Old 11-26-2012, 11:13 AM   #16
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,569
Originally Posted by robtg View Post
Why not do it right and send them to a machine shop, mill the top parallel to the bottom like they are supposed to be?
If they're really warped then yes that's the best way to go, but if it's just a nick, gouge, or other high spot on the mating surface, it's easily taken care of with a file or dressing stone.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 11-26-2012, 01:47 PM   #17
Bluethumb OP
Oddometer: 130
I pulled the heads last night and will do just as suggested - take them to a buddy who is a machinist. He can disassemble the valves for me and fortunately he's really good at doing valve jobs.
The left head has a high point in the very center, near the center stud. In addition, placing a straightedge across the top and across the bottom, I can see gaps, noticeable, enough to slip a .0010 mm feeler gage here and there. The right head is similar but not as severe.
I'll find out more later this week when my buddy pulls the valves out. The valve faces look good from what I can tell, but of course he'll be able to measure the valve stems and guides.
In the end, it will be done right. And I guess in the end, that's all that matters!
Bluethumb is offline   Reply With Quote
Old 11-27-2012, 05:28 PM   #18
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,551
I expect this is a typo: 0.0010 mm is a micron - which should have no problem sealing with a gasket. Similarly, a 0.001 inch gap (0.0254 mm) should seal OK with a gasket. Good luck!
Stan_R80/7 is offline   Reply With Quote
Old 11-28-2012, 05:37 AM   #19
Bluethumb OP
Oddometer: 130
You're absolutely correct, .10 mm gap.
Old 11-29-2012, 10:38 AM   #20
Crisis management
Latte riders FTW!
Crisis management's Avatar
Oddometer: 1,479
I'm obviously not alone in this..... The R80 gets it's valve covers pulled this weekend and a few high spots removed, I will be using the file or dressing stone method having found it very effective in the past. I have an indelible memory from my apprentice years of a demonstartion on draw filing a 6 cylinder cast iron head flat after it had warped, there's nothing a hand tool can't fix!
Orange...cause it makes me look like I know what I'm doing!
Crisis management is offline   Reply With Quote
Old 11-29-2012, 11:36 AM   #21
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,943
Something I heard many years ago and would like to know more about. It was either mechanics or probably engineers in training in Germany, they had classes in filing. The spent hours each week learning various methods of using a file.
There are some small publications on the subject but I've not found much in depth.
I own some good files and I also have handles that fit. I've found a good handle improves the experience.
---Albert Einstein
disston is online now   Reply With Quote
Old 11-29-2012, 12:59 PM   #22
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,551
My approach to getting the head surface in contact with the valve cover surface was based in the art of scraping. Although, no scraping of the valve covers was done - it was sanding using 180 grit paper. Scraping is a machinist technique to get two surfaces within extremely close contact to each other. Generally, one of the surfaces is part of a machine tool (lathe bed, mill bed, etc) and the other is a saddle or table. Marking fluid (typically prussian blue) is applied to one surface and where the blue is removed is where the metal is scraped (i.e. the high spots).
I reversed the process (since the head had raised spots) and instead removed material from where the blue was on the valve cover. After each sanding of the marked areas, the valve cover is completely cleaned, the blue reapplied to the head and the process repeated. Also, my fitting was done with the head on the bike - so sanding or filing on the head was prohibited due to getting debris in the engine.
Plenty of ways to skin a cat. Plus, as noted, it turns out my valve cover fit was not off that much and the eventual leak was found to be from a pushrod tube. The double gasket idea is not a bad one if it works to stop a valve cover leak (I had not thought of that). There is no reason for a high precision fit between the valve cover and head mating surfaces.
Old 11-29-2012, 03:50 PM   #23
Crisis management
Latte riders FTW!
Oddometer: 1,479
Draw filing is essentially holding the tip of the file on one hand, the handle in the other (as you normally would) but pulling on the tip rather than pushing on the handle to draw the file over the surface. Typically we push very hard on the handle which naturally rocks the file down onto the work piece, by relying on a controlled pulling action it is easier to guide with the handle and maintain a flat contact surface. Using engineers blue on the surface to show the high points as Stan mentions, allows the development of a flat surface.
I have no doubt that the surface is not truly flat but for low pressure situations (older engines / valve covers) it is sufficiently flat. Generally for something like the valve cover I will wet a sheet of 200 grit wet & dry paper, slap it on a nearby window (glass) and rub the mating surface directly on that. Glass is flat enough and the surface is done in a couple of minutes. Make sure you don't use old (50 years) glass as glass is actually a liquid at ambient temperature and flows downwards over the years resulting in a rippled surface.
Failing all this, two gaskets should work.....
Old 11-30-2012, 07:01 PM   #24
supershaft
because I can
Oddometer: 9,116
I do not recommend those after market gaskets there or anywhere else. They are a problem waiting to happen IMO. Besides, the stock gaskets work perfect. I have only heard of the vavle covers being part of the trouble on the net. I have still never seen it. The soltion is milling your head. teh stop gap solution is two stock gaskets with sealant BETWEEN the gaskets. Otherwise, no need to use goop there or on any other paper gasket on our bikes.
Old 11-30-2012, 08:34 PM   #25
Bluethumb OP
Oddometer: 130
On both my '81 and '84 R80G/S's I used the Real silicon rubber gaskets, both valve overs and float bowls. Total milage, 70,000. Not one single problem. They worked great. Paper gaskets work fine for the valve covers, but the Real gaskets for the float bowls are far better.
The problem I'm having with this ST is because the previous owner over tightened the center stud pulling the surrounding surface up. My machinist is going to take a very light cut flattening the surface.
Once I get back to a nice, clean, flat surface on the mating surfaces, I'm going to use Real gaskets. Properly used, they work just fine.
Old 12-01-2012, 12:36 PM   #26
supershaft
because I can
Oddometer: 9,116
The cork bowl gaskets work perfectly for decades. How do you get better than that?
The heads warping is not from over torqueing the cover stud. It's from combustion heat.
Old 12-03-2012, 06:59 AM   #27
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 48,351
Originally Posted by bmwhacker View Post
I ended up using two gaskets on each side on my R100s engine...no sealant. Don't like using sealant as valve cover removal seems to be a frequent event in my world. Maybe not a proper fix but they don't leak anymore.
This
Uncle Pollo is offline   Reply With Quote
Times are GMT -7.   It's 06:43 PM.
