Old 11-14-2012, 04:32 AM   #1
muschelschubser OP
muschelschubser's Avatar
Oddometer: 283
Flat Twin Mistery
Whats that? "MG" letters stamped on some parts. Estimated 400 cc.
Central East Tour
http://gespann.wordpress.com
The fastest way to yourself leads arround the world!
Richard Hoffmann (*1938 ),
muschelschubser is offline   Reply With Quote
Old 11-14-2012, 03:21 PM   #2
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 12,881
No idea here. Possible someone in the Airheads thread might have a clue, so post it there also?
Remodeling. Please check again later.
Mista Vern is offline   Reply With Quote
Old 11-14-2012, 07:02 PM   #3
davevv
One more old rider
Oddometer: 2,204
Just a guess, but Moto Guzzi built some odd stuff many years ago. Would explain the MG.
"Fast is fine, but accuracy is everything"--Wyatt Earp
'09 Electra Glide Classic
'04 Sportster XL1200R
davevv is offline   Reply With Quote
Old 11-15-2012, 12:45 AM   #4
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 355
Marusho lilac 500cc?
Kt-88 is offline   Reply With Quote
Old 11-15-2012, 12:46 AM   #5
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 355
Nope. Changed my mind. Front cover is all wrong.
Old 11-15-2012, 01:51 AM   #6
Scrivens
Scrivens's Avatar
Oddometer: 294
I've gone through all my reference stuff and can't find anything like it for Europe, Japan or England between 1930 and 1960 over about 20 known makers of motorcycle flat twin engines. It looks like a number of European engines - Hoffmann for one - but nothing has heads like that, or the gear selector dial. Judging by the kick start and the very long carb inlet tube, are you sure it is a bike engine? Those carbs would stick way out in the breeze, and a pressed steel kickstart is pretty unusual. One of those two cylinder Euro utility vehicles perhaps? If there are any markings o the carbs or the spark plugs I might be able to narrow it down.
Scrivens is offline   Reply With Quote
Old 11-15-2012, 03:32 AM   #7
muschelschubser OP
Oddometer: 283
Originally Posted by Scrivens View Post
I If there are any markings o the carbs or the spark plugs I might be able to narrow it down.
Sparks are Isolator from former GDR.
Central East Tour
Old 11-15-2012, 05:24 PM   #8
wmax351
Oddometer: 740
Maybe a Velocette?
wmax351 is offline   Reply With Quote
Old 11-15-2012, 05:57 PM   #9
motu
Loose Pre Unit
motu's Avatar
Oddometer: 3,952
The LE was sidevalve.
motu is offline   Reply With Quote
Old 11-15-2012, 08:13 PM   #10
Nailhead
Painting by numbers
Nailhead's Avatar
Oddometer: 5,383
I love threads like these.
-Chris
'04 GS Adv- A fond memory
'07 990 Adventure- still bonding...
How hard can it be? - Jeremy Clarkson
Nailhead is offline   Reply With Quote
Old 11-16-2012, 06:42 AM   #11
Scrivens
Scrivens's Avatar
Oddometer: 294
The style of the castings and engineering and the general finish and colour of the alloy makes me think it is Hungarian, Romanian or Polish of late 40's to mid 50's vintage, but despite an exhaustive search I can't locate anything just like it. There are hints in the engineering of 30's styles, especially the gear indicator section, but I feel it is from the later period. It bears a resemblance to a number of engines from those places and periods, but none of them have the same heads or the style of rounded gearbox with no mounts for an airbox. It looks like it could be a derivative of the early Zundapp small capacity flat twin, but there are too may differences - push rod locations, heads etc, to take that much further. Given the type and location of the carb inlets I still think it is out of a two cylinder car or utility vehicle though most of the Eastern bloc ones used the flat twin 2 stroke engine. If it is from a car etc, it is unusual in having twin carbs as most had a Y manifold with a single carb in the centre of the engine. I've gone through all the Soviet era car twin cylinder engines as well with no luck, so I'm stumped.
Is that a gear lever on the left and what does it have on the end of it? If you can get some full side on pics and a few other close ups from various angles we may be able to get a bit further on.
Old 11-16-2012, 06:50 AM   #12
Scrivens
Scrivens's Avatar
Oddometer: 294
Just a thought - a military vehicle might be a possibility. There were all sorts of small tracked vehicles kicking around at that time. A military or other utility usage is also likely because the engine is unidentifiable. Many of the bikes and cars of the period have been collected or restored so their engines are known via photo or blueprint and can be quickly identified, but this one can't have been used in anything common unless it was of a vehicle type not attractive to restorers. Hope that makes sense.
Scrivens screwed with this post 11-16-2012 at 07:01 AM
Old 11-16-2012, 07:16 AM   #13
muschelschubser OP
Oddometer: 283
Guess you are caught, I surely am!
Central East Tour
Old 11-16-2012, 09:27 AM   #14
muschelschubser OP
Oddometer: 283
It seems to be a single made Motocycle build in a romanian Jail. http://gespannreise.regina-vetter.ch/?paged=5
there you find a little bit more.
Central East Tour
Old 11-16-2012, 10:19 AM   #15
drhach
gorillamanufacturing.com
drhach's Avatar
Oddometer: 1,880
So, more importantly, what do you plan to do with it? You can't just let it sit there.
1976 R90/6
1972 XLCH
2010 Triumph Thunderbird SE
drhach is offline   Reply With Quote
Times are GMT -7.   It's 04:46 PM.
