Old 11-27-2012, 10:06 AM   #16
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,231
You better hope the new switch works. If it is Ghosts special procedures are required and they sometimes do more harm than good it seems.
---Albert Einstein
disston is online now   Reply With Quote
Old 11-27-2012, 10:12 AM   #17
NC BMW Rider
Oddometer: 105
Originally Posted by khale View Post
Thanks, Bill. I did as you said. Ignition on, oil light is ON. I pulled the connector on the oil pressure switch and the light remained ON on my gauge. Does this mean bad sensor or a ghost in my electrical system? (man, I hope not). I've already got another oil pressure switch on the way anyways.
Sounds like the wire leading from the sensor is grounded somewhere between the sensor and the light. If you moved a bunch of wires around when you converted to LED's some insulation may have broken and now you are grounding somewhere along the wire.
Good luck.
NC BMW Rider is offline   Reply With Quote
Old 11-29-2012, 09:31 AM   #18
khale
ride dirty
khale's Avatar
Oddometer: 557
Good luck.
thats a very good point. I'll investigate
2013 BMW R1200 GSW | 1972 BMW R75/5 toaster | 2011 Husky TE310
"4 wheels move the body, 2 wheels move the soul"
khale is offline   Reply With Quote
Old 11-29-2012, 03:17 PM   #19
khale
ride dirty
khale's Avatar
Oddometer: 557
Good luck.
You were exactly right. There was no insulation on the connector for the oil pressure switch bulb and a brown wire was in close contact with the wire, causing it to ground out.
Thanks for everyone's help.
I'm also very glad I wasn't actually subjecting my engine to low oil pressure as well.
Times are GMT -7.   It's 02:45 PM.
