11-22-2012, 11:35 PM
#1 |
Serbia Strong
Tire patch/plug question.
Not exactly sure if this is the right place, but I did see some tire threads so here is a shot... if it's not the right place, please move it. :)
Ok, I may also get flamed for this question, but my flame suit is on so here goes it. Last year, I got a flat tire on my bike... it happened to be a split, as seen below: ![]() NOW, the problem with this, is the fact that getting this 860lb machine on the flat bed was probably scarier than the tire going flat itself.. I'm not entirely sure how the tire split that way, but it did. What I'd like to know, is if there is any possible way that could be patched? Now this happened well over a year ago now, but I'm still really scared about it happening again and having to go through that same scary experience of trying to ride it up just far enough on a slippery flat bed so the operator could lift it up and get it chained down. All I would need to do is get it patched up to get me home so I can go buy a new tire, then trailer the bike to a shop to get it put on, or if I'm out touring, to putt down the interstate/hwy's to the nearest bikeshop to get the tire replaced. So, like I asked, is there anyway a SPLIT like that could be repaired to be safe enough to do just what I stated? Thanks for the help guys.
2009 Vulcan 2000 Classic. |
11-23-2012, 02:18 AM
#2 | |
Oddometer: 1,976
Take the wheel off, take the wheel to someone who can change the tire, bring it back, put it back on the bike. Couple of cheap car scissor jacks (junk yard, a few $ each) and a 2x4 under the front of the swing arm should lift it and be stable. Pete |
11-23-2012, 04:43 AM
#3 |
Wrench Rider
Oddometer: 712
A split longer than about 1/4 inch, maybe 3/8" cannot be safely repaired. Plugs
do not work well in splits as the plug leaks at the ends of the splits.... A patch with no plug will not work (safely) due to weakness at the split area. Roll-back wise, many roll-back operators now carry small dollies with built-in wheel chocks, especially made for safely, easily loading motorcycles. Usually this one:http://www.buyersgroup.com/products/condor/condorfr.htm |
11-23-2012, 08:02 AM
#4 |
Still a stupid tire guy
Oddometer: 7,270
As was stated, that tire has been cut. I've pulled hundreds of razor blades out of tires over the years.
Assuming you had the skills, you could pull that tire off of the wheel, install a large radial patch over the cut area, and install a tube. This type of repair would only be recommended as a "I have no other choice to get my ass out of a dangerous spot" type of thing. I would not ride it any farther than is absolutely necessary to satisfy the above statement. You won't find a bike shop or a tire shop in North America that would touch that repair for love nor money.
"Nearly all men can stand adversity, but if you want to test a man's character, give him power." - Abraham Lincoln |
11-23-2012, 08:08 AM
#5 |
Serbia Strong
Well, like I said, this happened well over a year ago... I've already pretty much burned through a Metz ME880 since then.
Thanks for the replies guys. Part of me wants to think someone sliced it and it just gradually got worse, but I don't know... the thought of that happening again scares me, because like I said... it was a scarier ordeal getting it up on the flatbed than it was when the tire lost air at the snap of a finger. All the more reason to get an ADV bike with a center stand so I can fix this stuff on the side of the road right?
11-23-2012, 08:51 AM
#6 | |
WFO for 41 years
Oddometer: 3,995
Too much is just barely enough..... 2007 Tiger 1050 2005 Royal Star Tour DeLuxe 1973 Yamaha TX750 1974 Norton 850 Commando Roadster |
11-23-2012, 10:05 AM
#7 | |
Serbia Strong
![]() What I was talking about.
2009 Vulcan 2000 Classic. TxRoadDog screwed with this post 11-23-2012 at 10:07 AM Reason: first pic too large |
11-24-2012, 04:06 PM
#8 |
Oddometer: 3,312
You probably just ran over something on the road, or you parked your bike someplace neither you or it needed to be..Anyway, you cannot repair that type of cut safely.
If I wasn't here, I'd be somewhere else |
11-24-2012, 04:44 PM
#9 |
Registered User
Oddometer: 25,005
Tires are built up in layers.
If the inner carcass was not pierced, and the cut was only in the raised tread, it's no biggy. Think deep 'sipe' cut. Just look and see what was actually cut and how deep. Tread cuts are no deal. |
11-24-2012, 10:34 PM
#10 | |
NoMoTDM still Gary
Oddometer: 3,707
The tire is toast because Bigger Al said so and he does it for a living. Even if he had not, I would think so, because the cut is deeper than the sipe and it let air out. It probably cut some cords in the process. If it is off the bike what does it look like on the inside? My motto is when in doubt (riding a 860lb bike at 80 mph) don't
BMW Motorrad USA customer service: "We make superior motorcycles and continue to improve them." |
11-25-2012, 06:49 AM
#11 |
Oddometer: 21,547
Unlike a puncture, which damages only a couple strands of the cord plies, a slice deep enough to lose air through cuts *all* the cord strands along the length of the slice.
If the cut is shallow enough to not affect the cords, its *probably* okay, but start shopping for a replacement as soon as you can. If the cut is through the tire, find a ride to a shop for a new tire, it is not fixable. |
11-25-2012, 09:45 AM
#12 | |
TE450-KLE-FXDWG
Oddometer: 2,734
____________________________________ Get fit. Stay safe. Enjoy life. Learn something to help someone in need. |
11-25-2012, 02:47 PM
#13 | |
Oddometer: 7,715
I used to change car, farm implement and tractor trailer tires for a living. I've seen all sorts of things protruding from tires. A hole is one thing to patch. A slice could possibly split even further and cause it to go flat again...very quickly! You may as well stick a fork in that tire...it's done!
2004 XR650L 1992 Specialized Stump Jumper FS NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST |
11-26-2012, 05:30 AM
#14 |
Oddometer: 719
Personally, Id probably patch it, put a tube in it, and keep riding it.
That being said, in all honesty, Id have to actually see it to properly assess it. Its easy to have an opinion looking at pictures on the internet. Relying on patches/plugs alone.....no. I wouldnt use it.
All that is gold does not glitter, Not all those who wander are lost J.R.R. Tolkien 01 F650GS Dakar 04 KLR 650 (Need to sell) |
11-27-2012, 10:01 AM
#15 | |
Serbia Strong
As to what the tire looked like inside, it was cut all the way through. As to the comments on me running over something, that is probably what happened. Wouldn't surprise me if a razor blade was sitting right straight up in a crack in the road and I ran right over it. Thanks for the help guys, I really appreciate it!
