Old 11-23-2012, 02:33 PM   #1
Beard OP
Pro Blowhard
Oddometer: 39
installing hepco and becker engine guards / crash guards on r1100Gs bushing size?
just got a hepco and becker engine guard / crash bar set in the mail today.
everything reads r1100 850 yada.. but it seems like the bushings are way to short.
when they slip into the frame "cups" they would just rattle back and forth between the bottom of the cup and the top plate of the engine guard.
anyone have experience with it?
sure seems like i have the wrong length bushings
Jack of all trades / Master of nothing
Beard is offline   Reply With Quote
Old 11-23-2012, 02:41 PM   #2
LaurelPerryOnLand
Oddometer: 3,482
NEW or "new to you".
That is, if it's NEW...they SHOULD be the correct bushings.
Sounds like since you got the 'instructions'...I'd go ahead and follow them.
Have any pics showing 'discrepancy'???
LaurelPerryOnLand screwed with this post 11-23-2012 at 02:56 PM
LaurelPerryOnLand is offline   Reply With Quote
Old 11-23-2012, 02:47 PM   #3
Eddy Alvarez
Addicited to ALL bikes!
Eddy Alvarez's Avatar
Oddometer: 2,330
Unfortunately, yes...The engine guards went on fairly smoothy but the tank guard installation was a lesson in patience, anger managment and profanity control. Nothing fit well, things didn't line up right, the guards were so close to the tank that it prevented removing the side panels (which required cuttting, spreading with a jack, re-welding and repainting). Once everything was in place, I was pleased... It now looks and feels as strong as a tank!
Good luck! Have a beer, or four...Patience is a virtue!
Me: Honda CB1100 BMW R1200GS KTM 525EXC. Gabriel: KTM 50. Elena: Honda CRF70. Lynn: Sugar Momma and Gatorade/snack girl!
Eddy Alvarez is offline   Reply With Quote
Old 11-23-2012, 02:52 PM   #4
Beard OP
Pro Blowhard
Oddometer: 39
brand new.. instructions in german..
ive built cafe racers from the ground up for years.. i dont know if im over thinking things and over looking the obvious...
ill post some pictures in a couple mins
Old 11-23-2012, 03:20 PM   #5
Beard OP
Pro Blowhard
Oddometer: 39
so you can see only using 1 12mm spacer.. it would do nothing and rattle between the bottom of the cup and the crash bar plate that would cover that hole.
also if i use the spacers inside the cup.. then why are the bolts much longer that stock? to compenstate a 1/4in thick plate?
is the solution to leave the frame cup empty... and use the spacers on the outside of the gaurd.. hence making the heads stick out further than they really need too?
yeeeshh..
Old 11-23-2012, 04:17 PM   #6
serenitynow
Oddometer: 22
I fitted a set recently and followed a tutorial that some fella had put together on the UKGSER website, which was quite useful. Ill see if I can find it for you.
serenitynow is offline   Reply With Quote
Old 11-23-2012, 04:30 PM   #7
Beard OP
Pro Blowhard
Oddometer: 39
thanks for the attempt but we are from different worlds..
Old 11-23-2012, 04:55 PM   #8
serenitynow
Oddometer: 22
Hepco & Becker Engine Bars for BMW R1150GS
Fitting Instructions
Hepco & Becker engine bars are an excellent product and one of the best sets of bars available for the BMW R1150GS. However, they are not a perfect fit and require patience and a bit of muscle to get them right. Also, it is possible to get into difficulty with alignment of the bolt through the riderís footrest hanger and gearbox housing. For this reason, the manufacturerís clearly post the following warning:
Do not loosen the right hand side and left hand side rear attachments at the same time, otherwise there is a danger of the rear subframe dropping.
So, fit one side of the bike at a time!
Before you start
You will need just a few tools for the job:
• The bars and fitting kit (bolts, washers, spacers)
• 6mm and 8mm allen headed sockets (do not be tempted to use allen keys)
• Socket wrench and short extension bar
• Trolley or bottle jack or some sort of axle standard
• Torque wrench (this is not essential)
• A lubricant such as Copper-ease
• 2 to 4 spare 65mm long M10 bolts (this is a precaution not a necessity: they
can be regular hexagon headed and do not have to be recessed allen headed)
It is strongly recommended that you have a spare pair of (strong) hands to help you, but it can be done on your own.
You will need to remove your Baglux tank cover if you have one.
The job should take no more than 1 hour per side and can be completed in as little as 30 minutes total if all goes well. However, it is best to allow up to 4 hours in case of difficulties. Read all the instructions first to familiarize yourself with the job.
The fitting kit
The fitting kit that comes with the bars consists of the following:
• Four 65mm long allen-headed bolts (requiring an 8mm allen key/socket)
• Four large washers
• Two smaller washers
• One M8 self-locking nut and bolt
• Two 18/11 x 12mm long alloy spacers
• One 18/11 x 20mm long alloy spacer
One 18/11 x 17mm long alloy spacer
Preparation for fitting
The bars can be fitted without removing the tank but it must at least be moved backwards a few inches. This is very simple. However, the job is much easier if you can remove the tank entirely. These instructions assume that you have not done this and will simply slide the tank backwards.
1) Place the bike on its centre-stand and remove both seats from the bike
2) Remove the black plastic cover level with the bottom of the tank on the right
hand side of the bike. This is a push fit with three male/female joints and
simply pulls off.
3) Undo, remove, and put to one side the bolt and nut holding the tank in place
(this is not a fixed nut ñ donít let it drop into the bowels of the bike)
4) Gently lift the rear end of the tank and slide it backwards until the brackets on
either side (under the tank) clear their holders. If youíve never done this before, donít worry, itíll be clear what is meant once you start. The tank can now be held either side and moved as desired backwards a few inches or twisted slightly to allow access for the front fixing bolt. Remember: the fuel lines are still attached, so donít try to move it too far! Itís OK to rest the tank gently on the fuse boxes but itís best if the tank is not full with petrol!
It is now easier to appraise the situation, in conjunction with the Hepco & Becker diagram that came with the bars. There are three fixing points per side. It is impossible to get the wrong ones!
Fitting the bars
Fit one side at a time.
Offer up the bars to the bike to see more clearly how they fit. Remove the three existing bolts one side of the bike first.
The front fixing position uses the original 6mm allen headed bolts that hold the instrument panel subframe to the main frame. This bolt is obscured by the tank, but with the tank moved backwards slightly and twisted a little the bolt can be accessed without complete removal of the tank.
The middle fixing position involves replacing the original allen-headed M10 bolt with one of the longer bolts. The bolt is situated just below the level of the tank, above the injector and air intake assembly and partially obscured by black plastic injector pipes. It fits into a recessed hole within the black tubular bike frame. For this reason, when you fit the bars you will need to put one of the 12mm long spacers into the recess and use a washer between the bolt head and the bars themselves. There are two identical 12mm spacers in the fitting kit ñ these (short) spacers are for the right and left middle fixing positions.
The rear fixing position involves replacing the original allen-headed M10 bolt with one of the longer bolts. The bolt is situated at the top of the diamond-shaped riderís footpeg hanger and is conspicuous because it goes through this hanger, through the black tubular bike frame that supports the seats, and into the gearbox housing. This is an awkward bolt to remove and replace. Once you have removed this bolt
you are committed. The bolt is under a lot of pressure laterally from the weight of the components it holds together. Removing it can be difficult and it will feel as if itís not turning smoothly. Do not be surprised if this bolt has been loctited in and is very stiff to shift. Do not worry though, your bike will not suddenly collapse when it is removed ñ providing you do not remove the other side at the same time! The original bolt is recessed into the footpeg hanger. This recess is filled by the longer 20mm spacer on the left side of the bike (the exhaust side) and by the 17mm spacer on the right side (the footbrake side). Again, use one of the washers between the bolt head and the Hepco bars.
Fitting is a matter of offering up the bars and refitting with new bolts, spacers (where needed) and washers. The sequence of fitting can be quite important:
1) Lubricate the bolt threads with copper-ease or similar.
2) Try fitting the middle bolt first, but do not tighten fully
3) Then fit the front, upper bolt that is hidden by the tank (If this proves too
awkward then reverse this procedure and fit the front upper bolt first)
4) Do not fully tighten either of these bolts
5) Fit the rear lower bolt to the footpeg hanger last as the bar end here is the
most pliant and with two pairs of hands can be held in place whilst fitting. (First see the note below) It is also the most accessible. Do not be surprised if the eyelet on the bars for this bolt seems to be an inch or two out of alignment! In the worst instances you will need to lever this section of the bars back using a strong bar placed between the H&C bars and the cylinder head to achieve vertical alignment and/or push/pull the arm of the bar down or up to get horizontal alignment ñ this is where the spare pair of hands comes in useful.
6) When all three bolts are partially tightened, fully tighten the rear bolt first. Then tighten the other two.
7) Now do the other side.
8) Finally, join the two sides of the bars together at the front with the nut and bolt
Warning: the Rear Bolt
As soon as you remove the original bolt from the footpeg hanger, the rear subframe will sink very slightly. This can make fitting the new bolt virtually impossible and any attempt to do so without correct alignment will result in stripping the threads of the new bolt. Before attempting to fit the bars, but after removing this bolt, use a torch and/or some sort of drift (a small screwdriver or a small allen key) to ascertain whether there is anything obstructing easy tightening of the bolt. If the subframe has dropped fractionally then you need to jack-up the rear of the bike. The simplest method is to use a trolley jack or bottle jack with a wooden block or brick under the rear pillion footrest. You only need to raise the subframe a millimeter or two; donít go too far the other way. Check with the torch/drift that the subframe is no longer obstructing the hole. Lubricate the bolt and try to make sure you keep it parallel to the sides of the hole. Once it is engaged with the threads of the gearbox housing you can use a socket to tighten it. Any excessive resistance at this stage is an indication that the bolt is rubbing against the hole in the subframe and the threads will be stripped very quickly. Be patient!
Old 11-23-2012, 04:57 PM   #9
serenitynow
Oddometer: 22
There we are, got there eventually. It's all about playing around with the spacers
Old 11-23-2012, 05:39 PM   #10
Beard OP
Pro Blowhard
Oddometer: 39
ive came across that exact pdf already.
and thats for 1150. 1150 is a different kit than 1100 / 850
and show me where u get "its just playing with the spacers"
says nothing of that sort.
Old 11-24-2012, 04:12 AM   #11
serenitynow
Oddometer: 22
I get playing around with the spacers because that's what I had to do to fit mine. I know it's the 1150 guide but I found it of assistance.
Old 11-24-2012, 05:31 AM   #12
serenitynow
Oddometer: 22
I've taken the best pics I could of the spacers on mine
Old 11-24-2012, 05:31 AM   #13
serenitynow
Oddometer: 22
Left
Old 11-24-2012, 05:32 AM   #14
serenitynow
Oddometer: 22
Left front
Old 11-24-2012, 05:33 AM   #15
serenitynow
Oddometer: 22
Right bottom
The small bracket has to fit round the back of the brake pipe
Times are GMT -7.   It's 05:35 PM.
