Old 09-01-2012, 12:22 PM   #1
gettinold OP
Oddometer: 4
Lc4 640 Extremely stuck choke plunger
Hello, anyone have tips on removing a brass choke plunger that's stuck tight in the carb..... Ok I have a 2000 KTM Lc4-e 640 with 9900 hundred miles. Problem is the choke cable broke right where it connects to the brass plunger or what-ever it's called inside the carb. I've soaked it daily with wd-40 with absolutely no effect. Currently the plunger is all beat up from attempts to pull it out and now there is nothing to grab hold of to get it out. My next step was going to be drill and tap the plunger and try screwing a bolt in to have something to pull the plunger out with. But I wanted to see how others have gone about this removal task. Appreciate any tips. Thank you......
gettinold is offline   Reply With Quote
Old 09-01-2012, 12:44 PM   #2
Sacal
Sacal's Avatar
Oddometer: 119
Can't say i'm familiar with that carb, so don't know if there is a circlip or something holding it in. BUT...if you are certain its metal on metal stuck, I would hit it with a blowtorch and heat that sucker up get it hot through like you are removing a bearing...of course you still need something to get hold of.
Im sure someone with knowledge of this particular carb who experienced the same issue will be along soon....good luck, hope you get her fixed and back riding soon!
ad astra per alia porci
Sacal is offline   Reply With Quote
Old 09-01-2012, 03:03 PM   #3
Groundhog
Groundhog's Avatar
Oddometer: 186
Compressed air? If you have a circuit diagram you should be able to find a port that leads to the back side of the plunger. Maybe?
Groundhog
Horsepower determines how fast you hit the wall. Torque determines the size of the hole you make.
Groundhog is offline   Reply With Quote
Old 09-01-2012, 05:28 PM   #4
charlie264
charlie264's Avatar
Oddometer: 5,036
Bottle of malt vinegar.
Old 09-01-2012, 06:13 PM   #5
r77toy
Oddometer: 336
Blowtorch and carburetor, make sure you post video.
r77toy is offline   Reply With Quote
Old 09-01-2012, 07:09 PM   #6
itsatdm
NoMoTDM still Gary
itsatdm's Avatar
Oddometer: 3,711
That plunger is loose fit, I can't imagine it being stuck. I assume you have removed the fitting (plastic?) and spring.
Old 09-01-2012, 09:27 PM   #7
Aussie Steve
Aussie Steve's Avatar
Oddometer: 1,313
Think its fairly common for these to get stuck in place on bikes that dont use the choke often.
Would expect carbon and varnish to be holding it in place rather than corrosion, maybe better off trying carby cleaner or acetone to loosen it rather than wd40? (guessing here). Would definitely try to apply it through the choke passages rather than behind the plunger.
Aussie Steve is offline   Reply With Quote
Old 11-22-2012, 05:51 PM   #8
gettinold OP
Oddometer: 4
Yea I removed the plastic and spring, used 10 different solvents and the like and nothing. I ended up using a number 7 drill bit to drill a hole about 3/8" into the plug then used a 1/4"-20 bottom tap and put some threads in the plug. I then screwed in a 3" s.s. hex head 1/4"-20 bolt into the plug, and after an hour of pulling on the bolt then tapping it in, went back and forth till it finally came out. The plug looks like it fused to the inside of the carb.
Old 11-22-2012, 09:46 PM   #9
bmwktmbill
Traveler
Oddometer: 4,012
Next time try your propane torch...with aluminum it is often enough...for red loctite use/overuse and other tight fits it rarely fails me and I have to go for acetylene and oxygen....
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Times are GMT -7.   It's 02:38 AM.
