Old 11-23-2012, 09:04 PM   #16
fire carl
fire carl's Avatar
Oddometer: 197
love mine, i have the air /hyd model and wont spend money again on the air portion, only problem i had with the lift is after about 3 months the hyd ram and would not extend after pumping on it for 5-8 times, with investigation i found that the rubber plug on the top of the hyd unit had swelled and created a vacume inside the cylinder preventing the lift from raising, solution was to drill a vent hole in the rubber plug and has been trouble free fro 2 years now.
fire carl is offline   Reply With Quote
Old 11-23-2012, 09:42 PM   #17
Yeahbaby
Yeahbaby's Avatar
Oddometer: 72
I like everyone else always bitched and moaned when lying on a cold, damp shop floor working on our treasures. I said enough was enough and bought one. It is by far the best tool you will ever buy for the bike. I also put 2 of these on the sides near where the u-bolt tiedowns are. http://www.boatbuckle.com/transom/pr...transom_g2.htm
They are spring loaded so they auto-retrac. One handed operation and a tight ratchet, sweet!! I attached the set that are rated at 2500lbs, 1" wide x 50" long. So, no more trying to attach a tiedown one handed and having it come loose then trying to get it tight by pulling at unsafe angles with all my weight. When not in use they are rolled up and out of the way.
You can outrun a motorcop....but you can't outrun Motorola
When you start loosing your mind over a woman remember this one simple fact.................it's just the hairy end of a gut!!!!!!!!!!!!
Yeahbaby is offline   Reply With Quote
Old 11-24-2012, 05:35 AM   #18
DustyPockets
Rusty Bike Rider
DustyPockets's Avatar
Oddometer: 44
My buddy just bought one of these, I am not really a great fan of Harbor Freight but I was surprised how nice it was. He also bought it for $299.00 and the warrantee with it.
Best part is his garage is full so it had to go to my shop. If he ever makes room at home I would go right out and buy one.
DustyPockets is offline   Reply With Quote
Old 11-26-2012, 04:16 AM   #19
Mr. Fisherman
oneandahalfassed
Mr. Fisherman's Avatar
Oddometer: 9,806
Yep...
Been there, got that...
http://www.advrider.com/forums/showthread.php?t=457623
This question comes up from time to time... Search is your friend...
http://www.advrider.com/forums/showt...highlight=lift
Mine has been solid. Well worth the investment for me...
I line the mods I have made. It is very versitile.
Mr. Fisherman is offline   Reply With Quote
Old 11-26-2012, 09:17 AM   #20
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,453
It also works great for wheel balancing...
...with my Marc Parnes balancer. No more working stooped over or fiddling with jack stands like I used to do:
Since this shot was taken, I bought a 4-foot-long, 1/2" steel rod (same size as the one in the balancer) at Lowe's for about $5. The one that came with the Parnes balancer was at the very edge of being too short. I cut it to about 2' long and now have plenty of hangover.
GSBS is offline   Reply With Quote
Old 11-26-2012, 09:33 AM   #21
TVtommy OP
TVtommy's Avatar
Oddometer: 187
Sweet...I think I'm going to pull the trigger this week...
1976 R75/6
2009 GSA
2009 HD Ultra Classic
TVtommy is offline   Reply With Quote
Times are GMT -7.   It's 12:27 PM.
