Old 11-24-2012, 05:34 AM   #16
serenitynow
Oddometer: 22
Right bottom again
serenitynow is offline   Reply With Quote
Old 11-24-2012, 05:35 AM   #17
serenitynow
Oddometer: 22
Right top.
Old 11-24-2012, 05:36 AM   #18
serenitynow
Oddometer: 22
Front under tank.
Let me know if you need better pics of any of them.
Cheers
Peter.
Old 11-24-2012, 11:37 AM   #19
Beard OP
Pro Blowhard
Oddometer: 39
i understand.. but i have 4 spacers..
if i need 2 12mm spacers in each frame pocket.. then i dont have enough spacers
Jack of all trades / Master of nothing
Beard is offline   Reply With Quote
Old 11-24-2012, 11:42 AM   #20
serenitynow
Oddometer: 22
If you've got a 20mm spacer, that goes in the left hand frame pocket. You'll notice in the first pics that it brings the bars quite a bit out from the frame.
Old 11-26-2012, 04:08 PM   #21
Beard OP
Pro Blowhard
Oddometer: 39
2 x 12mm = 24 to barely get flush on all frame pockets..the 20mm would be too short
Old 11-27-2012, 04:51 AM   #22
serenitynow
Oddometer: 22
Sorry, it certainly seems strange. 1 x 20mm and 3 x 12mm were all that came with my fitting kit. As you can see, the 20mm one comes out a fair bit on the left side.
Seems the frame pockets on yours are a bit deeper for some reason.
Old 11-28-2012, 06:49 AM   #23
Beard OP
Pro Blowhard
Oddometer: 39
are u able to take one bolt out and verify the length of one of the bushings.. ive been on the phone with the place i bought it from with out a solution yet
Old 11-28-2012, 01:27 PM   #24
serenitynow
Oddometer: 22
Yea certainly, which one ?
Old 11-28-2012, 03:20 PM   #25
serenitynow
Oddometer: 22
Spacers are 20mm on the left and the others are all 12mm.
Old 12-04-2012, 08:51 AM   #26
Beard OP
Pro Blowhard
Oddometer: 39
right i have 3 - 12mm.. and 1 - 20 mm.. but if u look at my pictures.. all of the frame cups that u put the bushings into.. require at least 2 of the 12mm bushings for it to be close to flush. for a total of 24mm
on urs.. that 20mm sticks out.. on mine it would be 4mm below the cup outside edge..
all the other pockets using only 1 12mm.. the bushing would be 12+mm from the edge of the frame cup
have email to place i bought and hepco germany themselves.. waiting to here from them..
basically i need a 2nd set of bushings
Old 12-05-2012, 04:47 AM   #27
papachiax6
papachiax6's Avatar
Oddometer: 12
Recently had the same issue as you but on a gs. I bought a set used and missing some spacers. As long as you know the length of the spacers you need, go down and buy a bunch of washers to fill the void. I bought stainless so the wouldn't rust. Worked for me.
papachiax6 is offline   Reply With Quote
Old 12-05-2012, 10:04 AM   #28
Beard OP
Pro Blowhard
Oddometer: 39
great idea with the washers..
thanks
stainless steel washers.. that probably set u back say $30 :)
Old 12-05-2012, 09:24 PM   #29
papachiax6
papachiax6's Avatar
Oddometer: 12
yep they were a little pricey but it works. I also had to chop off the mounts on the tank bars and weld on new mounts to fit. Repainted with stove paint and they look brand new.
Old 12-06-2012, 04:53 AM   #30
rvt
Big Fat Trail Bikes
rvt's Avatar
Oddometer: 1,248
hate to complicate it further, but...
Will this bike be doing much off road work, corrugated dirt or carry big loads?
If so, you might want to think about fitting frame reinforcement plates. TT sell them. Mine is built to Aussie spec, so came with them.
They will affect the way you mount the crash bars.
http://www.touratech-usa.com/Store/2...R1100GS-Yellow
Cheers, RVT
This week's ride: http://share.findmespot.com/shared/f...Vcz6Icqrhsbbpq
rvt is offline   Reply With Quote
Times are GMT -7.   It's 03:46 AM.
