Old 11-22-2012, 09:40 PM   #1
lukeinlondon OP
lukeinlondon's Avatar
Oddometer: 433
clutch leaking a little 950smr
Hi, after bringing my bike back in a truck with a lot of furniture I noticed their is a little oil leakage from my clutch lever. I have a feeling this has something to do with having my bike strapped because their might have been something heavy leaning on one of the straps because one of my hand guards has bent in a little and the clutch lever seems to be angled lower than my front break lever. So i have to reach my left hand further forward than my right...
Any thoughts?
[img=http://s9.postimage.org/5j6q5l9ob/photo.jpg]
lukeinlondon is offline   Reply With Quote
Old 11-22-2012, 09:41 PM   #2
lukeinlondon OP
Oddometer: 433
Old 11-22-2012, 09:48 PM   #3
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Here is the link on this issue:
http://www.advrider.com/forums/showt...ylinder&page=7
You could have Pulled/Torqued your Master Piston and/or Tweaked the Rubber.
There are rebuild kits for this if you need it.
AdvGa is offline   Reply With Quote
Old 11-22-2012, 09:53 PM   #4
lukeinlondon OP
Oddometer: 433
thanks and happy thanksgiving by the way..
Do you know where i can find the rebuild kit?
I dont really understand what they are saying can you lamens' it for me?
Old 11-22-2012, 10:00 PM   #5
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Here is a link to the Rebuild Kit:
http://www.ktmtwins.com/magura-ktm-l...er-rebuild-kit
Old 11-22-2012, 10:05 PM   #6
lukeinlondon OP
Oddometer: 433
well thanks again!!
and with just the information i presented you are sure this is the issue?
Old 11-22-2012, 10:23 PM   #7
AdvGa
AdvGa's Avatar
Oddometer: 1,320
NO, you will have to look into it deeper to see if you pulled the Piston,
Check the Fluid Level, and see if it continues to leak.
If it does then you will have to pursue your course of action.
I did Rebuild mine but it did not last and then changed it out:
http://www.advrider.com/forums/showp...25&postcount=7
Old 12-16-2012, 12:22 PM   #8
lukeinlondon OP
Oddometer: 433
pretty simple...i unscrewed the top of the reservoir and the plastic seal was not on straight..no issues since then!
Old 12-24-2012, 01:49 PM   #9
lukeinlondon OP
Oddometer: 433
until..
i was on the freeway heading out for a big ride of the canyons..clutch started getting loose..
..then i found it hard to change the gears with the clutch..then i couldnt changed the gears so i had to rev and change the gears with no clutch..which mean't getting into neutral before i go to the red light otherwise they wheel could have locked up at low speed in 1st gear?!?..managed to get it to a friends guest house about 10 miles away..next trip to Mr Tim Robel..in a pick-up
Times are GMT -7.   It's 09:33 AM.
