge.
C) Changed battery but bike stumbles and is not right
D) cleaned carb (lots of gunk) and it stumbles till throttle is over about 1/4 then it runs fine, idles fine also.
E) Drilled out mixture screw and cleaned this passage also with compressed air
F) been playing with turns in and out with mixture screw but even at only TWO turns out it is blackening the plug and still stumbling horribly until it revs above 1/4 throttle. Correct me if I am wrong but "in" is leaner and "out" is richer, how in the world is it blackening the plug at two turns with no airbox lid???
I thought 6 turns would be good, but it is stumbling. I have been suprised by the black sparkplug at only TWO turns out. It will spin the tire once it is reving but NO bottom end. I did have one issue with cleaning, the pilot screw was sticking when I was removing it and after reinstalling the screw after the second cleaning I now have a pilot screw with NO flat head receptacle. Could this damaged pilot screw be allowing too much fuel into the "idle circut"? I assume the only way to get the screw out would be to use an easy out and then replace it.
Would like to get this sorted so the Daughter and I can get some riding/camping in prior to a planned COLO summer week long ride(OOOOHHHH YEA) she is 16 and progressing nicely as both a rider and a young lady.
What say you intrepid ADVers, I am a little low feeling on this as I also embarked on replacing the tiny front forks on my 91 DR650S with SWEET USD RM forks and hit a couple of unforseen snags with stem length and diameter (DRAT perse, as it were). I mean doggonit how hard can this little thumper be to work on!!!!
been saved is offline   Reply With Quote
Old 12-30-2008, 07:16 PM   #2
Bladeforger
Bladeforger's Avatar
Oddometer: 116
Well, I ain't a guru, but I have some thoughts for ya. Bout everyone says that the little DRs are more sensitive than the 350s and 650s to any changes in the fuel system. The first "change" was losing the airbox lid. What has happened to the air filter since then?
When you cleaned the carb, did you take it all apart? Did you clean the primary jet (aka pilot jet)? What you're describing is the primary circuit: from idle up to 1/4 throttle.
Does turning the mixture screw in or out change the way the bike runs at idle? If so, good. If not, you have the wrong primary jet or it's dirty.
Betcha Jesse at Kientech has a replacement carb for sale. If not, maybe something like this
TM28 on ebaymotors
I think you probably have a BST Mikuni right now.
However, before buying a new one, I'd look at the primary jet. Also Jesse sells the Jet Kit for DR200
Hope this helps at least some. If not, it was a simple case of the blind leading the blind again.
KLR650
DR350 (sold)
KLX250
"Obsolete doesn't mean a thing isn't any good--it just means they don't make it anymore" Von Dutch, May 1970
Bladeforger is offline   Reply With Quote
Old 12-30-2008, 08:45 PM   #3
been saved OP
been saved's Avatar
Oddometer: 88
A) Air filter not as bad as you would think, been running that way for about 1.5 years.
B) Yes every thing came out, even had to drill out the brass plug the second cleaning to get the mixture screw out
C) Yes if it is all the way in it will not even start, backed out 2 - 8 turns and it will idle but that stumble moves around a bit.
TM28 on ebaymotors
D) yes it does have the BST, I actually also emailed Jesse tonight to try and get his thoughts.... we shall see.
E) Jet Kit will probably be ordered since it has the extended fuel mixture screw.
Thanks VERY Much all help and ideas are appreciated!!
Been Saved
Old 12-30-2008, 09:42 PM   #4
BobCWNC
Orange lithotripter
BobCWNC's Avatar
Oddometer: 13,041
Your batteries not holding a charge? It stumbles till you rev it? Could it be a bad battery, reg/rec, stator or other charging issue?
Don't know specifically about this bike, but others I've had wouldn't run right with bad electrics.
Edit. reread amd saw that you changed batt, but does it run fine and change how it runs once the battery dies?
__________
"It is a great art to saunter". Thoreau
“Life’s most persistent and urgent question is– what are you doing for others?” –Martin Luther King, Jr.
Alan Greenspan said out loud, “I have found a flaw.” Waxman pushed him, responding, “In other words, you found that your view of the world, your ideology, was not right; it was not working.” “Absolutely, precisely,” Greenspan said
BobCWNC is offline   Reply With Quote
Old 12-31-2008, 07:13 AM   #5
been saved OP
been saved's Avatar
Oddometer: 88
No Battery is good and strong (110.00 worth of strong) it seems to be a fuel issue.
Old 12-31-2008, 07:45 AM   #6
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,973
If the you say that the carb had a bunch of gunk in it, did you check the petcock filter? Also check the choak plunger to make sure it is not held open by gunk.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 12-31-2008, 04:04 PM   #7
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,690
The damaged jet may be an issue, but probably not unless you somehow opened it up when trying to clean it. It is screwed in all the way, right? As I recall the standard setting for the mixture screw is 1 1/2 turns. It should be quite sensitive to small changes, so 2 turns would still be way rich. If it will idle, try screwing the mixture screw in until the RPMs peak, the back it out maybe 1/16 of a turn. That should give you the best performance. I can't stress enough as to how clean the carb needs to be. The low speed jets, in particular, have tiny orfices that must be totally clean for it to run right. I think there is also a low speed air jet that will affect this whole deal, too. If your air cleaner is deteriorated, particles from that may be causing trouble as well.
Good luck and keep us posted with your results.
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper
Andyinhilo is offline   Reply With Quote
Old 12-31-2008, 04:46 PM   #8
been saved OP
been saved's Avatar
Oddometer: 88
This may be the big issue, I think I need to start at about one turn and work into 1.5 - 1.75 turns I will try this tomorrow and if all else fails send it to Jesse at Kientech for a performance jet kit and the pipe mod (she and the wife are begging for an F650 but they gotta master the DR first)
Been Saved
Old 12-31-2008, 06:38 PM   #9
mykill
odd
mykill's Avatar
Oddometer: 1,166
stumble
If the jets are undamaged, you should verify the float height is good. Float needles wear and will raise float height causing a rich running condition that you cannot fix with adjustments. Floats also may be sinking or not moving freely.
mykill is offline   Reply With Quote
Old 12-31-2008, 09:05 PM   #10
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,690
1+
Old 12-31-2008, 10:44 PM   #11
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,754
Its real lean on the pilot jet with the lid removed..
I had a KLX300 do this after removing the air box lid. I had to rejet it so it would run right with the lid off..
Buy another lid or rejet it...
Originally Posted by WaterWheel View Post
The things I would do with that old broad would make a seasoned porn producer puke.
KTMSER is online now   Reply With Quote
Old 01-01-2009, 07:00 AM   #12
been saved OP
been saved's Avatar
Oddometer: 88
1+
"Go soothingly on the grease mud, as there lurks the
skid demon! Press the brake foot as you roll around
the corners, and save the collapse and tie up."-
1962 Honda Motorcycle owner's manual
HAHAAH that is classic. Stupid grease mud.
Been wondering about the float, but wouldn't that cause the gas to overflow through the overflow line (or am I remembering a througback from my old CB)
Been Saved
Old 01-01-2009, 08:22 AM   #13
ram1000
ram1000's Avatar
Oddometer: 1,834
Look fr a pinched air breather line coming out of the top area of the carb.
A good adventure bike will get you to where you wish you had a good dirt bike! (and back)
:2014 XC800 :2012 WR450
ram1000 is offline   Reply With Quote
Old 01-01-2009, 11:26 AM   #14
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,690
Been Saved
The float, if stuck can allow the fuel to overflow or not flow at all. If mis-adjusted, it can cause lean or rich conditions as well. As a suggestion, you might get a sheet of foam (like the air filter is made of) to put in place of the airbox cover. That could help with any issue caused by loss of the cover.
Watch the grease mud, nuke the skid demons, and have a good new year!
Old 01-01-2009, 01:57 PM   #15
straight cut
Oddometer: 136
Get the airbox lid back on again and then start setting up the carb
lid pt no 13740-42A00
or just sick a piece of alloy sheet over the hole and silicone it down
straight cut is offline   Reply With Quote
Times are GMT -7.   It's 10:41 AM.
